Question about Minn Kota DeckhandTm 40 Anchor Winch
Rope in minn kota deckhand 40 wont release - Minn Kota DeckhandTm 40 Anchor Winch
5 Suggested Answers
  • 4340 Answers
SOURCE: Have a minn kota riptide sf 101 thrust 62" shaft.
There is more than the shaft, there is the housing and then everything needs to fit and have correct clearances.....I suggest sell the old one and get a 52 inch new one...
Posted on Mar 14, 2011
bonedivers
  • 1140 Answers
SOURCE: What spec battery is the
that depends on the usage you want. any good deep cycle marine battery should do you good. min of 700 cca
Posted on May 20, 2011
SOURCE: my minn kota endura 55
I had this problem with my MinnKota Endura 35. The gear teeth that turn the prop are off center and need to be realigned. You need to take it to a service depot as trying to open the casing yourself may do more damage. Plus when it it put back together you need to ensure that it is water tight again.
Cost me around $85 at the local marine mechanic...
Posted on May 25, 2011
  • 4961 Answers
SOURCE: minn kota repair manual for deckhand 40
Manual:
http://store.minnkotamotors.com/media/document/2377106rg.pdf
Posted on Aug 25, 2012
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    My minn Kota deackhand 35 won't lift a 28lb anchor
    How heavy is the line that is attached to the anchor - you need to add that weight to the amount being lifted as well. Some general things to consider: Are you providing the correct voltage and current? Is the wire supplying the motor large enough - or is it getting hot? Check & clean as needed ALL connections at terminals, relays, etc for corrosion and tightness. Make sure the unit has been serviced and lubricated as required.
    Sep 29, 2015 | Minn Kota Boating
    How do i release 101 fortrex motor from mounting bracket
    There is a pin that goes through the shaft, a small circle clip that holds it in place. Remove the clip and pull out the pin. This may require a hammer and drift as they tend to corrode in the aluminum. don't forget to pull the rope and release the catch.
    Jun 02, 2014 | Minn Kota Maxxum 101/BG/Hand Freshwater...
    Anchor pulls up won't release to go down on either of the two switches
    Im getting power to motor, but can't get it go down. When I hit switch I can hear a clicking sound from the unit
    Nov 05, 2010 | Minn Kota Deckhand Electric Anchor Lifts...
    I have a Minn Kota Deck Hand Ser. No. MK01798492 I can not find a modle # on it. It came on the boat i bought used. it did work now it will not let the ancor down. I took the cover off, found a spring off...
    39 2372700 COIL SPRING ??
    DeckHand 40, 12 Volt, 25 to 40 Pound Capacity, 2377106 - 2004,2005,2006,2007,2008,2009,2010,2011,2012,2013,2014,2015,2016,2017
    DeckHand 40 - parts diagram
    Aug 07, 2017 | Minn Kota Boating
    Minn Kota Deckhand stripped gears
    Hello!
    Here is a schematic for your Deckhand:
    DH40
    The install of the large plastic gear is fairly easy if you are somewhat mechanically inclined (you must be if you posted the question ;)
    Give it a go, last one I did took about 20 mins.
    Mike
    Sep 26, 2009 | Boating
    I HAVE A MINN KOTA DECKHAND 35 THAT WONT WIND UP. IS THERE A GEAR I CAN REPLACE?
    Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
    I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
    Good Luck!
    Jun 09, 2009 | Boating
    Minn Kota DeckhandTm 40 Anchor Winch Logo
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
