Question about Bose Companion II Computer Speakers
Get loud hum from both bose companion II speakers when i disconnect left speaker hum goes away tried most everything else thanks
  • 27,725 Answers
Try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on May 23, 2011
I have a bose companion 3 series ii my base speaker has an broken audio input that i'm trying to fix can anyone help me Please!!!!
Yes you can fix it but need a soldering iron and tin and the part that will change. Get everything in radio shack or similar store. If you don't now how solderin go to this link: http://www.youtube.com/watch?v=Rm28jkKGMz4
Good luck
Dec 15, 2010 | Bose Companion 3 Series II Multimedia...
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
Loud hum when Bose Companion 3 Series II speakers are turned on.
I had the same problem for many months. I asked a sound & video professional and he suggested I move the subwoofer away from any power source. I had the subwoofer next to my UPS. Once separated and moved all wiring away from the power supply (about 12") the low bass hum was practically gone.
Jun 28, 2009 | Bose Companion 3 Series II Multimedia...
Constant hum when the computers are connected
Hums come from several sources. A light dimmer switch on the wall. Speakers too close to a monitor or other electrical device. Try turning off everything in the room or nearby rooms, one at a time while the hum is audible.
Apr 15, 2009 | Bose Companion II Computer Speakers
Loud hum with static when speakers turned on
There is def. a loose connection somewhere in your system. This is a grounding problem within the system if nothing else. Def. a "lazy" connection somewhere.
gurutim
Mar 10, 2009 | Bose Companion 3 Series II Multimedia...
Speakers only play cd's
Please look in your Start Menu, go to Control Panel, then into Sounds, Speech and Audio Devices. See near the left, and select Advanced Volume Control. Turn up the inputs for the other sounds that you want delivered out to those speakers. Later adjust the levels a little higher if at first the mix of the sounds is not quite loud enough from one or several of the sound sources. Also in Control Panel, Sounds, you can mute out or eliminate annoying unwanted system sounds such as sounds for minimize and maximize a computer window, and the click that occurs when the computer does Complete Navigation -which it does a lot. Go into Sounds and Audio Devices, and into the Sounds tab. Select the Windows Program event such as default beep and click pick NONE from the sound chooser scroll bar that is just below. Scroll up to NONE to eliminate that sound. Now your overall sound experience will be more pleasant, without unneeded sounds playing loudly, unexpectedly.
Feb 24, 2009 | Bose Companion 2 Computer Speakers
Bose Companion  II Computer Speakers Logo
386 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
