Question about Muvee Technologies autoProducer 4 for PC
Muvee autoproducer 4.5 run time error - Muvee Technologies autoProducer 4 for PC
Muvee autoproducer 6
Did you install the stylepacks? If not, you need to install them.
Jun 18, 2014 | Computers & Internet
I have a problem in using my webcam,its indicated that i need to turn it on.
You need a program like QuickPlay or Muvee Autoproducer to activate the webcam. When in Quickplay, go to the bottom of the screen, select the icon with a camera, and then choose the device from the left-hand menu.
Press the QuickPlay button (normally located near the display) on the notebook PC to open the QuickPlay application.
Alternately, click Start , type QuickPlay in the search field, and select QuickPlay when it becomes available to open the QuickPlay application.
Click the Video icon, and double-click HP webcam in the Source column.
The input from the webcam displays on the screen
Jan 03, 2011 | HP Pavilion dv6000z Notebook
Compaq Presario CQ50-110US 15-Inch Laptop PC Notebook: my computer keeps saying it cannot detect my built...
The issue might be due to corrupted drivers or with other operating system settings. Let me assist you in this regard.
To isolate and resolve the issue, please perform the below steps:
Uninstalling Webcam drivers in vista:
1. Click Start.
2. Type Device Manager in the Start Search box
3. Click the Device Manager.
4. Click the "+" sign next to Imaging devices.
5. Click the first device listed under Imaging devices .
6. Click Remove to remove the HP webcam 1000 driver.
7. Click OK for confirmation.
8. Close the System Properties box.
9. Restart the computer by clicking Start, Shut down, Restart, and then OK
Note : Uninstall all the webcam drivers that you come across.
Install the Webcam drivers that are being provided URL:
ftp://ftp.hp.com/pub/softpaq/sp34501-35000/sp34746.exe
Installation Instructions
1. Download the SoftPaq .EXE file to a directory on your hard drive.
2. Execute the downloaded file and follow the on-screen instructions.
I recommend you reset the "Windows Image Acquisition (WIA)" service settings by performing the below steps:
1. Click Start
2. Type Run in the start search box and select it
3. Type "services.msc" and click on Ok
4. In the list, select the "Windows Image Acquisition (WIA)"
5. Double click the "Windows Image Acquisition (WIA)" service, and under the startup type select Automatic.
6. Click on "Start" button if it is stopped under Service status
7. Click the Recovery tab.
8. Set all the First failure option to Restart the sevice.
9. Select the same for Second failure and Subsequent failures.
10. Click Apply and click OK.
Furthermore, update the BIOS that is available in the below URL:
ftp://ftp.hp.com/pub/softpaq/sp36501-37000/sp36551.exe
NOTE:Clicking the link may give an error indicating it is invalid. If this occurs, copy the portion of the address on the remaining line(s) and paste it at the end of the address showing in your browser until the complete address is displayed in the Address box.
After the above steps are performed, please check the functionality of the Webcam by following the below steps:
To work with the built-in Webcam of your notebook, you have to use either QuickPlay or Muvee Autoproducer software installed in the notebook or use Yahoo, MSN or AIM messenger and check the functioning of Web Cam.
To use QuickPlay, perform the below steps :
* Click on the Vista button (formerly called the Start Button, and also now referenced as the Pearl button)
* Click on All Programs
* Click on QuickPlay
* Within the QuickPlay application, click the Video icon (Icon resembles, camera, music, and film)
* Double click on "HP Webcam" in the Source column
The screen will now display the webcam input. From this screen, the customer can click record at the top; recorded files will be added to the play list. To playback video, the customer should double click on a file from the Play list column.
To use Muvee Autoproducer software perform the below steps :
Open Muvee Auto Producer >> Click Tools >> Get Video from Camcorder.
If issue persists, then stop and temporarily disable Windows Media Center Receiver Service (if found)
1. Open the Services item in Control Panel. To do this, click Start, type services in the Start Search box, and then click Services in the
Programs list.
2. Click Windows Media Center Receiver Service.
3. On the Action menu, click Properties.
4. Click the General tab.
5. In the Startup type field, click Disabled, and then click OK.
6. Restart the computer.
Uninstall Vista security update KB915597 (if found in your notebook)
1. Open Programs and Features by clicking the Start button , clicking Control Panel, clicking Programs, and then clicking Programs and Features.
2. Select Vista security update KB915597, and then click Uninstall. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Additionally, download and install the fix from the following link:
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36128.exe
Alternatively for testing the HP webcam you can follow the below steps
Download the and install SoftPaq SP35414 to preview the WebCam.
ftp://ftp.hp.com/pub/softpaq/sp35001-35500/sp35414.exe
NOTE: Clicking the link may give an error indicating it is
This Software has a Preview, Capture, Take a Snap options.
Now for using the webcam with the above software you should follow the path mentioned below:
C:/ProgramData\Microsoft\Windows\Start Menu\Programs\HP\HP Webcam
May 17, 2010 | HP Compaq Presario CQ50-110US Laptop
How do you turn a webcam on???
From your Email, I understand that you wish to know how to start and use the webcam in your Notebook.
I would like to inform you that, to start or enable the services for camera "Windows Image Acquisition (WIA)":
1 Click Start
2 Type Run in the start search box and select it
3 Type "services.msc" and click on Ok
4 In the list, select the "Windows Image Acquisition (WIA)"
7. Click on Apply and Ok
Let me inform that to work with the built-in Webcam of your notebook, you have to use either QuickPlay or Muvee Autoproducer software installed in the notebook.
Open Muvee Auto Producer >> Click Tools >> Get Video from Camcorder. The screen will now display the webcam input.
To use QuickPlay, do the following:
1. Click on the Vista button (formerly called the Start Button, and also now referenced as the Pearl button)
2. Click on All Programs
3. Click on QuickPlay
4.Double click on "HP Webcam" in the Source column
From this screen, you can click record at the top; recorded files will be added to the play list. To playback video, you should double click on a file from the Play list column.
I am sure that the above information helps. If you need any further assistance or clarifications, please feel free to reply to this mail. We would be delighted to assist you.
May 14, 2010 | HP Pavilion dv6000z Notebook
How to work the webcam???
From your message, I understand that you wish to know how to start and use the webcam in your Notebook.
1 Click Start
May 14, 2010 | Compaq Presario CQ50-215NR Notebook
Muvee Autoproducer 6.1 not importing video from Sony handycam
Try importing to windows, create a folder and then try importing to your programme.
Apr 26, 2009 | Muvee Technologies autoProducer 4 for PC
Missing files - cannot save
try this, i'm not really sure what the problem is because i've never used Muveereveal, but try uninstalling it, and removing its folder from c:\programfiles\Muveereveal, because even though you uninstall it, some times some registries stay in that folder and it can just be restoring the same files over and over again, you can do that or when re-installing it and it ask you what directory you would like to save it at, instead of c;\programfiles\Mueereveal, add an "s" at the end of the folder confusing the computer making it think its a new program. You can also try deleting all the registry that come installed with this software and reinstalling it....
i hope this helped.
Apr 16, 2009 | Computers & Internet
License
You would need to contact muvee for that information.
http://www.muvee.com/en/support/
Dec 16, 2008 | Olympus Stylus 790SW Digital Camera
Crystal eye webcam
Using HP webcam in Quickplay software:
1. Click on Start button, select All programs and click on Quickplay.
2. Within the Quickplay application, click the Video icon (Icon resembles, camera, music, and film).
3. Double click on "HP Web cam" or “USB Video device” in the Source column.
4. Now you could see your self on the screen.
Using HP webcam on Muvee Autoprocucer software:
1. Click on start, Select all programs and click on Muvee Autoproducer.
2. It will open Muvee Auto Producer. (Click on Trial version if it prompts.)
3. Click on Tools the top and select the Get Video from Camcorder.
4. You would see your self on the screen.
If the webcam does not show the picture you need to perform the below steps. If the webcam works, you need not to perform the below steps. Please ignore the below steps. However, I personally recommend you to save this email and if any time the webcam does not work or if it shows blank screen please perform the below steps.
Before we trouble shoot this issue let me explain the reason for this issue, HP has released new driver for webcam and the driver update process can’t be done automatically and as long as the old driver exists the webcam does not work, To resolve this issue First we need to uninstall the existing webcam from device manager. Then restart the notebook and install the latest driver to resolve this issue
Step 2: Steps to Uninstall the Webcam drivers from the device manager.
1. Click on start and click on Control panel.
2. Click on "the Classic View" on the top left side of the control panel.
3. Double click on the "Device Manager" icon in the list.
4. Click on + next to the Imaging devices. Now you would see one HP Pavilion webcam or more then one web cam listings under the Imaging devices.
4. Right click on each HP Pavilion web cam and click on uninstall. And confirm un installation if it prompts. (Click on Yes.)
5. Now the Imaging devices option should not appear on the device manager.
Note: If the HP pavilion webcam is not listed or Imaging device is not listed, in device manager you need to reset the Bios to enable the webcam. Once you reset the Bios the webcam will listed in device manager. Here are the steps to reset the Bios.
1. Restart the notebook.
2. Tap the F10 key as soon as the HP logo appears.
3. Using the arrow keys, navigate to Exit Menu, select "Load Setup Defaults" and select "Exit Saving Changes"
Step 3: Restart the notebook.
Step 4: Click on the below link and then click on Save button of the download window. Click on brows and then click on desktop then click on Save.
*we need to download the file to the desktop.
Step 5: Installing downloaded web cam driver (sp34746).
1. Double click on the downloaded file (sp34746) and follow the on screen instructions to install the file.
Step 6: Once the installation prompts you that the installation has been successfully completed. Now you need to restart the notebook.
Now check the webcam input in Quickplay software using the steps provided on the step no. 1. The webcam should work, if the webcam does not work please verify the below steps.
Step 7: Enable the Imaging services on the notebook.
1. Tap Window key(flag key on the keyboard) and R key on the keyboard, at once.
2. You would see the Run window on the screen.
3. Type SERVICES.MSC and hit enter.
4. You would see the services window on the screen.
7. Click on Apply and Ok.
Step 8: Now check the webcam in quickplay or Muvee software. verify the step 1 to know about how to use the webcam in quickplay or muvee.
If the still issue persists, Please check webcam name in device manager. If you see USB 2 Video device under the Imaging devices the webcam works properly (it means latest drivers have been loaded successfully). If you see the HP Pavilion webcam under the imaging devices, it means still the notebook is using old webcam drivers and you need to repeat the steps from Step 2:
Follow theses steps should help ya get back on line with your cam .
Good Luck, Have a great Sunday and a safe one.
Dec 02, 2007 | Computers & Internet
HP webcam dv6000 is not working properly
Weird but worked for me for yahoo and messenger but not quickplay. If you have the Chicony web camera, follow these steps to download Acer webcam drivers.
1. Download Acer 5210 Chicony Webcam drivers.
2. Run the setup file.
3. Follow installer prompts then RESTART PC.
4. Ignore the 'installing drivers' popup.
5. Open up the Control Panel.
6. Open up the Device Manager.
7. Select webcam from 'Imaging Devices'.
8. Right click on webcam and select 'Update'.
9. Select 'Browse computer for driver'.
10. Choose 'Let me pick from list of devices on PC'.
11. Uncheck 'Show compatible hardware' checkbox.
12. Scroll down to Chicony manufacturer.
13. Choose the 'Acer Crystal Eye Webcam'.
14. Install even if a question pops up.
YOU ARE DONE AND ENJOY YOUR CHATTING WITH ACER CYRSTAL EYE WEBCAM.
Thanks to DylanBennett for uncovering this odd fix for the HP webcam
Oct 14, 2007 | Computers & Internet
Computers & Internet Logo
98 people viewed this question
Top Muvee Technologies Computers & Internet Experts
David Payne
David Payne
Are you a Muvee Technologies Computer and Internet Expert? Answer questions, earn points and help others
