Question about Panasonic Televison & Video
Vcr pc4022 panasonic vcr insert tape and it rjects the tape and won"t play
  • Panasonic Master
  • 6,771 Answers
The main loading sensor is defective and needs to be replaced, "cost to replace will exceed a new vcr"
Posted on May 23, 2011
WHEN INSERT THE VHS TAPE TO VCR IT EJECTS BACK... WHAT MAY BE THE PROBLEM?
Hi, depending on the age, chances r that some components r worn out or the eye sensor needs cleaning or sdjusting.....
Jun 21, 2014 | Panasonic Televison & Video
I have a Panasonic VCR (DMR-ES35V) and when you insert the tape, it does not thread the tape across the video head. The tape runs for a moment and then ejects.
There's either damage in the drive section, or more likely and in some cases "plus" the Mode Switch is set in the wrong position or is faulty. The mode switch tells the electronics what position the VCR mechanism is in. Such as play or fast-forward. If in the wrong place it will carry out other functions - such as eject - in your case.
Sep 27, 2013 | Panasonic PV-V4022 VHS VCR
VHS Tape won't stay in compartment
Going to have to look inside but expect to find that tape is not going all the way into position and having the tape pulled out and up against the drum with the video heads.
If it does not fully load a transport problem exists--drive idler and or belts.
Faintly possible also is something that does not belong inside got in past the door and is jamming it up.
Apr 24, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
I took out some 2001 9/11 taped back then. Inserting them the TV message was CLEAN VIDEO HEADS. I don't know how to do this. Are the video heads on the VCR or on the video tape? What would i use to...
You can purchase a VCR cleaning tape that will do the job. However the best way is to buy a can of Servisol Video 40 (small one will do and it will last a long time) then remove the top cover of the VCR. Spray the VCR heads. Shinny Silver things and any moving parts that the tape touches. If your not certain what to clean, with the cover off insert a tape and press play. Remove the tape and spray small amounts on the surfaces. If you can see a lot of dust you can wipe the heads etc with a cotton bud. A VCR housed in a smokers house will need extra work to get it clean. Once dry you can test a tape. If you see flecks or spots the VCR will need further cleaning.
Sep 13, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Panasonic model pv-4351 insert tape, press play, vcr shuts off
Any number of problems can cause this. One of the biggest culprits is the mode switch. These tell the electronics of the VCR what position the VCR is in. However if part of the mechanism fails (could be anything) then a false position will happen and the Electronics shut the VCR down when this happens. Nevertheless the mode switch can be the cause of this itself, by having dirt in it or being worn out. Sometimes a spray of Servisol Video 40 on the switch will clean it, but it won't do anything about a worn switch or one that is out of position caused by damage to the mechanism elsewhere. So check for damage, then spray!
Jun 14, 2011 | Televison & Video
VCR plays 15 seconds, TV shuts off. Same without tape inserted
Sounds like a typical Switched Mode Power Supply fault, or an internal thermal fault that is shutting down the power supply, over & over. Really you need to get it serviced. You need to get a firm "Quote" for repair, remember these days repair can often exceed replacement cost.
Feb 03, 2010 | Televison & Video
VCR Lock Activated message appears when I hit Play. Why and how do I get rid of it so I can play a tape?
<b><font size="1" face="Helvetica-Bold"><font size="1" face="Helvetica-Bold"> To turn on, </b></font></font><font size="1" face="Helvetica"><font size="1" face="Helvetica">hold down<br /> REC on the VCR in Stop<br /> mode with no tape<br /> inserted for 7 sec.<br /> (Please ignore the NO<br /> CASSETTE warning.)<br /></font></font><b><font size="1" face="Helvetica-Bold"><font size="1" face="Helvetica-Bold"> To turn off, </b></font></font><font size="1" face="Helvetica"><font size="1" face="Helvetica">repeat above<br /></font></font><!-- from fixya rte -->
Nov 22, 2009 | Panasonic PV-V4022 VHS VCR
Video transfer not working
  1. connect VCR(recorder) to TV, select TV proper channel to get signal from VCR
  2. connect Mini DV to VCR, for example, you are using AV1 input on your VCR
  3. on you VCR, select channel(or input) to AV1, insert a blank tape
  4. turn your Mini DV to play mode and play, press REC on your VCR
you should get picture now.
May 08, 2009 | Panasonic NV-DS60 Mini DV Digital...
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
