Question about Iomega (35IN1TBHARDDRIVE) Hard Drive
Hard drive will not spin up. Blue light is on, no sound of spinning hard drive
  • Iomega Master
  • 27,725 Answers
Click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Posted on May 23, 2011
Seagate Barracuda 7200 1TB spinning but not mounting
Man it sounds like it just died on you out of the blue... Maybe you had a power surge or something and you didn't know it.
Jun 30, 2012 | Iomega 1TB Desktop USB 2.0 Hard Drive
My WD element extrenal hard drive won't open. i can see it in my devices, and the blue light stays on. it also makes the sound saying it's connected but I can't see the device in my comput
First thing, try to change the cable, try a different one, then if it does not work, try to connect the hard drive on another computer, and changing cables as well. This will help you to narrow down the problem to find out exactly what the matter is. If the Hard drive spins properly and it does not produce any click-click sound then it is fine. If all the above fail, then you have to slave the hard drive using its internal SATA connection. You have to open up the hard drive and remove the pin that connects the hard drive to the cable. This will enable you to see the SATA connection. Slave the Hard drive on a desktop computer and see if you can gain access to it. If you can, then consider replacing both the cable and the pin that connects the cable to the hard drive. If your hard drive just spins and you can not access it while its a slave to another computer, then the hard drive has a problem.... Try the methods above, i believe your hard drive did not go this bad...
Mar 26, 2012 | Western Digital Elements powered by WD 320...
I have firelite external and it's not working. There's light but no spinning sound. what can I do?
This a firewire drive and needs to plugged into a firewire port to spin up. If you do not have a firewire port on your computer (most PC's don't) it will not work. I don't believe a firewire to USB connector will pass enough power to the drive to spin it up.
Mar 12, 2012 | SmartDisk FireLite 60 GB Hard Drive
LG -External Hard Disk not working I have an LG HDD HXD2 - 250 GB and yesterday I unplugged without safe to remove . When i tried to reconnect HDD, the blue light is on and the hard disk make sound...
Hello
Welcome to Fixya!
Firstly we will need to establish is the hard drive spindle is actually spinning up. Can you hear it spinning up?
Does the hard drive make a clicking sound?
Let me know any feedback in regards to the above.
If you do hear a clicking noise, it is not good news.
Let me know by means of a comment.
Kind regards
Lock123
Oct 10, 2011 | Computers & Internet
I plug in my Acomdata 320 GB external hard drive and the blue light comes on and stays on (it doesn't alternate between the red & blue as it did before when it was working). There is no whirring...
If the drive doesn't spin up, then the housing/controller has probably died. The hard drive is likely okay though. You can purchase empty hard drive housings for around $20-30 and transplant your drive into it. Take the old drive out of the housing first to determine if it is IDE or SATA. If you don't know what this means, you may be better off taking it to a shop to have the drive transplanted. It would take a technician 5-10 minutes to do.
Hope this helps!
Regards,
Joe
Jan 02, 2011 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
When powering on ,power button light is blue,then changes to white, both fan running,no video,hard drive sounds like its spins up
your video card is damage or your (ram) memory card have a trouble with your computer.. and your hard drive maybe broken
Sep 25, 2010 | Computers & Internet
Lacie 1 t drive will not mount. previously worked fine for almost two years. used as pc backup drive on bootcamp side of macpro. Primary drive in computer has also failed (fantastic). drive does spin,...
Sounds as though the interface card, between the hard drive and connector panel at the rear has packed up. If it is out of warranty it is worth opening and connecting to a separate cable. You will most likely be lucky.
Mar 07, 2010 | LaCie (300770) 250 GB Hard Drive
1 TB Esata/FireWire400/USB 2.0 disk problem, one flashing light
have you checked the output on the power adapter when you plugged in? if not, there is no hard reset for the drive. you just have to isolate the board on you external hdd.
Mar 02, 2010 | LaCie d2 Extreme 250GB External with...
My external hd blue light just flashes and i dont have access.
Do you connect via USB or firewire? Can you / have you tried another connection method?
Does it sound like the disk is spinning normally, or is it making a heap of clunking noises or not spinning?
The most common problem (assuming it has power, which it obviously does because it has a blue light), is the USB cable. Do you have another that you can try?
Let us know how you go with that and we'll continue...
Apr 27, 2009 | Acomdata 500GB External Firewire HD 500 GB...
Dropped firelite: still spins but is not recognized
Ok same situation happened to me i dropped my Firelite 80Gig, drive would spin no light and the computer would not recognize the drive. All I did was open the case an saw the the internal hardrive had come loose from its pin connection. So all i did was pushed it back in and BAM now it works, hope this helps other people. Thanks C.J.
Mar 20, 2008 | SmartDisk FireLite 40 GB Hard Drive
Iomega (35IN1TBHARDDRIVE) Hard Drive Logo
151 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
