Question about Hayward Pool & Spa
Heater will not fire I have spark and can smell gas could it be the so called thermo coupler which is actually the control knob I think. By the way the blower does work fine.
  • Don Woodward May 24, 2011
    This heater has a spark ignition like a stove you know snap snap. This seems to be fine checked for spark and it was there and a good shock too. The part I was taking about was made by COTHERM and one end goes into the pipe where water from the pump goes into, the other end has the heater temp control. We were able to get the burner (only one) to light by a torch for a little while then it goes out. Also sound like popping noise until flame goes out. The Heater is a Hayward H1001D.
  • 11,800 Answers
Your heater has indeed a safety system - a thermocouple will engage the main gas valve and keep it open while the flame is lit.
If the flame dies with popping after being lit it's because either:
1- the air - gas mixture is too rich because the air vent on the burner has been partially clogged by dirt and it will have to be cleaned and readjusted.
or
2 - the safety thermocouple no longer powerfull enough to keep the valve open and it will have to be replaced.
While, with some care, you could clean the air vent itself, the replacement thermocouple-valve assembly must be replaced by a pro - you will have to call one.
Posted on May 24, 2011
  • 2,019 Answers
The thermocouple is most definitely not the control knob.
The thermocouple is a thin tube that is supposed to be in the tip of the pilot light.
If it is not heated up by the pilot light, then the main valve will not release the main gas.
What you are probably smelling is the small gas released for the pilot light, because it is not lit.
Follow the procedure on the gas valve, for lighting the pilot light.
If your system does not have a pilot light, and has an electrical ignition system instead, then probably the ignitor is bad. It is a crystalline probe in the path of the gas, that is suppose to glow red hot and ignite the gas. They often crack from water dripping on them. It will have a 2 wire connector, and be mounted in the path of the main gas.
Posted on May 23, 2011
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
My heater made a weird sound, then I heard a hissing sound, when I got to the heater, a flame was coming out the top vent and gas was spewing out. I turned the control knob on top of the heater and it
You need to call a service contractor as soon as possible. You have described a very dangerous scenario and the system should remain off until the unit is repaired or replaced....CALL A TECHNICIAN now.
Jan 04, 2015 | Heating & Cooling
I changed the thermo coupler and the pilot light does stay lit but the burners won't light
If you are referring to a gas fireplace:
  • Make sure the pilot knob is turned from "pilot" to "ON" or it will never run.
  • If the pilot knob is "ON", and the pilot is lit, but the burner won't light, it could be a bad Thermopile. The thermopile is the other safety mechanism in the pilot assembly that controls the burner.
Dec 19, 2012 | Heating & Cooling
Atwood G6A manual water heater had gas flare up around the control knob when lighting the pilot. Unit is about 9 years old so repair or replace? works OK & no gas smell.
The gas control is leaking gas around the knob?
The gas control needs to be replaced before causing explosion and/or fire.
Gas control has identifying marks on side.
Sep 27, 2011 | Water Heaters
Hayward H250 (millivolt) pilot won't stay lit
make sure the flame hits the thermo couple if so then replace it lows has them in the water heater section thermo couple gets hot makes millivolt signal then opens gas valve
May 08, 2009 | Hayward H Series Millivolt 250,000 Btu...
No hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
May 05, 2009 | Bosch & Tankless LP Hot Water Heater
Will not light. Don't know how to take thermostat off. Did take coupler off and clean it. Was hoping to get help on it. It sat for years before I bought it. Can I take it completely off and clean it out or...
Is this water heat a older model or pretty new?I should have read more first.OK ,this is what I think you should do.I am hoping this is gas water heater and you said it sat for a long time. I think you should take the burner and clean it.But don't take the gas valve apart.Then read the direction on the heater to light it. You should fine a bleige incolor knob on top of the gas valve.Turn it to pilot and push down and hold it until you get the pilot lite,once you get it lite hold down for another minute to heat the thermocoupen. Once the thermocouplen red take your hand off it.Make sure the heater is full of water and the water will run out of the hot water lines.If you got all of that then turn knob on the gas valve to the on and stop.there the heater should start burning now.PS.Forgot to tell you to bleed the line first to get all the air out.You can smell the gas when it comes out because it smells like a bad egg. Thanks for picking FIXYA.COM
Mar 17, 2009 | Water Heaters
How do i install a thermal coupler for forced air heater gas
Thermo coupler is held in place with a clamp bracket at the pilot end and a small brass line nut on the other end going into the gas valve.The pilot flame must surround the sensing bu or wrap itself around it Press the pilot button for a few seconds and fire up the pilot flame. Wait a few more minutes and turn the gas vale on for the main burners. If it fires, your set.Good Luck,Ned
Jan 15, 2009 | Reddy Heater RLP100 Portable Forced Air...
Pool & Spa Logo
196 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
