Machine doesn't drain & spin, it says "OE" or sometimes some other message "E something"
  • Washing Mach... Master
  • 43,501 Answers
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
Posted on May 23, 2011
Washer broke
that is just a dampening ring. Does nothing with the funtioning of the machine. if the machine stays full of water and doesnt drain
May 27, 2013 | Washing Machines
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Washer doesn't spin out sometimes
you say it drain, but sometimes it won't spin,this could be your filter if it is blocked these new machines can sence it and won't let the machine spin easyest thing check your filter,you never know might be that simple
May 07, 2012 | Washing Machines
I have LG WD 85260NP wash machine and my problem is OE error where as water drains out completely but pump remains run and OE error shows,it means doesn't pass to rinse/spin operation,any body can help...
Although you say 'water drains out completely' many machines will not even go to rinse or spin or release the door lock if there is any water still left inside ;-0(
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter- so many 'faults' are caused by blocked filters.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 09, 2011 | Washing Machines
THe machine won't rinse. Displaying a "OE" symbol
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Jul 26, 2011 | LG Washing Machines
"OE' flashing in top-right hand
On your washer 'OE' stands for 'outlet error' (draining).
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
John C
Jul 03, 2011 | Kenmore Washing Machines
Spins but laundry is still dripping wet
This happens to me sometimes. My washing machine doesn't drain right into the drain, I have a pipe coming out of the back of the machine that I have to hook into the kitchen sink myself to let the water drain out. My washing machine was still full and I realized that it was because my sink was a little blocked and so it was draining too slowly and leaving water in the machine. If there was too much water, it would sometimes help to put the machine on again or put it on a drain cycle. My machine doesn't have a spin cycle so it will just give your clothes an extra spin so I couldn't do that and my clothes would still come out dripping wet. I advise that you give them another spin before you take them out if possible! xxThe fact that the washing machine is spinning but not drying clothes shows that there is some problem with the outlet of water. The water outlet is blocked. You can check for the blockage yourself. Normally threads or other waste accumulate in the water outlet, and if possible you can remove it yourself. Otherwise call your washing machine's customer services center and ask them to send a repair man
May 01, 2011 | Smeg Washing Machines
I have the washer described above. We are getting the OE error message. The machine will not drain water or spin.
Unfortunately there is no 'washer described above' so I am guessing that it might be an LG and 'OE' is 'drain error'.
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
Apr 17, 2011 | Washing Machines
"OE" error. Filter cleaned but makes terrible
You still have something caught in the drain line on the machine. Check the filter again and the lines coming from the tub to the pump, and from the pump to the waste line. Here is a link to LG's document on the "OE" error.
Jan 10, 2011 | LG WM2277H Front Load Washer
My washer machine keeps displaying OE. We have checked all the hoses, and everything seems fine. Will not empty water or finish cycle
Error Message : the OE is (outlet error).
1) If OE error occurs, clean & empty the filter.
2) If this doesn't solve the problem, and it won't drain, then provided that you can hear the pump spinning (the normal whirring the machine makes that should be accompanied by the water going down the drain) then the hose pipe leading to the pump is probably blocked.
I'm sure a lot of dodgy service people might just charge you for a new pump & labor, but if you can hear the pump spinning then you just need to remove the blockage.
Aug 12, 2010 | LG WM-1832C Front Load Washer
Washing Machines Logo
288 people viewed this question
Top Washing Machines Experts
