I have 1997 ford futura isnt starting in morning i put the battery on charge for a couple of hours and it goes all day then next morning wont start again what could be the problem?
  • 1,381 Answers
Hi damian_ramsa
You need to replace the battery .
Best regards,
fanaudi .
Posted on May 23, 2011
Truck is draining charge and not charging battiers
I just went thru same thing with my 2003 f-350 diesel. I hooked up my horse Trailor and drove to Von's parked went in came back out and truck was dead. I tried to jump it didn't work. Then over next two hours two tow truck Drivers hooked up to both batteries full power charge direct to my truck and would not start.
End story required two new batteries alternator and cilanoid discussed above. In other post. Also contributing to the cause was really badly coroded cables they looked good at the connection point but wher discovered to be coroded inside the tubing just above the end connections so bow it has all been replaced and I have had no trouble since. Hope this helps. Tanya
Jan 23, 2013 | 2003 Ford F350 Super Duty DRW SuperCab
1997 ford escort battery new battery dead overnight no electrical works no blown fuses jump start and cables start to melt will push start and run
Check battery cables are correct ! Prime suspect here ! Alternator may be damaged and shorting .. Don't drive any car that will melt jumper cables ! Something very basic wrong here.
Aug 26, 2012 | Ford Escort Cars & Trucks
Car not starting in the morning after being on battery charger for 2 hours it starts and goes all day and the next day wont start again
either have a battery drain or your battery or alternator is bad-you can check all these things out if you have a battery voltmeter. The battery should be at 12.5 volts after sitting overnight and it should be close to 15 volts when first started, gradually dropping down to about 14.2 volts at idle.
May 23, 2011 | 2005 Ford Futura
BATTERY IS GOOD SO IS THE STARTER AND THE ALTENATOR WHY DO I KEEP HAVING TO HAVE JUMP STARTS? 1997 FORD ESCORT
How long does it take for the battery to go dead, overnight, couple of days?
Have you checked the electrical system for draws? You'll need a multi meter capable of reading amperage. Disconnect the positive cable and hook the meter up in series with the battery and the positive cable. You want to make sure the key is out of the ignition, all the doors are closed and all the dome lights etc are turned off before doing this. If you get a reading of more than .050 amps than you have a draw. You may have to wait for 20 minutes or so for everything to power down to get an accurate reading.
If you have a draw of more than .050 amps than you can start pulling fuses one at a time until the draw goes away and then focus on the things that fuse supplies power to. Make sure you put the fuse back that you pulled out before pulling the next.
If there are no draws and the battery goes dead overnight disconnect the battery, let it sit overnight and then see if the battery will start the vehicle in the morning. Every once in a while you will run into a battery that has an internal draw and will run itself down all by itself.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 27, 2010 | 1997 Ford Escort
Car won't start in the morning. Put in new battery, still won't start until we charge the battery. Next morning, same thing.
Check to see how many volts your alternator is putting out at your battery terminals, should be putting out 14-14.4 volts. If its any less than that you probibly need a new alternator
Dec 05, 2009 | 1997 Honda Accord
6.0 power stroke diesel,wife put regular gas in it,had to drop tank and clean,changed filters,twice in two weeks,wont start in the morning,have to crank it for an hour,keeps trying to start,gets closer and...
Quick check is to take a fairly thick cable from the positive terminal of the battery and touch it onto the glow plug connector , it should give a healthy spark as it makes the connection , no spark no glow plug
Sep 16, 2009 | 2005 Ford F 250 Super Duty
1997 mpv mini van runs great. While traveling i drove from SC to Atl GA....parked and went into motel for evening...the next morning i had very difficult time getting it re started....Like it was not...
I think you should check your battery and alternator.If they both check good you may have a battery draw,something draining the battery over night.Check your doors make sure they are closing like they should.
Jul 28, 2009 | 1997 Mazda MPV
My 1998 windstar shuts off and wont start
charge battery up 2 amp slow charge,could take 24 hrs,,, put a volt meter of any kind that goes up to 20 volts or more,and it should be charging 13.50 to 14.25 with nothing on then turn ac on and fan on high and head lights on bright it should stay around13.25 to 13.75 if u dont get these readings replace alternator
Jun 28, 2009 | 2003 Ford Windstar
1997 ford expedition will not start
try new fuel filter...also connect scantool for pending codes not yet ready for check engine light.
Jun 14, 2008 | 1997 Ford Expedition
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
