Question about AOC LCD TV's: 17.0" LCD Flat Panel Display - FP720 Monitor
Good Day, I have an AOC m19w531 and my remote got busted. Is there any replacement available? are there universal remotes that will work with this monitor? Thanks.
4 Suggested Answers
  • 68 Answers
SOURCE: AOC 19MVWK
CNET.com
Posted on Oct 24, 2009
SOURCE: my AOC LCD monitor was broken,their are posible
yes it's posible to replace screen but thing is it will cost you the allmost 75% price of LCD
Posted on May 05, 2010
budmrtn
  • 11361 Answers
SOURCE: My AOC 2019Sw1 - 20" LCD monitor is not working.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed AOC monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Feb 01, 2011
I have a RCA 3 device remote model rcrno3br I need to program a zenith digital converter box to it model number dtt900 it won't work the 51415 codes a bust the search is a bust I need help
You have this backwards; the remote codes control the Zenith box. If your RCA remote is universal and you can't find anything that works using code search, you may have to try a different universal remote.
Nov 14, 2016 | RCA Televison & Video
Codes for aoc tv universal remote chunghop?
Chunhop remote control have no set-up code to AOC. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the "brand name" of your device, in the search box [at the top right] of the display window and press Enter. It will make surf easy.
Jun 12, 2015 | Universal Televison & Video
Can i set the language without a remote?
No. You should have a remote control to select languages. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Sep 08, 2014 | AOC L19W861 19" LCD TV - 16:10 170AA /...
The tv is stuck on a game channel and none of the buttons work such as the channel page, menu, select, guide, etc. I have replaced the batteries
Good day!
may I know if your remote is original or universal remote.
If your remote is universal you have set-up the remote code.Because universal remote is need to set-up every time it loose the battery or power.
If your remote is original and the battery is new.You have to do is replaced the IR sensor of your remote.
Thank you
May 28, 2011 | Hughes HRMC9 Remote Control
My car has a remote and it stopped working as well as my signal lights, my hazards still work, what seems to be the problem and how can I fix it
good day, you may try checking on the fuse of the turn lights and replace it if busted, you can try to open the remote control and replace the battery too. hope this helps, have a nice day
Feb 08, 2010 | Car Audio & Video
Remote fOR AOC LCD L37W781B won't work
try to replace a crystal capasitor on your remote
Feb 21, 2009 | AOC A15X221 15 in. LCD Television
Remote control codes
my mums remote control for her aoc television has broken i bought a new universal remote but there is no code for the aoc television i have tried the other method avaliable but the television still does not accept it what do i do now
Sep 21, 2008 | Televison & Video
Can change the sound with my remotes
I recently bought a GE universal remote control, SKU: 24950, that has a control code for the AOC A17W221 TV. I bought mine at Target. You can check online to see if your local store has one before you go there. It's also listed on the GE site under consumer electronics accessories with a price. Don't know if they sell it online, though.
Mar 15, 2008 | AOC A17W221 17 in. HD-Ready LCD Television
Help me
Try www.replacementremotes.com Their website says they have a replacement for your original remote model # KKY223 with a model # KKY223A. Call to verify availability. Other sites I have checked state that neither of these is available anymore. In addition, you may want to consider purchasing a generic or universal remote for every day usage to save the factory unit from the day-to-day abuse that all remotes suffer.
If you go shopping for a universal remote, be sure to verify that it specifies that it will work with your particular Konka model. There are a # of people writing to this site looking for remote codes because they didn't verify that the universal remote they purchased would work with their TV.
Feb 25, 2008 | Konka FL2792U 27" TV
Universal Remote
I dropped and busted my origional remote control. I bought a new one from www.newremotecontrol.com , there are many sites that sell origional remotes, so shop around. it is not a universal remote, but the actual remote for the product... a little pricy, but worth it to have all the funtions available.
Nov 28, 2007 | Sansui VRDVD5000 DVD Recorder/VCR
AOC LCD TV's: 17.0" LCD Flat Panel Display - FP720 Monitor Logo
140 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
