Question about Royal Sovereign ARP2412 Air Conditioner
I purchased the ARP 2412 Portable Air Conditioner unit, and I find myself very unsatisfied, cause no matter what function mode I select to cool the area, after only 30 minutes aprox, it turns off... (in all COOL, AUTO, DRY... etc.) I understand this function allows the saving of energy, but I understood it was an automatic function, and I would like to know if there's a way to make it work NON STOP... as it should. THANX, I would really appreciate your response.
  • 148 Answers
SOURCE: Royal Sovereign not keeping the room cool.
electronics give off alot of heat you need larger unit
Posted on May 19, 2009
  • 306 Answers
SOURCE: air conditioner turned itself on to 22 degrees.
If it got to 22 degrees the Ac unit should have self destructed. What brand and model is that unit?
I think I would love to have one here in Georgia.
Posted on Aug 22, 2009
  • 615 Answers
SOURCE: A red light came on and the unit turned off
see if you can push water from the other end to see if you have something that stuck inside
Posted on Sep 08, 2009
  • 24 Answers
SOURCE: I have an air conditioner model ARP 1000 ES. It
it is possible the fuse is blown inside of furnace or air handler it should be a 3 or 5 amp car fuse also check the fault code inside of door panel there is a list of fault codes listed
Posted on Oct 01, 2009
  • 15 Answers
SOURCE: I have a portable air conditioning unit...now it
its out of gas bring it two ur nearest refrigeration company
Posted on Feb 24, 2010
Ok So We Bought This. But We Have A Problem Does It Take Water Or Not? Thats What I Need To Know! Please Help!
The DeLonghi PACA120E Portable Air Conditioner quickly cools rooms up to 400 square feet and comes equipped with several functions that make operation easy and low maintenance. Its 3 operating modes are supplemented with no-drip technology, an adjustable thermostat, 24-hour timer, and much more. This unit truly takes the work out of cooling medium- to large-sized spaces. Multiple Modes and Functions The DeLonghi A120E-also known as the Delonghi Pinguino PAC A120E-offers 3 operating modes and 3 additional operating functions that make this model versatile and energy efficient. Cool Mode: 12,000 BTUs of cooling power help cool large rooms, offices, or basements. Dry Mode: Reduce room humidity by removing excess moisture from the air. Fan Mode: Circulate air to keep your room comfortable without using a lot of energy. Low, medium, high, and an auto-speed are all included (auto speed selects a fan speed for you). Smart Function: Your AC uses Cool and Fan mode based on ambient room temperature. This function will also select your fan speed and keeps your room comfortable without wasting energy. Sleep Function: Using a low fan speed, the AC gradually reduces operation so your room remains comfortable but the AC runs more quietly and efficiently while you sleep. Boost Function: This function is ideal for the summer months and uses the maximum fan speed to rapidly reduce your room temperature. Useful Features Using DeLonghi's patented no-drip technology, this unit is "dripless" under normal conditions, meaning the AC will discharge all of the moisture collected from the air-so you typically won't have to worry about draining the water. When dehumidifying a lot of moisture in Dry mode, excess water may collect in the internal collection tank. Once the tank is full, the air conditioner will automatically turn off to avoid overflow damage. You can also use the included continuous drain hose as a no-fuss way to eliminate excess water as needed. An adjustable thermostat provides additional convenience by allowing you to set your room temperature. The DeLonghi portable AC will cycle on and off to eliminate over-cooling and maintain the set temperature. Additional Features Washable Air Filter: A washable air filter helps remove allergens and other particles from incoming air and saves you money on replacement filters. Quiet Operation: High efficiency compressor and components result in quiet performance. Electronic Controls: The LCD screen displays the timer and temperature settings, while intuitive indicator lights accompany each operating mode. 24-Hour Timer: This feature lets you program your AC to turn on or off up to 24 hours in advance, so it only runs when needed. Window Bracket: Double window bracket is included with purchase for flexible installation. Self-Diagnosis System: The unit includes a self-diagnostic maintenance system that identifies malfunctions should they occur. Remote Control: Use the full-featured remote control to change modes, set the timer, and select a fan speed up to 23 feet away from the receiver (on the front of the unit). Portability: Easy-roll casters and dual carrying handles make it simple to move this model from space to space.
Aug 06, 2012 | DeLonghi PAC A120E 12000 BTU Portable Air...
Window kit for RS ARP-9411
I assume you are looking for the window kit for ARP-9411 Portable Air Conditioner. If so, contact
Royal Sovereign Customer Support 1-800-397-1025 .
Hope this helps you & thanks for choosing FixYa.
Aug 19, 2011 | Royal Sovereign ARP-1000EX Portable Air...
The unit only blows out hot air. It doesn't switch to ac mode @ all. What is the problem?
Make sure the control or the remote has actually changed the mode setting to cool function. Try new batteries if necessary or see if the main unit has an overide or manual control to select cooling only. It may be that the compressor is not running at all. The hot air you are feeling may be the room temperature air... Can you hear if the compressor is running or is it just the fan ??
If it is still stuck on heat mode, the reversing valve may be jammed.
Jul 03, 2011 | Royal Sovereign ARP-3012 Air Conditioner
Compressor wont start..blows hot air
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 27, 2010 | LG LP1200DXR Portable Air Conditioner
Sep 08, 2009 | Royal Sovereign ARP-1008 Portable Air...
Air conditioner turned itself on to 22 degrees.
Aug 21, 2009 | Royal Sovereign ARP-4012 Portable Air...
May 19, 2009 | Royal Sovereign ARP-4009 Portable Air...
Royal Sovereign ARP2412 Air Conditioner Logo
43 people viewed this question
Top Royal Sovereign Heating & Cooling Experts
jdthefixer
Bill Long
Are you a Royal Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
