Question about Dryers
Our dryer suddenly has no heat - it is electric and is tumbling but no heat at all. Please help!
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on May 23, 2011
Dryer suddenly does not heat and dry clothes.
sounds like a tub wheel that the drum runs on may be bad ,youll have to take the front off and look,check for a burnt wire at the heating element or the heating element itself
Jan 15, 2013 | Kenmore Dryers
Where is the belt located?? This maytag legacy elec dryer is 4 yrs old. over the last few mths it has made louder sqeaky noises but now all of a sudden it stopped tumbling!! It still heats up like it's...
it is inside the dryer, you will need to disassemble the dryer here is a website that may help:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
diagram of belt routing:
http://www.applianceaid.com/images/belt-config.JPG
Good Luck Tim
Feb 09, 2011 | Maytag MDE308DAYW Electric Dryer
I have had a stackable hi efficent 7.3 cap. kenmore dryer for 2 months. Suddenly it doesn't heat. No sign of vent problems or electrical but on all cycles both the dry & cooling light up at the top...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 22, 2010 | Kenmore Dryers
Dryer was working fine. Still runs, tumbles, etc, but all of a sudden, no heat. Only 2 yrs old. Cleaned vent and lint filter. Is it likely a hi limit switch (if so, can it be reset or does it need to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 13, 2010 | Samsung DV218AEW Electric Dryer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Dryer works and tumbles but does not heat
First, you must remove the front panel. Open the door and remove 2 screws on each side of the opening; 2 in the door hinges and 2 directly opposite from them. Then close and latch the door and pull on the top corners of the panel and it pivots down, then lift off the bottom brackets. Then start the dryer (making sure it's not set for air fluff or no heat) and watch the ignitor to the left side of the burner tube. Report back if it glows or not. Also you might include the first two numbers of the serial number so I can make sure we're talking about the same series machine.
Jan 12, 2009 | Frigidaire GLEQ642A Electric Dryer
Maytag dryer sde305day won't heat
you may need to replace the heating coil from the back... i have the unit pulled apart as we speak :).... also make sure to check the connections on the back switch to the heat selector! if you need pictures i would be more than happy to get them for you please contact me a Admin ........ at .......WhyPayForHelp .... .... dot org ... the e-mail is "encrypted but you should be able to figure it out :)
~Lee
Mar 20, 2008 | Maytag HYE3657A Electric Dryer
Defy Tumble dryer not heating
Is this an electric dryer? If so, the most common problem would be a burned-out heating element. There could also be a defective temperature sensor inside. This will need to be evaluated by a qualified appliance repair technician to find the exact cause.
Jan 18, 2008 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
