Question about Lexmark X2600 InkJet Printer
The Red ! on both color and black ink images on the printer are blinking and its blinking E C 1 in the window.
  • Official Brand Answer
  • 3,344 Answers
The EC1 error indicates that the printhead is not valid. It could be that your cartridges are not seated properly in the carrier or just needs cleaning. Open the printer cover. Remove both cartridges and close the cover. Wipe the cartridge nozzles with a moistened soft cloth to clean it from dirts and clogs. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert one cartridge first then close the cover. Check for any errors. Then, open the printer cover again and reinsert the other cartridge. If error still appears for both cartridges, then it could be that both cartridges are faulty or incorrect versions. You will have to replace them.
Posted on Jun 01, 2011
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
Tip
How to conserve color ink when printing only text documents.
First, make sure you have an updated driver installed in your computer. Visit http://support.epson.com for updated drivers.
To select black ink only mode and conserve color ink when printing only text documents, please do the following:
1. Open the Printers window by following the appropriate steps for your operating system:
In Windows 2000: Click START > SETTINGS > PRINTERS.
In Windows XP: Click START > CONTROL PANEL > PRINTERS AND FAXES or PRINTERS AND OTHER HARDWARE. (Select VIEW INSTALLED PRINTERS under PRINTER TASKS if no printers appear.)
In Windows Vista: Click START > CONTROL PANEL > HARDWARE AND SOUND > PRINTERS.
2. Right-click on your printer name and select PRINTING PREFERENCES.
3. Click the ADVANCED tab.
4. Select the BLACK INK ONLY option.
5. Click OK.
Remember to repeat these instructions and remove the check from BLACK INK ONLY when printing photos or color images.
on Nov 06, 2008 | Epson Stylus Multifunction Printer/...
Printer not working so put new Color ink in - red light is on the black ink. Changed printing preferences to Color Ink and deleted all documents in queue and also turned off computer and still the printer...
part of your prob is that the way ink jet printers work, (according to the tech support training that I rcv'd about ten yrs ago from Canon) is that the printer "builds" the image or character by adding color to the black ink (for most of the jobs) in order to create "depth", so you will need to replace or (HINT: you can sometimes reset the cartridge by lifting the locktab and then reseating it) using the utility to replace the black cartridge. good luck!
Jun 13, 2010 | Epson Stylus 880 InkJet Color Printer
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
C43sx both lights on
ok...start by removing the drivers from control panel, go to website and get new drivers, install them, try it again.
http://tinyurl.com/6qcpgy
Jun 11, 2008 | Epson Stylus C43SX InkJet Printer
Epson R2400 too red
i think you have a corrupted driver- you have to uninstall driver first
1. Double click on the MAC HARD DRIVE.
2. Double click on the LIBRARY folder.
3. Double click on the PRINTERS folder.
4. Drag the EPSON folder to the trash can.
Go to print and fax and delete the printer name as well
Restart the Mac. (You do not need to empty the trash.)
If you have not done so already, please follow the steps below to download the latest driver for your printer in OSX:
1. Go to the following website: http://support.epson.com
2. Under the PRINTERS heading select INK JETS and then the Stylus Photo R2400.
3. Under the DRIVERS & DOWNLOADS section select MACINTOSH.
4. Select and download the following file for your operating system
which mac are you using? tiger ot leopard? intel core or powerpc?
May 15, 2008 | Epson Stylus Photo R2400 InkJet Printer
Installing
not sure w/ this one, but is it blinking too fast on printer, the check color and black ink cartridges? and if yes what is the color of the light, is it yellow or red, and is the on and off lights, flashing?
-black and color blinking fast - install printhead
-black and color blinking slow - no cartridges installed
-on and off blinking black and color steady lights, calibrate
-hope this helps, or else contact kodak
-xoxo
Apr 11, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printing Problems
In Windows 98/ME/2000:
1. Go to START, SETTINGS, PRINTERS.
2. RIGHT CLICK on your Epson printer name; left click on PROPERTIES.(PRINTING PREFERENCES in Windows 2000).
3. Go to the MAIN tab.
4. Place a check beside BLACK INK ONLY.
5. Click APPLY then OK.
In Windows XP:
1. Go to START, CONTROL PANEL, PRINTERS AND OTHER HARDWARE or PRINTERS AND FAXES. (Select VIEW INSTALLED PRINTERS under PRINTER TASKS if no printers appear).
2. RIGHT CLICK on your Epson printer name; left click PRINTING PREFERENCES.
3. On the MAIN tab.
5. Click OK.
Dec 28, 2007 | Epson Stylus Photo RX600 All-In-One InkJet...
It will not print.
Hi Greenhorn, Your info is slightly conflicting - I think. As I remember the C60 has just 2 LED's: 1 - Green for Power 2 - Red for Error The third button - Cartridge exchange - has no LED Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong. The error codes I remember are: Printer status - Indicators - Priority Power - Error Power ON condition On - Ink sequence Blink - Ink Cartridge change mode Blink - Data processing Blink - Paper Out *1 - On Paper jam condition *1 - On Ink end (Black) *1 - On -> Blink Ink level low (Black) - Blink-> Blink Ink end (Color) *1 - On -> Blink2 Ink level low (Color) - Blink-> Blink2 Ink end (Black and Color) - On -> On No Ink Cartridge (Black or Color) *1 - On Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink Fatal error *1 Off On Special setting Blink2 Blink2
Mar 27, 2007 | Epson Stylus C60 InkJet Printer
Lexmark X2600 InkJet Printer Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
