Question about Dryers
I have a simpson 39P400 dryer. the drum turns as it should but it only blows cold air. have had the heater element block checked and ok. is ther a cut out relay or ?? that i can replace.
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on May 23, 2011
My candy tumble dryer gov218-80 blows just cold
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or
overheating.
The heating elements are located inside the heater ducts. If you think a heating element is faulty, test it with avolt-ohm-multimeter (VOM)set to the RX1 scale. Disconnect the leads from the power terminals and clip one probe of the VOM to each terminal. The meter should read about 12 ohms. If the reading is higher ohms, the heater is faulty and should be replaced. Replace a faulty heater with a new one of the same type and electrical rating. A heater connected to a 115-volt line usually has an 8.4-ohm resistance; a heater connected to a 220-volt line usually has 11 ohms resistance.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
OR you may have a broken centrifugal switch in the motor because this switch activates the motor and the heater as well. supposed to be if the motor does not run , the heater should not heat in order not to create fire but you said that even the motor is not running, the heater is still heating, then there could be a problem with the motor centrifugal switch that is connected to this interlock switch that should trigger the heater.
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Oct 04, 2014 | Dryers
Simpson Dryer only blows cold air
It's either the fuse, heating element, thermal cut-off or thermostat
May 20, 2012 | Washing Machines
It blows air but it is cold it does not get hot had thermail limi
Depending on the type and make or model of dryer check drum turns,filters are not blocked or condenser is not blocked.then if all ok it could be the safety thermostats or the heating element.
Hope this helps.
May 10, 2010 | Dryers
Ok got a GE DVL223EB1WW Insufficent Heat
Yes think so , what should happen is element heats up controlled by fan blowing cold air across it this then heats to whatever thermostat is set to switch at, which in turn controls heat level..Air is then exausted via hose to waste unless its a condenser drier which then turns the steam back to water / which is collected in a waste condesate drum..hope this is helpful...
Nov 19, 2009 | GE DVL223EBWW Electric Dryer
My Maytag Performa dryer is blowing out cold air. How can I fix it myself?
remove frt cvr,then top then remove drum belt and drum, check for open heater element, defective thermal fuse,hi-limit switch, open neutral to element if it uses the neutral connection
Oct 18, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
Will not heat, it only blow cold air, how do I change the heating element inside the unit
If the drum turns, it could be as simple as a blown fuse or breaker. The dryer has doule breaker or fuses at fuse panel. If the one blows, the heater will not work but motor willturn as motor rums on 110volts. It may be cut out thermostat or could be element, but check the power to the plug of dryer out let and make sure you getting 110 volts on from neutral to both sides and 220 between two live lines.
Apr 27, 2009 | Dryers
Simpson Clothes Dryer wont start without assistance
your dryer has a start assist compressor go to this site to see it and that could very well be the problem. www.repairclinic.com/SSPartDetail.aspx?s=t-39p400-%3d%3db166i938994%PartID=938994
Jan 21, 2009 | Whirlpool GEW9250 Electric Dryer
Maytag dryer MDE6000 is only blowing cold air.
Electric dryers run on 220 volt, it is usually a double breaker at your main panel, however, depending on the electrician and how old the wiring is you might have two breakers, so start there first. If not, there are several parts to this dryer. It could be an element, a thermal fuse, high limit thermostat, or as simple as a burnt wire. Most important please turn off power before working on this.
The other thing that most people forget to check is the outlet pipe or vent pipe. If they get blocked, when the heat turns on, and it is blocked, the dryer will detect it and immediately turn off the heat but the drum will still turn. Bed Bath and Beyond has a dryer vent clean out kit that hooks to a shop vac.
Jan 09, 2009 | Maytag MDE6000 Dryer
The dryer only blow out cold air.
When I turn the dryer on, only cold air blows out. There's no heat. I cleaned out the vents? What do you think is my problem> Thank you very much. K
Oct 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
192 people viewed this question
Top Dryers Experts
