Question about NComputing L300 Terminal Computer PC Desktop
We are trialling an L300 unit at a fast food type of place, problem is that after a period of inactivity it will log out by itself. I'm aware of the sleep function, which has been disabled, is there something else we're missing? We couldn't find any other relevant settings. The screen will just go blank, and require user input to come back on. When it does, the users have to log on all over again. What are we missing? Thank you!
  • Steve Nordquist
    Steve Nordquist May 23, 2011
    Pretty common to have to log in again, really. That said, look for lock timeout or a backroom terminal profile.
    Sniper:
  • 79 Answers
This could be an issue in group policy. As I'm not directly there to look at the way the network is set up, it could be a number of things. While I don't believe the systems don't run on top of Windows Terminal Services, and considering that it is a fast food joint, it is hard to tell specifically other than that they may have it set up to log off after a certain amount of time of inactivity.
I hope this helps!
Posted on May 23, 2011
I have a Kitchenaid YKHMS147HW microwave that started turning on by itself, and will not shut off unless I unplug the unit. If I put food in to cook, the food starts cooking as soon as I plug the unit in,...
Sounds like stuck relay contacts. Magnetrons need a high voltage source which is controlled by a micro to relay and then from relay to voltage source. Even the turntable works via a relay.
Oct 14, 2013 | Microwave Ovens
I have a General Freezer,Ltd model 16 Upright and it shuts itself off periodically without my being aware . When I see food defrosting , I am able to restart the unit by tapping on the temp control dial...
You need to replace the temperature control, (unless you find a bad wire connection to the temp control first). You can find a control that is close enough at any appliance parts store, bring the old one in for a match up. Make sure it is NOT a 39 degree constant cut in type and you will want a differential of at least 6 or 8 degrees minimum so that it wont "short cycle" which means it would run for a few minutes, shut off for a few then run again before the high side pressure comes down.
Oct 01, 2011 | General Freezers
Dear Technician, While i am typing things, the mouse cursor replaces itself elsewhere and thus my typing shifts to the new place and continues typing from there. I then have to cut the words and...
You are probably hitting the touchpad on your laptop with the heel of your hand while you're typing. This will make the cursor move to some other place. It's not really moving by itself; you just aren't aware you're doing it. I would suggest turning off the touchpad while you're typing, and then turn it back on as needed. Compaq computers usually have a switch on the touchpad bezel to turn it off. Some people also plug in a USB mouse, finding it more convenient and comfortable if they want to move around on the document frequently.
Jun 12, 2011 | Compaq (153515-001) Touch Pad
I do have Toshiba satellite pro L300-299 system unit . but it doesn't work wireless internet please send me appropriate driver for this.
Best place to get drivers for wireless internet for toshiba laptops is the toshiba support website. Visit the toshiba support website and type in your model for drivers and the list of all drives available for your unit will be displayed. You can simply get the driver for your wireless from there.
Hope this solution has been helpful?
May 18, 2011 | Toshiba Satellite Pro L300 Notebook
How to use fingerprint,scaaner and fargo print with terminal of pc,if not support add detial.thank
Simply install the driver for the scanner and printer on the HOST system. Plug in your peripherals and when the user on the L300 logs in they should see the printer. The problem with the fingerprint scanner is depending on the make/model, it may not work with the NComputing device. The only way it will have a chance of working is to make sure the device has a live session, sitting at a logon prompt for the desktop. The L300 by itself won't know what to do with the fingerprint scanner. It needs a session to the host to marry up the driver with the peripheral. Also make sure you have the latest vSpace software as NComputing has implemented a new USB architecture for larger USB peripheral support.
Dec 06, 2010 | NComputing L300 Terminal Computer PC...
Periodically the page on screen goes blank
Windows inactivity for screen saver is set. If you want it to deactivate.
On Windows desktop screen, right click mouse a pop up box will show. Select "properties" or "personalize", go to screen saver. Uncheck the box with " on resume, display log on screen". And on screen saver box select NONE this will unhighlighted the inactivity time and the logon screen. Hit apply and then ok button.
This will deactivate the screen saver.
Mar 31, 2009 | Acer Aspire 5500 5570-2609 Laptop
NComputing L300 Terminal Computer PC Desktop Logo
168 people viewed this question
Top NComputing Computers & Internet Experts
Tom Chichester
Dan Shibata
Dan Shibata
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
