Question about Panasonic PT-51G42 51" Rear Projection Television
Okay i have a panasonic big screen model# PT-51g42 And it randomly turns off then turns back on then about an hour later it'll do it again what is causeing it?
    Problem Solver:
  • 10 Answers
Did you check for dry soldering on the circuit board
Posted on May 23, 2011
My dirt devil keeps shutting off randomly
It's overheating. Empty the cup and replace the filters. There's a breaker that opens up and turns it off when it gets too hot. When it cools down it closes back up and it will run again. It'll argue with you til the end of time or until you fix the problem.
Good Luck
Jan 13, 2013 | Dirt Devil M085805 Upright Vacuum
I have Panasonic PT-51G42C. Colors are distorted. Try entering service menu...it starts with chk screen CHK 1294F 00000000 08 and later left with CHK 12950 00000000 00...feels like convergence...
Hi Lit,
Please confirm if the picture looks like these.
If not, can you provide me sample pictures of the symptoms to accurately diagnose the faulty parts. Email it at jimvincentvillanueva@yahoo.com
Thank you for your patience...
Oct 27, 2011 | Panasonic PT-51G42 51" Rear Projection...
I need to zero the lamp hours on a panasonic PT-AE900E projector
Hi. Press menu and you'll see the menu on screen. Go to options, highlight the runtime hours figure, and press and hold the "enter" button. The hours figure will change to "Power Off" which is what you do next, good luck!
Oct 19, 2011 | Panasonic Lamp For Panasonic PTAE900E...
I have a Panasonic PT-LM2U; when it is turned on, everything powers up fine but the image projected is upside down. I've looked through the menu but didn't see an option for flipping or rotating...
Every modern projector that I have seen has a setting that will allow you to flip the image for this.If you purchased it used it was probably configured as a ceiling mount in an upside down orientation or rear projection onto a translucent screen. (The projection method can be set from the "OPTION2" menu. in a Model LM1 so it should be similar. http://service.us.panasonic.com/OPERMANPDF/PTLM1U.PDF
If yours doesn't have this option, then you'll have to use mounts that require the projector to be upside down.
Jul 18, 2011 | Panasonic PT-LM2U Multimedia Projector
We have a Panasonic PT-D5600U DLP Projector, and the rear infrared sensor is not working. The front sensor works fine, but the projector is ceiling mounted, and we need to utilize the back sensor from the...
Hello: in most cases, front and back sensors are identical. Might even be those little boards, as well.
I've seen repeated problem with sensor board circuitry, not a IR sensor, itself. in my 2 cases, there was a faulty sms ceramic capacitor, twice at the same make and model of Phillips TVs. If you can handle safely open and close top part of projector's cabinet, you will see those 2 small pc boards, connected to control panel. To get a part#, go to "panasonic.com", then look for "support", then 'parts ordering". enter your model# and you'll find whole list of the parts for your set. You don't need any authorization to buy 2 little assemblies. Get 2! The other one will quit sooner or later! shouldn't cost too much, anyway.
Good luck,
Thanks,
Alex.
May 13, 2009 | Panasonic PT-D5600U DLP Projector
How do you reset lamp hours back to zero on a Panasonic PT-D4000U projector?
When you remove one of the lamps, you're notice that there's a micro-chip build into the housing itself. Unfortunately there's no way of manually resetting the lamp hours, due to the chip. You'll need to replace the whole lamp assembly.
Apr 13, 2009 | Panasonic PT-D4000U Projector
Yellowish spot on the lower left hand corner of tv screen
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Jul 07, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic pt-51g42v
You might have bad solder joints on the vertical output IC. I do not know where it is located in this set only that it will be mounted on a metal heat sink near three wires that have identical plugs which go to the deflection yokes on each crt tube. Sets vary as to placement of vertical IC. Solder joints should be easily seen if you have good eyes or use a magnifying glass. I do know that the vertical IC will be on the board that has the highvoltage transformer on it (has big red wire). You may have to unplug the board and turn it to the soldered side or just turn the entire chassis up 90 degrees to see the connections. If this is not the problem I don't know how to get into the service mode at this time.Hope this helps
Dec 28, 2007 | Panasonic PT-51G42 51" Rear Projection...
Panasonic pt-50LC13
We just replaced new bulb and screen was on for about an hour. Turned off TV and tried to turn on later, but now no screen. Do you know what has happened or what I can do?
Dec 24, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
