Kingston flash drive when sending files,data and media displays a dialog box >> like this WRITE PROTECTED-- help me pls...
  • 243 Answers
It seems that the file or the system in your flash drive error, to fix this issue try to format your flash drive. To format the drive you can follow this way
right click on my computer icon in our desktop
click manage
click disk management (in a storage tab)
right click on your detected flash drive (could be in F)
click format
make a system as fat32
list on perform a quick format
Notes: it will erase all your data on your flash drive
Posted on May 23, 2011
Kingmax sd card
To remove write protection:
Open Start Menu >> Run, type regedit and press Enter. This will open the registry editor.
Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Double click the key WriteProtect in the right pane and set the value to 0
In the Data Value Box, press OK
Exit Registry, restart your computer and then re-connect your USB flash drive to your computer.
Dec 06, 2013 | Kingston Electronics - Others
My kingston 8gb flash drive shows 0bytes
Dont worry, you can usb flash drive recovery software like asoftech data recovery to get back your files. You may refer to this step by step guide
how to recover files from USB drive
You may check out this video tutorial also
Mar 23, 2012 | Kingston Digital DataTraveler 4000 8 GB...
Pls. help me ..about my usb (kingston 2GB)..i can't format it and copy some datas!!!..it says that the drive is write protected..and i don't know how to fix it!!..please help me!!
If it says the drive is write protected it means either it was formatted this way ..and for to see if it is so click right on it ..and choose properties and in there take a look not to be ticked on write protected ..or if it is selected read only ..remove the mark and click apply ..
If this is not a case..check the files inside not to have such a issue ..delete files one by one ..and check the ones that do not want to remove themselves..and do just like I suggested .In the last resort ..try to download and install remove on boot program ...and select tye files into the program ..and delete them on boot if they are write protected..
The action itself is to click right on the file that can not be deleted...and select to remove at next boot ..(the program will add this option on the menu ) and once selected all ..just restart the computer ..
here is the link for the program ..but lets hope it will not be needed..
After all files are removed..open the flash drive folder and under organize,,folder and search options ..click on view and select to see hidden folders ..and if there are any delete them too ..just to be sure ..
Last ..just click right on the drive's icon ..and select format ..select the options for to do that and go for it ..
here is the program I mentioned..
http://www.softpedia.com/get/System/Boot-Manager-Disk/MoveOnBoot.shtml
Dec 17, 2011 | Kingston Computers & Internet
Gmail.comhow to remove file protected from pen drive data traveler and also please send any link to down load the software
Kingston Data Traveler2.0 USB Device 4gb write protected remove cannot remove write protected file from usb plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz send me this solution
email addres- Ijazdoger@yahoo.com
Feb 26, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hii sir pls help me mine kingstone data traveler 2gb is write protected so how shall i remove write protected?
Copy all the files onto your 'C:' drive.
Spend $9 to buy a new 2GB USB memory-stick.
Copy the files to the new memory-stick.
Take a sledge-hammer to the old memory-stick -- to prevent anybody else from reading your files.
Oct 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Transcend JetFlash V60 16GB pen drive is write protected
Flash drives by default use the FAT32 file system. FAT32 has a limit of 4gb per file. So you could have four 4gb files on your pen drive, but no files bigger than about 4gb. You could use the NTFS format, but it's not suggested for flash drives since it reads/writes much more often than FAT and will make the drive lifetime MUCH shorter.
Aug 26, 2009 | Electronics - Others
My drive is write protected, but I din't do that.dialog box showing remove the write protection. so how to remove this write protection.
Dear,
Just do one thing
Copy the data of Pen drive to PC and format the drive. Now paste the data back to the pen drive.
It may work fine onward.
Please try it.
Regards,
Rakesh Kumar
Apr 07, 2009 | Kingston 4GB Secure Digital High Capacity...
How can I reformat kingston and sandisk memory cards?
Dear,
Just copy the data of memory card to PC. Now format the card and send the data back to card from PC. It will help you.
Regards,
Rakesh Kumar
Mar 16, 2009 | Kingston 1GB Secure Digital Memory Card
Pen drive is not working properly
try to replace the unit.
it is possibly faulty.
also you should note that pen disks are not as reliable as hard drives.
Jan 23, 2009 | Electronics - Others
Removing write protection of USB pen drive
if u format ur pen drive. then use this step
Check out the registry under:
1)click on start button
2)clik on run dialog box
3)type regedit
4) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0' and when you try to format it you have to format it as FAT16
Good Luck!!
Palwinder
Oct 31, 2008 | iLO (2 GB) MP3 Player
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
