Question about Ovens
I have an Omega 00651XB oven with a really noisy fan. The oven is just over 2 yrs old. It sounds like the fan is hitting metal?? Can the fan be replaced?
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: NOISY OVEN
Yes, it can be fixed quite simply.
First check that the fan is not catching the cover or grill, if it is not remove panel covering fan and see if the fan blade is loose,on the shaft, they are usually held on by a left handed nut., so to tighten go the oppisite way to what you normally do, if that does not cure it, then your only solution is to replace the fan motor complete.
Plz rate my solution.
Thanks, and a merry xmas.
Posted on Dec 21, 2008
  • 69 Answers
SOURCE: my omega europa oven is not heating up .grill fan
Sounds like a faulty fan oven element. To replace: Disconnect from power (usually easiest to switch off at fuse box). Remove racks etc from inside oven. Remove rear panel inside oven- four screws. You will now see a heating element that goes around the fan- often you see blow mark on element. You need to remove the back panel of oven to access the nuts that hold element in- two nuts, undo nuts, remove wiring from element. New element available from any good appliance repair shop. Reverse procedure to refit. Happy fixing!!
Posted on Mar 18, 2010
  • 106 Answers
SOURCE: oven fan not working so oven not heating up
have the motor checked and replaced if no runnig the oven will not heat as it is a safty measure
on moter the fan blade could have been loose, the motor bearings could be worn out or the fan motor gone kaput
Posted on Jun 15, 2010
Cooling fan makes a rattle noisy when the oven gets hot & after turning the oven off. Very very annoying.
I would suggest taking a look at the fan and seeing if any hardware has come loose. A loose holding screw will cause the fan to wobble in its cage and make noise like the one you're describing. If all the hardware is tight, try a dab of WD40 to get everything moving properly.
May 23, 2015 | Ovens
I bought this on Craig's list. When I turned on the upper oven to bake, it sounded like a fan came on with the blades hitting something and it wouldn't go off until we flipped the breaker box switch. We...
obviously the fan is hitting something as the screws or frame holding it have become corroded and damaged. if u look inside u should be able to remove any plate or covering to have abetter look at the fan
Mar 10, 2015 | Ovens
Omega oven
The cutout stat for the cooling fan needs replacing
Oct 06, 2017 | Ovens
Omega OA 25 oven auto turn off?
Is there a way to change from "Fan Forced Oven" to normal conventional heating oven in an Omega OA25 model?
Jan 14, 2012 | Ovens
My omega europa oven is not heating up .grill fan
Mar 18, 2010 | Ovens
Single oven BT2385SS - took 2 hours to get to temperature after blowing a RCD circuit in the fuse board. Fear that element has gone at 2 yrs and 3 months old.
I think your fear is correct, it sounds as if the heating element is going although you do not say if the fan is working.
Dec 31, 2009 | Baumatic Ovens
Delonghi ESM465ST Oven Noisy Fan
If it is a fan assisted oven, then you are likely to have 2 fans, an external cooling fan, and a fan inside the oven for ciculating the hot air.
So to answer your query, yes it is a noisy fan you are going to have to establish which fan.
It could be a worn bearing, or the fan blade has come loose.
If it is a worn bearing, thge only cure is a new fan.
Hope this helps with your problem.
Dec 02, 2009 | DeLonghi Ovens
Whilst working, my Ariston oven ventilator tangential fan motor at times produces an intermittent metallic noise, as if metal is touching with metal. What could this be, and how can this annoying noise be...
Whilst Working? An explanation of what you were doing would be extremely helpful.
#1) If it sounds like metal on metal, chances are its METAL ON METAL.
#2) Its pretty obvious you didn't make graduate highschool, let me explain this as simple as possible so you don't hurt yourself trying to read it.
#3) Your fan (thing that blows) probably caught a wire (metal string), or was altered slightly and is now hitting a metal ventilator (sponge) which is installed near the fan on this particular model.
Oct 11, 2009 | Ariston Technologies Ovens
Omega Europa 20-1 oven. What do the symbols mean?
Fan symbol - defrost (fan only - does not use thermostat)
Fan symbol within a circle - fan forced oven
3 little triangles - static grill (keep oven door open)
3 triangles above the fan symbol - fan grill (keep door closed)
Oct 03, 2009 | Ovens
Noisy fan in Smeg oven SA398X
Does the fan sound like a squeling or rumbling?Is the fan blade itself scraping on something?
Apr 18, 2009 | GE JGRP17 Gas Single Oven
Ovens Logo
332 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
