Question about Nightforce Optics
I have a nightforce scope and i'm having trouble shooting a constant group. It seems to have a flyer per each 5 shots. Is this a possible problem with the scope, as the gun is new. The shots are from a benchrest and sandbags.
    Scholar:
  • 137 Answers
It could also be the ammunition. If its federal or remmington ammo it probally isnt but if its generic ammo it could be. it is unlikely that the scope would be off, then back on again. I am sure you made sure the two mounting screws are tight and that there was nothing in the way when you put it on like a small piece of metal from when the scope was made that might have gotten pinched in the mounting clamps. Also, are the screws tight for sighting in the scope?
Posted on May 23, 2011
Throwing one of three shots
Not enough information. Is it consistent? Are you using the same ammunition? Distance? Rifle? Iron sights or Scope? etc.
If you are using a scope, it is possible that the scope is loose. If you are firing off-hand, it is probably you. If you are shooting at 1000 yards, you group is actually pretty good.
If you are benchresting your rifle, make sure you are not resting the rifle on the barrel, this can throw shots all over the place.
Apr 09, 2014 | Optics
My rifle is out, 3"
The gun can be getting hot during your sighting in session. Heat from the reviver can throw your setting off, then as you adjust things get worse. Start and loosen the scope rings one at the time. Front first, and re-tighten, then the rear. Fire 2 shot groups, letting the gun cool some in-between each group. This way you can figure out if it is the scope loosing it's center or the mounts getting in a bind due to heat and twisting the tube. After each adjustment tap on the scope to set the cross hairs, again this will give you feed back, if the scope can hold it's center. Hope this helps Fix Ya up.
May 18, 2011 | Optics
How do you make adjustments, towards the shot or towards center of the target?
You move the cross hairs to the shot. Set up your gun on a bench and start by firing at a target out at about 15 yards. Once you are "on paper" set your cross hairs on the center and fire a 3 shot group Adjust the scope to the group. if the group is down 3 inch and left 4 inch. Adjust your scope accordingly. Then Fire another 3 shot group, until you are shooting center. Every time you adjust your scope tap the barrel of the scope with a screwdriver handle to keep the cross hairs from sticking. Once on at 15 yards move out to your max range and adjust to that.
Mar 19, 2011 | Brunton 2x20mm NRA Sports Optics Rifle...
I have the thompson center muzzleloader trumiph.Having trouble sighting it in,shooting thompson tc bullets 250grain shockwave. with 2 triple 7 pellets and triple 7 209 primer. shoot and hit bulleye...
One thing about muzzle loaders, you should wipe or clean the bore after each shot. You need to find a method that works for you. I have an old CVA and I have to wipe the bore after each shot to keep it accurate, if shooting for fun I do not. But I would use my rod and with one patch in and out just to keep the fowling down.
Lets think of it this way. Even with the new powers they tend to build up. Now this build up causes each shot to have a different pressure and then each shot will run down the bore different. Hence one shot here another there.
Then there is the primer itself, The 209 primer has a very hot flame and can cause a bit of fouling.
See this link. Primers cause accuracy problems. It may help you understand what is going on. But the easy fix is to learn; wipe the bore after each shot. Use the same method to load powder, press the bullet in the bore, seat the bullet on the powder pellets, fire the gun, wipe the bore, start over doing the same steps, same motion, same pressure each time.
Jan 09, 2011 | Thomson Thompson Center Muzzleloader Rifle...
I have a bigcat and it will not shoot a gooup
I have one of the BIG CAT rifles and can shoot under 1" groups. First Check the gun and be sure it is tight in the stock. I had to remove the front screws and pot nylon washers under them to get the stock tight!
Second. I could shoot decent groups and the they would move! I replaced the scope mount with a better quality better fitting scope mount. Be sure it has the stop pin that fits in the hole in the top of the rifle or they will move to the back and never be stable.
Third. I replaced the Gamo scope with a Leupold 3X9 varix 2. I am not sure about the Gamo scope but while I was mounting a scope I decided to try the Leupold.
I have shot some 5 shot groups from a good rest that was less than 1/2". The factory scope mounts looked like a bad fit on the groves of the rifle and looked canted.
The best pellets I found are the PREMIER HOLLOW POINT and some of the worse were the GAMO FLATPOINT!
Dec 28, 2010 | Caliber Gamo USA Hunter Elite .177 Air...
I have a Beeman air rifile that I think is the greatest thing since sliced bread. I has taken down ground hogs at 50 yards. The rifle has a 4-14x56 Accushot scope mounted on it. When the rfile is working...
Unfortunately air rifles are hard on scopes due to the recoil...Suggest replacing the scope with something more of a brand model , like Bushnell or something like that..
Nov 07, 2010 | Beeman Optics
I can shoot my centerpoint scope on my .22 and it
When adjusting a scope just move a few clicks at the time, after every few clicks tap the scope with a screw driver handle. Fire 2 rounds for group tap and fire the third round it should be in line with the 2. Keep that up till on target. Let the gun sit till cold and re-fire for grouping, 2 rounds, wait then the third. To keep shooting round after round can get the reciver warm enough to wedge the scope in its bases, causing your problem.
Oct 13, 2009 | Optics
I have a Bushnell Elite 4200 6x24x40 rifle scope 42-6242M
First is to try for a group, do not adjust the scope in any way. Shoot 4 rounds with out adjusting the scope. The gun should settle down and start to group. If you can not get a group in 6 rounds go clean that gun & check your ammo. Start over. If she does not group, its the gun not the scope. Once it starts to group move the cross hairs in the opp direction small clicks and "TAP' the scope after each adjustment. Shoot for a group each time 2 rounds should group. Get a target that has a grid to help get on faster.
Sep 20, 2009 | Bushnell Elite 4200 6-24x40 Riflescope...
Sirs Shooting 25-06 dead on @ 100 yds., shot @ 200 yds hit 12" high, shoot again and the second bullet hit right at the first hole. Shooting H&R Handy Rifle, Hornady 117 gr. bullets Please advise to what...
sounds like it could be the scope more than any thing but shoot at 100 yd 5 shot group and see if it groups if if shots dance around on target make shure your mounts are tight there is time that companys send screws for the mounts that are to long for the holes that are taped in the gun the mount mite feel tight but could have play yet witch make your gun not shoot well you could also try setting the scope on 4 power shoot a shot at 50 yards then crank it up to 9 power shoot a shot if bullet impact moves it is the scope hope i helped ya out and good luck
Feb 24, 2009 | Optics
I have a Bushnell Sprotiew 4x, 15mm scope mounted on a Mossburg .22 rifle. My shots are hitting left six inches and low. Can you please tell me how to adjust this scope? Thank you.
Keep in mind Diane this is for a set distance. if you are taking a shot at a target further than your are set for (ie a target you wont get 3 shots @) remember how the bullet is travelling as it goes down range
one idea would be to set your rifle up down range and zero it in on a target (preferably paper) now adjust 1 MOA (try and have target @ 100 yards and 200 yards)
see how far the bullet moves for each moa adjustment. then check it against the next range.
this should remain constant @ a set number of inches per 100 yards.
so if you zero in @ 100 yards and then move 1 moa any direction and it adjusts (lets say and hope it is 1.047 inches") then you do the same for 200 yards. it should be twice as much movement. ie 2.094"
once you know what 1 moa represents on your scope you can adjust alot more accurately.
REMEBER the total inches of movement / adjustment per MOA is directly related to range (a precise range helps in shooting) so if your squirrel is 150 yards and your first shot is off 9" to adjust you divide 9" by the inches per moa so 1.5 (150 yards /100) X (Inches per 100 yards per moa you measured hopefully 1.047") its 9" divided by 2x1.047 = 9" / 2.094 = 4.29799
this number needs to be rounded to the nearest click on your scope (most are 1/4 MOA scopes and you can tell by looking at how many clicks/lines are inbewteen each large number on your windage and elevation dials
so to turn this into an adjustment we round 4.29799 to 4.25 which is 4.25 MOA or 17 clicks on a 1/4 min scope.
GL and any questions just post and ill help
not please rate this as fixya :)
Note i can provide EXACT information that would allow you to determine range, and windage and elevation adjustments by looking through scope and estimating range
then factoring in weather variables. NOTE you hafta enjoy math or just want to know how to shoot really well. :)
Dec 22, 2008 | Barska Optics Barska 10-40x50 Ao Varmint...
Optics Logo
274 people viewed this question
Top Nightforce Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Nightforce Optic Expert? Answer questions, earn points and help others
