Question about Canon Cameras
Change battery sign comes on. I put in new batteries, take a photo, and the change battery sign comes on again. Change batteries, etc., etc. What can I do about this?
  • 1 more comment
  • marianb3 May 23, 2011
    My PowerShot A1100IS Canon camera is two years old. After good initial success in taking photos, I can no longer take photos because now the Change Batteries message prevents it.
    What happened a couple of weeks ago: I put in two new Energizer alkaline AA batteries, take one photo, the Change Batteries message reappears. I can't take a second photo.
    Now the Change Batteries message prevents me from taking even one photo. Sometimes if I take the new batteries out and then put them back in, I can take a photo. But then the Change Batteries message reappears.
    When that happens, again I put in a second set of new Energizer Alkaline AA batteries, take one photo, etc., etc.
    My camera is not exposed to extreme cold or heat.
    I don't have the equipment for rechargeable batteries.
    Thanks for any help. I'm missing good photos.
    Is it the camera? Has something happened to it?
    All the advice I'm receiving is not helpful. It assumes there's something wrong with the batteries. I don't see how that could be when I've replaced batteries with NEW ones purchased from a store with continual turnover. I've done this several times with different brands.
    If you need to know my original problem, here it is: After a couple of years of good service, now I can't use my 2 year old Canon PowerShot A1100IS. Recently, the Replace Batteries message keeps reappearing. I have replaced several times with NEW batteries. Some of them have been just purchased NEW from a store with high turnover.
    Furthermore, remember this is a new problem. I had no trouble with the Replace Batteries message or the same type of batteries. I will make one more try with the batteries, and use another brand.
    In the meantime, are the experts looking in the wrong place? Is there something wrong with the camera? It is disappointing that this is happening. I will need my camera soon for a work project, and I don't know what to do.
    Thanks for any new suggestions that might help.
  • marianb3 May 24, 2011
    Thanks for your interest in helping me. I decided not to pursue this further since help replies were beyond my technical ability and understanding. I mailed my camera to the Canon fix-it people for them to diagnose. Thanks anyway.
  • 4,472 Answers
What is the model of the camera? How long have you owned it and what kind of batteries are you putting in it? Once I have more information I can assist you further.
Thank you,
Lee
Posted on May 24, 2011
  • Lee A.
    Lee A. May 25, 2011
    Sometimes that is the best option. Thank you for getting back to me and good luck,
    Lee
  • Canon Master
  • 17,970 Answers
It may depend on the batteries. I use 2500mAh rechargeable ones, and I can take several shots after I get the warning.
Keep us updated.
Posted on May 23, 2011
  • ZJ Limited
    ZJ Limited May 23, 2011
    I quote additional comments about this wrong...
    It only fixed to put rechargables in. tried to use rechargeable batteries...
    Alkaline batteries stored at "room temperature" self discharge at a
    rate of less than two percent per year. So normally refrigerating or
    freezing them will only help maintain their charge by a tiny amount.
    Hardly worth the effort of chilling them. However, if alkaline
    batteries are stored at higher temperatures they will start to lose
    capacity much quicker. At 85 degrees F they only lose about 5% per
    year, but at 100 degrees they lose 25% per year. So if you live in a
    very hot climate or are storing your batteries in a very hot location,
    it may be worthwhile for you to store your alkaline batteries in a
    refrigerator instead.
    NiMH and NiCd batteries self discharge at a MUCH faster rate than
    alkaline batteries. In fact, at "room temperature" (about 70 degrees F)
    NiMH and NiCD batteries will self discharge a few percent PER DAY.
    Storing them at lower temperatures will slow their self discharge rate
    dramatically. NiMH batteries stored at freezing will retain over 90% of
    their charge for full month. So it might make sense to store them in a
    freezer. If you do, it's best to bring them back to room temperature
    before using them. Even if you don't freeze your NiMH batteries after
    charging them, you should store them in a cool place to minimize their
    self discharge.
    When u use cheaper batteries usually get that message, but when u use
    more expensive batteries It don't and can take 400+ pictures.
    For an example when u use Rayovac Heavy Duty batteries (4 pack costs
    about .99) It can take maybe 20 pictures, but when u use Energizer
    batteries ($3-$4 for a 4 pack) 400+ pictures can be taken. I'm not sure
    why this is, but it is something.....
    Good luck
  • ZJ Limited
    ZJ Limited May 24, 2011
    I quote some tips about this subject...
    "DEAD CAMERA, LENS OPEN - If the batteries run down completely while the
    camera is still open, it may not start up again when new batteries are
    installed. But if you remove the memory card, then install the new
    batteries, when you turn it on it should come back to life. Error E30
    means you don't have a memory card installed, so turn it off, slip in
    the SD card and turn it on one last time."
    If you're still having problems even with rechargeable batteries, you may have not set the camera's menu setting to recognize NiMH rechargeable batteries. Some camera brands (Samsung in particular) have a setting in the camera's menus to differentiate between Alkaline and NiMH batteries. If the menu is set to alkaline, the camera may in error report a low battery status with NiMH batteries. To correct the problem, merely find the page in the camera's menu to set the battery type, and reset it to rechargeable batteries.
    The next thing to try is examine both the battery and flash card door.
    There's usually a little switch on both doors (note some SD card doors
    do not have this switch) that activates when the doors are closed. If
    they don't, the camera won't start to prevent damage to the flash card
    or camera startup sequence. For most cameras its usually a little piece
    of plastic on the door that pushes in on a pin switch when the door is
    closed. Closely examine both doors to try to identify these switches. A
    lot of times that little plastic nib wears down or breaks off, but can
    easily be jury rigged with a small glued-on replacement.
Why does my camera keep saying battery exhausted even when I change the batteries?
If batteries leaked in the camera the connections IN the camera may be dirty. Putting in a new battery takes care of the battery connection but not the camera connections. This is why it is very important to take out batteries when you are done taking photos. When you want to shoot again you put the batteries back in and set the time and date. You MAY be able to clean the connections with a pencil eraser. If you use a pencil eraser please blow out the dust from the eraser. If you are positive the camera then I cannot help you here.
Jul 20, 2014 | Nikon COOLPIX Cameras
Borrowing my friends fujifilm instax mini 8 and a photo got jammed as it was coming out. I managed to pull it out as well as the rest of the photos still in the camera, but after putting a new pack of...
First, take the photo pack back out, and then change the batteries in the camera. Make sure the photo pack is pressed down and not misshapen at all. Put the photos back in and try again.
Mar 17, 2014 | FUJIFILM instax mini 7 Digital Camera
Battery light
Have the charging system checked. The alternator may need testing.
Jan 29, 2014 | 2003 Buick Regal
Warning battery light
It means that you have not been keeping the battery posts clean, the belt to the alternator tight etc. If the battery has died once real bad it may need replacing. It is a custom to change the voltage regulator when you change a battery. The battery has to be carefully chosen for size, shape, internal resistance etc that will match your car and your charging system so don't put just any battery in it. A new battery will ensure cold weather starting and is a good idea since winter is coming. We Canadians can testify to that. :)
Oct 15, 2013 | Mercedes-Benz ML320 Cars & Trucks
The batteries died while I was taking photos. The lens did not retract. I changed the batteries and it would not come on. Changed the batteries again and got a message 'Change batteries'. I hooked it up to...
I don't know if you have a voltage meter, but you do, check the voltage of the batteries, you just tried. I have seen many "new" batteries that aren't good, and had similar problems as a result.
Even so I'd suggest a brand new set of Duracell or Energizer batteries, BUT.....
Why aren't you using NiMh rechargables?????
They have much more power will give you over a year of picture taking even if you shoot hundreds of pictures a day. All you need to do is make sure you charge them about once a week, even if you don't use the camera.
Sep 07, 2013 | Canon PowerShot SX10 IS Digital Camera
Canon PowerShot A480 won't take photo. Pressing on button camera on then pressing silver button to take photo when pressed down screen turns black no picture taken. Batteries new. This is the story; camera...
its just a matter of batteries...some are not powerful enough to operate the camera ....Try to change them and buy some real good ones..like Duracell or Tatra...do not make any compromises when buy the batteries...get the best cause these kinda cameras really require powerful ones...or ...try to get a set of rechargeable ...
Jun 20, 2010 | Canon Powershot A480 - Silver Digital...
When putting in new batteries the "change battery" sign comes on
try new Alkaline batteries or fully charged NiMH batteries, you may need to clean and adjust the springs in the battery compartment
this tips may give you more details
http://www.myfixtips.com/blog/digital-camera/why-my-camera-keeps-saying-%e2%80%98change-battery%e2%80%99-even-with-new-batteries-176.htm
May 14, 2009 | Canon PowerShot A520 Digital Camera
Replace the battery and starter will not turn over
You should have a Fuel Shutoff in the Trunk. Make sure that it is not Tripping when this Happens.
Jan 12, 2009 | 1995 Mercury Cougar
Casio Qv-r41
That's why whoever sold it to you, it's broken. Digicams are cheap enough nowadays to purchase new along with cheap large storage memory cards which comes bundled during sales.
Nov 06, 2008 | Casio QV-R40 Digital Camera
Cameras Logo
32 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
