Question about Cfm Daikin R410a Split System Air Conditioner
Low and high limit pressure of r410a for daikin
4 Suggested Answers
SOURCE: What is the high pressure
outdoor ambient temp + 30 deg F convert to pressure via chart;
indoor ambient-40deg F converted to pressure via same chart.
Posted on Nov 01, 2010
dvs_redstorm
  • 81 Answers
SOURCE: lost manual for model R410A
google daikin (model number) manual . what are you trying to do or just want a manual ?they really dont tell you much in them.
Posted on Nov 09, 2010
hvac1960
  • 2133 Answers
SOURCE: error message U1 on daikin
U1- Reverse phase/open phase. Check all phases are there. If yes, interchange any two phase in terminal. Please ensure you isolate the power before doing it. Thanks. Helpful?
Posted on Jan 22, 2011
What are the running compressor pressures H&L
Thats a hard question to answer! what Type of refrigerant is in it? R-22 or R410A? If its R-22 you want to see about 60-65# low side and 225 -240 high side. those can vary with outside temperature. R-410A look for 120# low side and 450-475# high side. DO NOT USE R22 MANIFOLD SET ON R410A SYSTEM!! IT WILL NOT TAKE THE HIGH PRESSURES AND COULD EXPLODE.
Aug 12, 2014 | Intertherm P3RA-036K Air Conditioner
Error code is "U0"
According to the operation manual your system is low on refrigerant. You will need a technician show up and charge your unit and find the leak. This is a split system so leaks are very prominent.
"U0" Low pressure drop due to refrigerant shortage or
electronic expansion valve failure
A link to the system manual is below.
Hope this helps you with your issues...Jim...please leave a comment
http://www.daikinac.com/commercial/pdf/service_manual/SkyAir_SiUS25-501.pdf
Feb 13, 2011 | Cfm Daikin R410a Split System Air...
Looking for code E3 keeps falshing
E3 Outdoor activation of high pressure switch
Condenser coil is dust blocked.-Clean it. Rpm of fan motor is less-Replace capacitor. If over charged gas- release some gas. Check for continuity for high pressure switch, if no continuity, replace high pressure switch.
Thanks.
Feb 05, 2011 | Cfm Daikin R410a Split System Air...
Error message U1 on daikin R410A
Jan 22, 2011 | Cfm Daikin R410a Split System Air...
Is there a reset button on daikin splits? If so where can I find it.? Fault code U4.
the fault code for daikin u2 is power supply is too low the reason for this is complexed and needs an expert to fix it
hope this helps in some way
Dec 02, 2010 | Cfm Daikin R410a Split System Air...
Lost manual for model R410A Daikin invertor. Where can i find a new one?
Nov 03, 2010 | Cfm Daikin R410a Split System Air...
NO cold air
I would check the drain to see if it is stop up.Next check to see if the unit inside is freezing up.If it is check to see if fan is running and if fan is running the you proable have a freon leak. Low charge on freon will make it freeze up and the fan not running also.
Therefore I would request to add r410a refrigerant for better cooling. Thanks for contacting Fixya.
Jul 05, 2009 | Cfm Daikin R410a Split System Air...
Cfm Daikin R410a Split System Air Conditioner Logo
94 people viewed this question
Top Cfm Heating & Cooling Experts
David Payne
David Payne
Brett Duxbury
Brett Duxbury
Thomas Woodburn
Thomas Woodburn
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
