Question about HP 4570C Flatbed Scanner
Scanning bar light
When I turn off my HP scanjet 4570 the scanning bar light does not turn off. The only way I can get the light to turn off is to unplug the machine from the power source. Any suggestions as to why this is happening and how can I fix this? Thanks
  • taylor10216 Aug 16, 2008
    The light that doesn't go off is the scanner lamp underneath the glass platten. The lamp stays on after the scanner has been powered off.
  • 876 Answers
Do you mean the green power light? I have the same brand and a similar scanner, and the light does always stay on. I think it is a normal function of the scanner. It may not be a good idea to unplug the scanner. I am going to be a bit more research so that we can both be reassured that this is normal.
I'll get back to you.
Posted on Aug 15, 2008
  • Gayle Ashbach
    Gayle Ashbach Aug 15, 2008
    On your front panel do you have a utton that looks like an incomplete circle with a straight line running from the center through the top? Sort of like a clock? This is a power save button and according to what I am reading you can push it to turn off the scanner lamp/the LEDs and the LCD. I hope this helps. It is worth a try. I am going to try it on mine.
    Please let me know and rate this solution thank you so much for using FIXYA
  • Gayle Ashbach
    Gayle Ashbach Aug 16, 2008
    did you try the solution above to turn off the scanner lamp?
Scanjet 4600 is stuck halfway through scan
About 2,970 results (0.68 seconds) Search Results
    HP Scanjet Scanners - Scanning Stops at the Preview ...
    Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
    Scan stalls half way through and never finishes - HP ... > ... > Scanning / Faxing
    Jan 11, 2011 - 7 posts
    More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet ‎4600
    issue Scanjet 5590 windows 7 Business 64 bits - stop during > ... > Scanning / Faxing
    Jan 19, 2010 - 10 posts
Feb 05, 2016 | Office Equipment & Supplies
Twain driver for hp scanjet G2710
I just wonder how to choose the right twain scanning API for the scanner. By the way, you can ask your question at HP support forum, also, like
Jan 18, 2012 | HP Scanjet G2710 Flatbed Scanner
I have connected the TMA to my hp scanjet and I have put a slide in it, but when I scan it, all I get is a scan of the whole glass and the slide is black.
When scanning slides and negatives the scanner lid lights up so light passes through the slides and negatives and the image is picked up by the sensor.
If the image of the whole glass is black then most likely the lamp in the lid is faulty.
Aug 19, 2011 | HP Scanjet 4570 Flatbed Scanner
My hp scanjet G241 scanner produces a terrible noise wen scanning
i want to dowonload system of my scanjet g 2410 on my laptop
May 17, 2010 | HP Scanjet G2410 Flatbed Scanner
HP Scanjet 2400 scanning picture green and backgroud green
go to scanning software in ur computer change color section and remove this problem
Nov 03, 2009 | HP ScanJet 2400 Flatbed Scanner
ARE THERE REPLACEMENT bulbs for an hp scanjet
Yes it has a replacement. Try to find it in some computer stores.
Oct 30, 2009 | HP Scanjet 3570c scanner
HP 5200c scanjet - get black page
yes, your fluorescent bulb is burned out and you cannot buy a spare. Sorry
Oct 11, 2009 | HP Scanjet 5200c Flatbed Scanner
HP Scanjet 3570c not scanning
Scanning Without HP Hardware
1. Click Start
2. Control Panel
3. Click Scanners and Cameras
4. Click on the Icon and follow the Scanner and Camera Wizard instructions.
5. Select the HP scanning device from the TWAIN source list
6. Click File and then Scan New .
Feb 08, 2009 | HP ScanJet 3570C Flatbed Scanner
Makes grinding noises, refuses to scan; WinXP
take a look on the underside of the scanner. there may be a switch that goes from lock to unlock. try to move it to lock and back into unlock. this lock is usually used to lock the bar from moving during shipping. if this got moved back to lock or bumped while you had it turned over, the scanner will not allow the bar to move.. try this first.
Aug 16, 2007 | HP ScanJet 6200C Flatbed Scanner
HP 4570C Flatbed Scanner Logo
332 people viewed this question
Ben Johnson
