Question about Humminbird PiranhaMax 190C Fish Finder ()
The depth reads 98 to 100 feet. - Humminbird PiranhaMax 190C Fish Finder ()
    Problem Solver:
  • 12 Answers
I need more details about the problem you are having to be able to help you.
My best guess is that your unit will only disply data between 98 and 100 feet?
If thats the case check the range setting on your unit. It may be set to only display that range. You can set it to auto and it will automatically adjust the range from zero to just over the maximum depth it is currently reading.
Posted on May 23, 2011
How much area will be covered with 36.78 cubic feet of mulch please answer in feet and inches
How it Works
Stone and Mulch Calculators
As an example, let's use 500 square feet to be mulched at a
3" depth.
  1. First, the depth must be converted to feet. To convert inches to feet, simply divide inches by 12, the number of inches in a foot.
    So for our example: 3 inches divided by 12 equals a 0.25 foot depth.
  2. Now that we have the depth in feet, we can multiply the depth by the area.
    So for our example: 0.25 foot depth times 500 square feet equals 125 cubic feet.
  3. If you are calculating 0.5, 2, or 3, cubic foot bags, simply divide 125 cubic feet by the size of the bag.
    So for our example: if we are using 2 cubic foot bags, we can divide 125 cubic feet by 2 which equals 62.5 bags.
  4. If you are calculating cubic yards, we need to convert 125 cubic feet to cubic yards by dividing by 27. One cubic yard is equal to 27 cubic feet, see the diagram below.
    So for our example: 125 cubic feet divided by 27 equals 4.63 cubic yards.
For Your Information
  • 1 inch equals 0.08333 feet
  • 1.5 inches equals 0.125 feet
  • 2 inc
Jun 29, 2016 | Office Equipment & Supplies
My pool is 16feet wide by 32 long 10 feet deep what is the square footage
What you looking to know?
Square feet suggests a flat area, like the floor plan of the pool, which would be 16 x 32 = 512 square feet. Like you'd measure walls for tiles or paper etc.
As you've given 3 dimensions, sounds like your after the cubic capacity/volume of the pool, in which case your looking at cubic feet (same as flat area above, but with the added depth to go from flat 2d, to 3d (2 vs 3 dimensions)), which would be 16 x 32 x 10 = 5,120 cubic feet.
Jun 02, 2015 | Pool & Spa
Just purchased and Eagle Fishmark 320 used. Will not display depth reading - just shows 0'0"? I have reset to factory settings. We have had in lake,same thing. Right now in 5 gallon bucket of...
Hello! Do you have the PDF users guide for your unit? I'm looking at a copy in the troubleshooting section...I don't want to cover information you have already looked at or tried...Since I do not know if you have that manual I'll give you a few items to check...
Measure the battery at the units power connector...Must be at least 11 volts DC...In portable mode it uses 8 D cell batteries= 12 volts
Make certain the Transducer is securely connected...
Did you use the in-line fuse supplied with the unit?...
Try the Manual Depth Range...First turn off Auto Depth Range...From the sonar Page Hit MENU...Down-arrow to Auto Depth Range...Hit ENT...Hit Up-Arrow to Depth Range...Hit ENT..
And the Depth Scale Range appears...Up-Arrow or Down-Arrow to select a different depth range...Hit Exit...The minimum depth the unit can read is 5 feet...
If you do not have the PDF guide, here is the link...
http://www.eaglenav.com/upload/Eagle/Documents/Manuals/seafinder320df_0143-661_101602.pdf
Let me know how you make out....Guru....Saailer
Sep 11, 2011 | Eagle Fishmark 320 Portable Fishfinder
My Furuno reads 3.5 feet when my sea ray depth finder reads 1.6 feet, how can i adjust this?
There is a keel offset or waterline offset that can be entered in the menus. Press "MENU" + go to "DRAFT", use right arrow to enter menu, change using up and down, the press "MENU" when done. Note that "DRAGHT" is on PAGE TWO(2)!! of the main menu. John 847-746-0100 technicalmarine.com
Jun 17, 2011 | Furuno Ls4100 5" Mono Lcd Fishfinder Temp...
My 570 transducer is mounted on trolling motor.
I too have the exact same problem. .6 to 6ft then stays at .6. love to figure this out.
May 08, 2010 | Humminbird Smartcast Rf 35 Dual Display...
New GPSMap 440 S Depth flashing
You need to visit the garmin site and download a software upgrade its free and should fix any glitches you may be experiencing with your unit.
Jul 01, 2009 | Garmin Gpsmap 440s Dual Frequency Combo
How and why scuba gauges give a diver critical information while scuba diving?
Scuba gauges give a diver three very important pieces of information: 1. Time 2. Depth 3. Air Consumption This information enables a diver to stay within safe time and depth limits and avoid running out of air. There are many different devices on the market to help with this, from simple gauges to complex digital consoles. Time If a diver is not using a dive computer to monitor their nitrogen, they dive according to approved dive tables. To use dive tables properly, a diver needs to track their downtime. This can be done with a good dive watch. Two things make a good dive watch: water resistance and a rotating bezel. 1. Water Resistance. Good dive watches are rated to a depth in meters or feet (e.g. 200 feet) or a pressure rating in atmospheres (e.g. 4atm). Even though most divers probably won’t dive below 130 feet (the recreational dive limit), a good dive watch should be rated to 200 feet. Note: There is a difference between “water resistance” and “waterproof”. A “waterproof” watch is what you would wear in the shower, but would probably start leaking at 15-20 feet. 2. Rotating Bezel. A bezel is an adjustable ring on the face of the dive watch with a pointer indicator. At the beginning of a dive, the pointer on the bezel is aligned with the minute hand where it stays though out the dive. At the end of the dive, you compare the difference between the bezel and the minute hand to find out the length of the dive. The bezel should only move “counterclockwise”. It is possible to accidently move the bezel during a dive. Because of this, watchmakers make sure any accidental movement will turn the time in a conservative direction, making the dive longer rather than shorter. Depth Another important part of scuba gauges is a depth gauge. A depth gauge enables a diver to keep track of their depth even if they cannot see the water’s surface. Gauges can be either an analog (needle-and-dial) device or a digital device. Both work in the same way. They measure the surrounding water pressure and convert this into an accurate reading of your depth. Another feature of a good depth gauge is a maximum depth indicator. This tells a diver their maximum during a dive and must be reset after each dive. Air Consumption Another equally important part of scuba gauges is a submersible pressure gauge (SPG). This is connected to the first stage with a high-pressure hose and measures the pressure of the air in the tank. The SPG is much like the gas gauge on a car. At the beginning of a dive, a diver starts with a full tank. This should be about 3000 psi or 200 bars. As the diver breathes during the dive, the gauge will move slowly downwards. This allows the diver to have enough air left in the tank to: 1. Make a slow, safe ascent 2. Make any necessary decompression stops 3. Inflate their BCD once at the surface 4. Breath from the regulator if the surface conditions are rough A submersible pressure gauge also allows a diver to stop diving with air still in the tank. This keeps contaminants from entering the tank due to no air pressure. Wrist Depth Gauge Scuba gauges come in two basic styles. Stand alone gauges or gauge consoles. Stand alone gauges such as a wrist mounted depth gauge or a submersible pressure gauge attached to the first stage of a regulator are great backups when using digital gauges. Gauge consoles allow divers to have all their gauges in one place. Although less easy to read, analog gauges sometimes give slightly more accurate readings than digital gauges, particularly at shallow depth. Submersible Pressure Gauge Choosing Scuba Gauges When choosing scuba gauges, remember to look for: 1. Easy-to-read numbers 2. Luminescent dial or back lighting options 3. Rotating/swivel mounting 4. Easy disassembly for cleaning or replacing parts 5. Good warranty
Dec 01, 2008 | Aeris Max Depth Analog 2 Gauge Console
Depth sounder problem
If the transducer is mounted off of level, an error is introduced due to angle. It is a fixed percent offset, say 10%. so 10 feet reads 11 and 100 reads 110. There is an offset function to read depth below ducer, depth below keel, and depth below waterline, but these are fixed amounts in feet, not a percentage. Look at the transducer when it is operating, boat angle considered.
Jun 18, 2008 | Furuno GP1650DF GPS Receiver
Depth display
reset your factory settings!
Oct 02, 2007 | Garmin GPSMAP 498
Humminbird PiranhaMax 190C Fish Finder () Logo
135 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
