Question about Zhone (6218-I2-200) Router
Red alert light
Can't get it off and get the dsl link light to come on. I've got no/limited (really its none) connection. I have attempted to reset and repower my router but the red light comes right back on.
How did you fix it...i have the same problem
Posted on Jun 02, 2009
  • tpooler Jun 02, 2009
    i have a similar problem... how did you fix it?
I want to know how I can re-set my 3Com 3crwe955275 wireless access point to its default factory settings. Can anyone help?
1 Remove power from the Gateway. 2 Disconnect all your computers and the cable/DSL modem from the Gateway router. 3 Using a straight through Ethernet cable, connect the Ethernet Cable/DSL port on the rear of the Gateway to any one of the LAN ports. 4 Re-apply power to the Gateway. The Alert LED will flash as the Gateway starts up, and after approximately 30 seconds will start to flash more slowly (typically 2 seconds on, 2 seconds off). Once the Alert LED has started to flash slowly, remove power from the Gateway. 5 Remove the cable connecting the Cable/DSL port to the LAN port, and reconnect one of your computers to one of the Gateway LAN ports. 6 Re-apply power to the Gateway, and when the start-up sequence has completed, browse to: http://192.168.1.1 and run the configuration wizard. You may need to restart your computer before you attempt this. 7 When the configuration wizard has completed, you may reconnect your network as it was before
Here on page 85 of the manual
3Com 3CRWE53172 User Manual Forgotten Password And Reset To Factory...
Feb 18, 2015 | 3Com Computers & Internet
D-Link DSL2730U dead after firmware update
Did you do a Hard reset of the Router after the Firmware Update? Try a 30/30/30 reset procedure: http://compnetworking.about.com/b/2009/03/11/the-30-30-30-hard-reset-rule-for-routers.htm Then reconfigure the SSID and the Security Key. AFTER, Shutdown the Laptop remove battery, plug in, reboot. post results.
May 08, 2013 | D-Link Computers & Internet
Why is my embarq 660 series DSL modem box's 1st
Telephone your Internet Service Provider, and have them check that you've paid your monthly fees, and that the DSL-modem at "their" end of your telephone-circuit has not failed.
Try a different DSL-modem, to see if your particular modem has "died".
Check the 2-strand or 4-strand wire from the DSL-modem to the wall-outlet, to make sure that it is properly connected.
Try a different 4-strand wire.
Aug 18, 2011 | Computers & Internet
Modem has red flashing light and no connectivity to DSL
You can try to reset by either pushing the little button or, by unplugging for like 45 seconds and plugging back in. Other than that, get with ATT. They are pretty helpful. You've either have a problem with the phone line pr the modem.
Jun 20, 2011 | AT&T Computers & Internet
The Broadband link light is red.
make sure the PC's have DHCP turned OFF, in services. make sure all are on same network, all have password, Use the connect to internet wizard to make initial connection.
Please go to link below, download your manual, and follow instructions, step by step...
http://www.dsldepot.com/dslmodem.asp?modem=237
Jul 14, 2010 | 2wire HomePortal 1000HW DSL Modem and...
We have a 3CR858-91 3com router and nobody knows it's administration password. I have tried to reset it to the factory defaults using a RJ45 cable (DSL port to LAN port connected) but it does't work (even...
I have same problem. So the solutions is (in my particular case), when you done everything as it written in the reseting instruction. You face blinking LAN/WAN ports and no any activity with Alert LED. After 30 second or even 1 min (i don't relly know do you need to wait or not), i disconnected LAN/WAN ports and connected it again without repowering. Then Alert LED starts to blink slowly every 2 second. After re-applying power it was reseted.
Mar 29, 2010 | 3Com 3CR858-91 Office Connect Cable/DSL...
The red led light on the internet connection on my d-link router is on. i cannot connect to the internet now. i have a green light above the dsl connection and their is one other green light on. i have...
1st: Have you paid your bill?
2nd: Have you power cycled?
Full Power Cycle is as follows:
Turn off all components plugged into the router(Computers, Printers, etc.) Unplug the power from the router. Unplug the data cable(DSL, Coax) going TO the router. Wait aprox. 1 minute. Plug data cable and power cable back into router. Wait about 1 minute. Turn computers back on. Problem Solved?
If not and you're using DSL make sure all DSL filters are in place and that none have come undone. Make sure the phone line is still plugged in. Problem Solved?
If not contact your ISP and ask if they are doing any maintenance in your area that may by effecting your service. Ask them to perform a line test on you. If all else fails ask them to have a technician come out and help solve the issue.
Oct 23, 2009 | D-Link DI-704P Router
Wont connect. power light is red. wireless light is green. i have a 2701hg-b 2 wire. i ve tried diconnecting, resetting, but the gateway remains the same. what do i do?
I've got the same issue, 2 wire claims that whrn the power light is red, the modem is bad and must be replaced. I would try and power the modem from another circuit before replacing. I am replacing mine today
Jun 24, 2009 | AT&T High Speed DSL Modem
Problem with my d-link dsl-2320b modem
try resetting the browser try to change the micro filter turn off the modem and computer power it back and check try connecting the modem to the main telephone socket check if the if ur phone line works fine after all these check the problem still continues its dsl connection problem
Nov 03, 2008 | D-Link DSL-2320B
2701HG-B
Hi. I will not repeat the check the phone line and resetting comments as it's now redundant.
I always have a spare modem as a line tester.
I've seen several 2700HG-B 2wire modem/routers burn out and every single time it's the DSL signal or modem portion that is burnt out. Even if you have two or three phone line surge protectors these 2700s are prone to shorting out unless you have a direct signal splitter DSL setup.
Here are a few things you can try to confirm if the 2700 is no longer functional on the DSL signal light problem.
#1: Turn on (plug in) your 2700 without the phone line plugged in and wait. If the DSL starts flashing red then there is a hardware problem in the modem/router.
#2: Plug the phone line into the 2700 while the dsl light is flashing red. It might take about 3 seconds however it should start to flash green and let it flash for about (usually) three minutes. If it turns red then the 2700 is indeed damaged.
#3: If you can enter into your modem using the http://2wire... and check the connection status. The first two status lines should read attempting to connect and no connection.
Nov 01, 2007 | 2wire 2700HG-B Router (2700HGB)
Zhone (6218-I2-200) Router Logo
636 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
