Question about Briggs & Stratton Tools & Hardware - Others
31HP on a stump grinder. Runs good than dies as if it is out of gas. Has all filters changed, valves set, new electric fuel pump. Fuel tank drained and washed out. Sometimes runs for hours, sometimes just a few minutes. Gas is good. Coil, and spark are good. Every B&S dealer has looked at it. Everyone thinks they fix but doesn't. Engine has appx 250 hrs on it. 120 PSI one piston, a little more on the other. It must be working on stumps to fail which is why no one can see the problem. When it quits, it will restart and run at idle, but not a working speeds. Next day it may run for hours, or just minutes. It is costing me business, and making me look foolish to my customers. Thanks, David 806-441-9472
  • davgendc May 26, 2011
    YOUR SUGGESTIONS DID NOT FIX MY MACHINE. ANY OTHER SUGGESTIONS??
  • davgendc May 27, 2011
    I have spent over $750 trying to fix this engine, It is a Vanguard. I will change out the coils and let you know.
    Thanks
  • 43,501 Answers
Does this have the electronic ignition module, or the electronic coils???
My thought would be that you have the control module unit and there is a crazy circuit board problem in that....Don't think you have a fuel problem, it would be more predictable....what you have is an electronic problem...those darn electronic coils can drive ya nuts also...
heatman101
Posted on May 26, 2011
  • D. Floyd Kolb
    D. Floyd Kolb May 27, 2011
    Those types of problems can be very frustrating and expensive....a new engine looks to be somewhere around $2500.00 so to this point you are well under a new engine...
  • 710 Answers
David,
Has anyone checked the valve clearance on the engine?
Also, sometimes simple things will make the engine perform intermittently. Try running it without the gas cap on when it has died. It could be a clogged gas cap so the engine is not ventilating.
Handie Andie
Posted on May 23, 2011
  • Handie Andie
    Handie Andie May 26, 2011
    Yes, If there is nothing wrong with the engine, the next step would be to look at the cutter you're using. How often do you sharpen or change the teeth? Are you using carbide teeth, etc.
    I'd like to suggest checking out these two websites. The first is info on a good cutting wheel and the second is the US dealer if you're in the US and are interested: >>>>http://www.multi-tip.com.au/ <<<<
    >>>>http://www.alpinemagnum.com/multi-tip.ht... <<<<
    Please copy and paste these web addresses into your browser to view.
    Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
    Handie Andie
Fuel Open Question 2000 Camaro fuel pump/ fuel
is the gas tank vent recirculate hose clogged?
bad gas cap?
Aug 17, 2013 | 2000 Chevrolet Camaro
2007 NISSAN QUEST It starts and then dies within 2-3 seconds.
hello good day, reverse your air filter, make the bottom to top,, if is not work change the high tension wires
Mar 07, 2013 | 2007 Nissan Quest 3.5 Minivan
When it runs fir a while it dies
Car runs then dies, left set it will run again and then die.
sounds like a fuel starvation.
I had similar problem on an old sunbeam. after doing
everything else, turned out to be paint inside gas tank
was flaking off and plugging up the hole in the tank bottom
where the gas line attached.
Had a similar problem on a Datsun. Turned out a small piece
of chewing gum wrapper foil got inside the gas tank and formed
itself into a perfect fitting cover for the fuel pump impeller intake.
This was so long ago it was the first in-tank fuel pump I had seen.
Note neither of these situations would have been fixed by
replacing the in line fuel filter.
Good Luck
May 02, 2011 | 1997 Chevrolet S-10 Pickup
Air in fuel line. changed all the filters. put a new in-line filter before the fuel pump. engine runs for a few miles and then dies. i have to bleed the air out of the fuel pump and then it will start and...
I'm a little confused. You changed all the fuel filters? How many do you have? If you have a late model vehicle, then your fuel pump is in the fuel tank. How did you put an in line filter before the pump. Is your vehicle gas or diesel?
Jan 21, 2011 | Ford F-350 Cars & Trucks
1990 CUTLASS CIERA,DIED ONE DAY,CHANGED FUEL PUMP,FUEL FILTER,STARTED,RAN,IDLED,BUT WHEN YOU STEP ON THE GAS HARD IT JUST DIES.WILL START BACK UP,AND THEN THE SAME THING ,STEP DOWN,BOGS THEN DIES,NOW WONT...
sometimes the tank decomposes from the inside flaking off and clogging filters, pumps, etc. always a good idea to completly remove tank and flush to check for same when changing the fuel pump. if that's your problem, you will need a new gas tank
Sep 04, 2010 | 1994 Oldsmobile Cutlass Ciera
Stalls out like its not getting gas
the valve that you are depressing is not an air bleeder it is a shredder valve used to check fuel pressure on, you most likely need a new fuel pump
May 12, 2009 | 2001 Dodge Ram 2500 Truck
Tools & Hardware - Others Logo
49 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Bill Boyd
Daryl Gleaton
obsteiner
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
