Question about HP dc7100 SFF PC Desktop
After update the windows i restart my computer but the bluse screen of HP come and come restart and restart i press f8 and after i press stafe mode put nothing happen the blue screen of HP come
    Guru:
  • 731 Answers
Repair the Operating System.
  • Insert your Windows XP CD, save the bios settings and exit. Soon "Press any key to boot of CD" will appear on the screen, hit the space bar to continue.
  • Now setup will inspect your hardware and software, it then will load various files required for the repair. Just wait and be patient, this may take a few moments.
  • Soon a menu will appear (as pictured below), press enter to continue.
  • Now the "End User Agreement" Press "F8" if you agree, "ESC" if you don't.
  • You will now have to select the installation you wish to repair. Usually there is only one, but sometimes, there may be 2 or more (i.e. you have done a parallel install to resolve a problem), use the up/down arrow key to select the install, and then press "R" to continue.
  • Setup will now examine the disk be patient, it can take a few minutes.
  • Setup will go through a percentage - 1 to 100%
  • A screen will soon appear. Press "F3" to continue
  • Now setup will reboot system, wait 15 seconds or just press enter.
  • Now it is time to see if this has solved your problems.
Regards,
Riztech
Posted on May 23, 2011
Microsoft Windows 7 ultimate 64BIT Operating System Software in the middle of os automatic shutdown
Sounds like some update was pushed and will be restarting without your intervention. I would shut the computer and power up and see if it continues to update. It should prompt you to manually choose not to restart. If it cycles again without your permission, press CTRL - BREAK to stop it. Reboot into safe mode - press f8 when you reboot the machine and before it gets to the windows logo. Your BIOS Screen will appear first, then start the Safe mode fast... Press F8 or FN-F8 continuously. Once inside Safe mode... reboot normally and you should be ok. Read this as it could also help..
Usually Windows is OK about notifying you but for this last update I had 5 different people all call me VERY upset that they had lost important work because Windows Updates just hijacked their computer and started installing and then restarted WITHOUT NOTICE.
At the very least if there is a user logged in their should be a window that REQUIRES a "yes" click before an auto-restart is performed.
I have the Group Policy Set "No auto restarts when users are logged in" but I am running Windows 7 Professional and it isn't so easy with the other versions.
For those who don't have Windows 7 Pro/Ultimate to run gpedit.msc - Computer Config-Admin templates-Windows Components-Windows Update you can use the following - save in Notepad and rename to a something.reg file and double click.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU]
"NoAutoRebootWithLoggedOnUsers"=dword:00000001
"AutoInstallMinorUpdates"=dword:00000001
Aug 25, 2015 | Microsoft Computers & Internet
Black screen
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Sep 19, 2013 | HP Pavilion dv6000z Notebook
My hp mini have black screen when i turn it on nothing appears on the screen
Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen.
Sep 14, 2013 | BattDepot.com HP Mini 210-1041NR 4400 mAh...
Oxeoefoooe
Method 1:
I would suggest you to check of you can open the system recovery options without using the installation disc- a. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer using the computer's power button. b. Do one of the following: If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer. If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8. c. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press Enter. If Repair your computer isn't listed as an option, then your computer doesn't include preinstalled recovery options, or your network administrator has turned them off.
c. Select a keyboard layout, and then click next.
d. On the System Recovery Options menu, click a tool to open it. Refer the below link for more information -
What are the system recovery options in Windows 7?
http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7 Method 2:
If the repair option is not present in the advanced boot options and you are unable to perform the recovery then in that that case there are no options other than getting the installation disc or contacting Hp for assistance.
The error code you are getting while restoring to factory settings is some error associated with the hardware for Hp computer. You might need a tool or some hardware update from HP to get over the error.
You may use the below link and check diagnostic tool update assists you resolve the issue -
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=pv-77569-1&jumpid=reg_R1002_USEN For further assistance you may contact HP using the below provided link -
http://welcome.hp.com/country/us/en/support.html
Mar 05, 2013 | HEWLETT-PACKARD COMPAQ PRESARIO CQ5700F...
Error code on compaq presatio desktop oxeoef000e
Method 1:
Mar 05, 2013 | Computers & Internet
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    • Search www.microsoft.com for terms in error message.
    • Search www.hp.com for terms in error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
      • Select Disable automatic restart on system failure to view error message.
      • Run Repair Your Computer .
      • Run Last Known Good Configuration .
      • Select Boot into Safe Mode and then select Run a Microsoft system restore .
      • Select Boot into Safe Mode and then select Uninstall recently installed programs .
      • Select Boot into Safe Mode and then run Windows Update .
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
    • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
    Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
    Oct 09, 2011 | HP Mini 1000 Netbook
    MY LAPTOP WENT OFF DURING UPDATES NOW IT WONT FINISH LOADING, it comes up update 3 of 3 then restarts and says same again keeps doing it not letting me in to lap top anymore seems stuck on updates
    Hold F8 while booting to go into safe mode, or last known good configuration. Then, preform the update from there, and that should fix your problem.
    Feb 28, 2011 | Acer Computers & Internet
    I have hp pavilion dv4 1070ee. window vista. i was trying to update my bios but everthing went blank. i trun off the laptop and try to turn it on agian but still bank screen. i don't know whether the...
    Turn on and keep pressing the F8 key
    If nothing shows up on the screen after a minute shut down, restart & kep hitting the F10 key
    A recovery screen should appear by pressing one of these keys
    If the screen appears pick a recovery job to restore your computer to a day when it worked well last
    Jun 30, 2010 | HP Pavilion dv4000 Notebook
    Hp pavilion dv5, flickering screen problem mostly when 26" external monitor is connected, Using Windows Vista 32bit
    First restart the computer and tap f10 key on keyboard to enter bios, and check wethere the screen flickers or not you can even try to tilt the screen and check as the drivers doesnt works in bios screen ... if the screen flickers then it is a hardware issue .. if it doesnt then log on to safe mode with networking by pressing f8 as the notebook restarts and then go to device manager by typeing device at the start search and the uninstall the video driver and then reinstall it from hp.com support and drivers ..issue will be resolved if not then do a bios update from hp.com, support and drivers.
    Apr 29, 2010 | HP Pavilion DV5-1000US Laptop
    My hp notebook (laptop) cant start... when I open my notebook the following in sequence appear: ''window is loading files.... next there is ''A rectangular figure with moving small vertical lines from left...
    Ok, at bootup, press F8, choose Boot up in safe Mode, when next window comes up, it ask if you want to go to desktop OR System restore, Choose system restore. now when next window, like a calender comes up, simply choose a date BEFORE you had problems, follow instructions, and it will reboot,this should get you back to working.
    Mar 26, 2010 | HP Pavilion dv6000z Notebook
    HP dc7100 SFF  PC Desktop Logo
    49 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
