My frigidaire washer will not drain. - Washing Machines
  • Washing Mach... Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on May 23, 2011
Frigidaire washer will not wash or spin
Hello friend, thank you for your post!
I understand that your Frigidaire washer will not wash or spin. Typically if your washer is not spinning it could be a potential issue with your drain hose. I would check to assure that there are no kinks in your drain line or that the drain hose is not too long. Those could be some possibilities.
If the drain line is clear you could be experiencing an issue with your timer or drain pump. I would recommend seeking assistance from a professional to come out and properly diagnosis your washer. I hope this helps. -Matt
Oct 08, 2014 | Frigidaire Washing Machines
My frigidaire washer does not drain
Good Afternoon Friend,
I understand that the washer on your Frigidaire laundry center, model# FEX831CS, is not draining. First, check the drain hose for any kinks or clogs inside of it. Secondly, make sure that the drain pipe is not clogged. Finally, reset your washer, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Restore power and try starting any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEX831CS Top Load Stacked...
Front Load Washer will not drain. Frigidaire Gallexy Washer Model # GLTF2940FS0. Get Error Code "E20".
This is an error code for a slow drain or no drain at all problem. It can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 21, 2011 | Frigidaire Washing Machines
Hello, Frigidaire washer will not drain, its not clogged. makes loud humming noise when it should drain.
The drain pump has gone bad , it probably has a broken impeller. These units require you to remove the back panel to replace the drain pump assy.
Dec 03, 2010 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire washer will not drain. It work
check all the drain hoses for something caught in the line to the drain from the tub thru the pump to the stand pipe at the drain,you may have a plugged line and machine pump wont start due to this restriction
Mar 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Washing machine will not drain the water??!?
Check the drain pump it may be clogged or not working. This is a common problem i have working at a camp with 15 washers.
Mar 26, 2009 | Frigidaire GLTF1670A Front Load Washer
Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Top Load Washer
Hello vohra_sam
welcome
You said , Water will not drain out
Usually this is the answer
Water in washer does not
drain or drains slowly.
Because drain hose is kinked or clogged.Clean and straighten the drain hose.
let me know, Huuum
Sep 08, 2008 | Frigidaire GLWS1339CS Top Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
