Problem with 6 pack cd unit ejecting from housing, when eject button isd pressed.
    Scholar:
  • 137 Answers
The button could be stuck in. Clean around it with alcohol and a Q-Tip and try the get a little behind the button. Then, keep pushing the button till the alcohol dries. Let me know if that works.
Posted on May 23, 2011
Loaded a cd to upgrade firmware, firmware would not load. eject button would not eject. read manual, says to push eject at the same time you plug in the electric cord,still would not eject. Any...
Please try in this way.
Disconnect power.
Connect power back, and keep REPEATEDLY pressing the eject button while you connect. If still no ject press power on button while you keep hitting the ehect button. You need to press eject on the unit, do not use the remote.
If that does not work, then the unit must be taken apart.
Dec 09, 2010 | Cameras
6 CD cartridge will not eject
If you are getting power to the unit and you hear it clicking and making a sound when you hit the eject button, the this means that a CD is jammed in the track and while it was changing it got stuck and now causes you to see an ERROR message.
What you do is while hitting the eject button, wiggle the CD MAGAZINE up and down and side ways. This will cause the CD to fall into place and your magazine will pop out.
KennyV
Jun 03, 2010 | 1997 Lincoln Continental
Unit will not eject CD will play fine but won't eject
Once it gets too hot in your car, a stereo or the cd in it can warp.If you press the eject button and the music keeps playing the unit has an electrical problem you can't fix. If you press eject and the disc sounds, or looks like it wants to come out, you might have a warped disc. As a last resort, pull out the stereo and leave it connected. Then try to eject it. If it ejects, then the stereo could be binding.
Apr 12, 2010 | Clarion XMD3
Open/close doesn't work
When you press Eject CD button, do you see CD display blinks as if its preparing to be ejected? If its true then eject switch is working and cd mechanism is stuck, requires service. Also check loading belt in mechanism.
And if unit shows no response on pressing CD Eject button then switch is bad, replace it.
Jun 30, 2009 | Aiwa NSX-A115 Shelf System
We just bought a new cd and it's stuck in the car stereo
If you like you can read throuh the manual for further help if this fails,
at this address :
http://www.cartoys.com/cartoy/pdfs/kdc-122s_manual.pdf
However the units have a forcible eject mode, im raking my brain for it but i think 90%  sure its as follows...
Try pressing and holding eject and the power button at the same time for about three to five seconds, the machine shoudl buzz louder then normal an do a full eject cycle for about 2 seconds,
If worse comes to worse you can take off the outer casing  four screws (if not under warranty) and carefully lift the disc slightly and slide it out. Take care to to force anything as you can damage/scratch the unit.
Another option is that you ring the Kenwwod customer service number and ask how them what the button press combination is for forcibly ejecting cds from the unit. you may need to ask for someone in repairs there to get a knowlegable answer,
Hope this helps
Cheers
STeve
Feb 15, 2009 | Kenwood KDC-122 CD Player
CD Eject
Press the Jensen logo button. The panel will drop down. A button inside will eject the CD.
May 26, 2008 | Jensen - CD4010K
Alpine CDM-9803 Cd Player
You need to visit Alpines' site to download the owner's manual for your unit. In the mean time here is some info from the troubleshooting guide for your error code.
• Mechanism error.
1. Press the "eject" button and eject the CD.
If not ejecting, consult your Alpine dealer.
2. When the error indication remains after ejecting,
press the "eject" button again.
If the error indication still does not turn off after
pressing the "eject" button for a few times, consult your
Alpine dealer.
Note
When the "- - - E" is displayed:
In case that the disc cannot be ejected by pressing the "eject"
button, press the RESET switch (refer to page 4) and
Good luck.
Feb 08, 2008 | Alpine CDM-9803 CD Player
Cd ejection
Look for a tiny, recessed Reset button on the front of the unit with the face removed. Press this button with a pen tip; it should spit out the CD and work correctly afterwards. This will also erase your station presets and audio settings.
Mar 13, 2007 | JVC KD-SX770 CD Player
Cd ejection
Reset this unit by pressing and holding the power/ATT and SEL buttons at the same time for several seconds.
Mar 13, 2007 | JVC KD-S680 CD Player
Open Questions:
 Grubhead
Grubhead
