LANIER COPIER 7313
When making copies, copies come out as if the paper was slid down the page. How can we fix this problem 7313 AG Lanier copier
ser. CKA 820 854
  • 417 Answers
I guess by your fault description that there is a blank gap before the printing starts? The only way to cure this problem is to replace the registration clutch as it is turning on too late and not releasing the paper quick enough. Also check that the paper tray dial is displaying the correct paper size and position.
Thanks Jason
Posted on Aug 17, 2008
Very light copy in 2nd side copy
its a moisture issue in the paper. try nice new dry paper and i bet it works fine
Mar 17, 2012 | Lanier Office Equipment & Supplies
Lanier 6613 copier. Image is offset down the page by 3 and 1/2 inches. Is this a setup issue? Any suggestions?
try making a copy and then open the door when the paper is in the center of the machine. if the image is offset before the paper hits the fuser(hot) rollers>the problem is in your drum unit (most likely a cleaning blade. If it happens after going through the fuser(hot) rollers you have a fuser roller problem. Most likely you have a worn drum cleaning blade which is cheaper the a drum. Good Luck.
Dec 17, 2010 | Lanier Office Equipment & Supplies
The copies on our Lanier/7313 come out zebra stripped. The copies appear to copy better if we change the copy darkness to a lighter color.
Zebra striping is typically caused by a bad development clutch. Most likely, the developer and the development clutch will need to be replaced, but the 7313 is so old you may have trouble finding parts, or finding a technician to work on the machine.
Sep 21, 2010 | Lanier 1205 Copier
How do I reolace the toner in a lanier 7313 copier.
It was very easy. I just had not seen the machine when I posted the question. Thanks
Jan 07, 2010 | Lanier 1205 Copier
Lanier Model #7320 Copier SN 826255. Has a wrench
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
Sep 23, 2009 | Lanier Office Equipment & Supplies
I have a Lanier 7313 Copier which doesn't copy properly. Even with a new ink cartridge, the copies come out faded. Any ideas on what I can do?
This machine goes through developer pretty quickly. Sounds to me like it needs new developer and possibly a drum (and drum blade).
Aug 24, 2009 | Office Equipment & Supplies
Lanier 6725 copier: Paper is always jamming and
I have worked for Lanier for 20 years, the 6725 was a great machine, but getting parts, spending $$$ and still having an old copier. Lanier is owned by Ricoh and all machines are Ricoh with a Lanier sticker on it. Its time.
-Carl, please let me know if this helps.
Jun 26, 2009 | Office Equipment & Supplies
Dark copies with overprinting
Cleaned the coronas as per instruction book. Done this before but this time it made a difference.
May 07, 2009 | Lanier 1205 Copier
Lanier copier 7313 AG
The clutches arnt too bad putting them in however... I own this model as a home copier but parts are hard to come by and to get a tech that knows how to repair is harder.
Sep 18, 2008 | Lanier 1205 Copier
Lanier 6735 Copier
Sounds like you need a new cleaning blade. It is located inside the process assy behind the drum.
Aug 10, 2007 | Lanier 1205 Copier
149 people viewed this question
jasbo
jasbo
