Lost manual for my armstrong furnace g2d95ct060v14b-2a
2 Suggested Answers
  • 5 Answers
SOURCE: High limit switch open on armstrong furnace
If you know where the high limit switch is you can always cut the two wires and wire them together causing the limit to close. But what you have to watch out for is why the high limit is not closing. That means in your return air either you have a dirty return air duct, dirty filter, or you don't have all your registors open to allow the heat to escape the heat exchanger. Just watch over riding the system. The high limit switch should either be on or behind the blower, in the middle of the system right under the heat exchanger. any other questions about hvac just ask.
David
Posted on Jan 17, 2009
I WOULD LIKE TO KNOW WHAT TONNAGE IS FOR MY ARMSTRONG AC UNIT. THE MODEL NUMBER IS SCU10A42A-2A
If you look in the manual it will give you the BTU, simply divide that number by 12,000. Example: 24000 BTU = 2 Ton.
Aug 10, 2014 | Heating & Cooling
Armstrong ultra 93
The blower motor may have to be replaced.
Jul 15, 2014 | Heating & Cooling
Armstrong eg6g75dc104
it should be on the inside of the door look for flash codes there is no code book you just have to know post code and what it says on the door and I can help
Nov 12, 2013 | Heating & Cooling
I have an Armstrong SX Ultra 90 propane gas furnace that the fan motor will not shut off ,the thermostat is on auto.
Hit the side of the furnace. Some times there's a sensor inside that gets locked up from a dirty filter.
Oct 19, 2013 | Emerson Lennox Ducane Armstrong Furnace...
I have a armstrong gas furnace and I would like a wiring diagram for it it is a model mg73140
http://www.armstrongair.com/armstrong-links/
from here select the particular furnace that you have this is the only resource the is avail. due to the furnace being a Lennox made furnace
Mar 07, 2011 | Heating & Cooling
Hi, My parents have an Armstrong Furnace Ultra V Tech 80 Model #G1N80AR100014B-2A. I am a building engineer with service exp. and have also had a service tech. out. After much research here is my...
You can check the flame sensor with a microamp meter to see if the flame sensor is good unhook the wire going to the flame sensor put one wire lead of microamp meter in the wire and connect the other wire from the microamp meter to the flame sensor the turn on the furnace for a cll for heat if you get less than .9 microamps replace the sensor.
Mar 08, 2010 | Heating & Cooling
Gas Armstrong Ultra V Tech 91-Is green light supposed to flash?
Installed a new filter and furnace is running great now. The old filter was not that old, but we have been doing some remodeling and I figure that is what clogged it so fast.
Jan 10, 2010 | Armstrong H 67 1PH Bf In Line Circulator...
Furnace Filter
Your chances of getting an answer here obviously weren't good.
If you still haven't located and replaced your filter, post the same question to Armstrong here:
http://www.armstrongair.com/contact.php
Apr 17, 2008 | Compaq Armada 1500C Notebook
Heating & Cooling Logo
192 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
