Question about GE 24 in. Profile PDW7880G Built-in Dishwasher
Dirty water not draining from the bottom. - GE 24 in. Profile PDW7880G Built-in Dishwasher
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Posted on May 23, 2011
Dishwasher has water in the bottom
check and be sure you don't have something stuck in the water pump for the drain or else the pump maybe bad and needs replacement. In addition, be sure the pump belt or motor is driving the pump.
Dec 26, 2015 | Frigidaire Dishwashers
Large dark brown spots appearing after washing
Normally a washer does not cause a staining problem, but If something inside the washer has rusted, it could. I would check your water tank. Drain water from the drain cock at the bottom of the tank, and see how dirty it is. If it is dirty, you need to drain the water until it is almost clear.
Aug 13, 2015 | Frigidaire ATF6000ES Front Load Washer
Electrolux dishwasher overflows
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 09, 2012 | Dishwashers
My Frigidaire dishwasher has dirty water.standing in bottom. Dishes are not clean
Aug 08, 2012 | Dishwashers
Water did not drain from the bottom
Hello Cheryl, There are a couple of possibilities. When the dishwasher drains the dirty water it is a time based function. This leads me to believe it is a blockage or partial blockage in the drain hose.
Here is an example. (If your dishwasher drains into your garbage disposal) washing dishes you put scraps into the disposal and forget to turn it on after you are done. The disposal is filled with scraps this restricts the flow of dirty waterfrom the dishwasher. If the flow is restricted less water is being drained per second from the dishwasher. This is why the dishes still looked clean and there was still water in the bottom of the dishwasher.
(if your dishwasher drains into a drain pipe) there is blockage or partial blockagein the dishwasher drain hose. if the sink drains slowly the blockage is in the main line
Hope this helps
Joe Connolly
Nov 02, 2011 | Frigidaire Dishwashers
Bosch dishwasher model #shu33A
your dirty water backed up into the washer (which it shouldn't do) and probably clogged something in there,..i would recommend getting it flushed out somehow, not sure how,.....next time, your washer drain hose should go up under the sink as high as possible and then back down to drain,....this settup makes it hard for drain water to go back into washer,....it's instructed in any dishwasher manual
Mar 06, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Water in bottom of dishwasher
Hi You have a drain problem, Your house drain may be restricted the dish washer pumps out with more pressure then the water just falling down your sink.I would snake it or have a plumber clean out that drain...let me know if this helps krazytech
Aug 24, 2007 | Bosch 24 in. SGS43C12 Classixx...
GE 24 in. Profile PDW7880G Built-in Dishwasher Logo
123 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
