Question about Cobra Li 6000-2 WX VP GMRS/FRS Two-Way Radio
One of my Radios will not transmitt to the other one. All channels are set the same on both radios. I had both radios put away for a few years and were working fine at the time.
5 Suggested Answers
  • 14 Answers
SOURCE: what channel do I put the radios on to charge it
Turn the radios off when you are charging them. The charger may not have the current flow to effectively charge the radios when they are on. If you need to monitor a channel, try charging them one at a time.
Regards,
Longshorts.
Posted on Jul 24, 2009
  • 713 Answers
SOURCE: Nedd to reset radios back to factory settings.
Hi,I think the problem is with your tone coded squelch (CTCSS). Your radio channel is like a telephone party line. If your CTCSS is not on, everytime you turn your radio on you will hear anyone on that channel that is close enough to hear.
If you are trying to use these radios for serious communications, that will drive you nuts to hear everybody else talking but not about what you need to hear. To try to mitigate this problem, CTCSS was created. There are 38 different codes. If you for example set your unit to operate on code 11 and your other unit is set to operate on code 12, you could not hear each other.
Now let's add a third unit set to not use CTCSS at all. Neither one of you will be able to hear this third unit but he can hear both of you. Now you set the second unit to code 11 like the first unit. Now you will be able to hear each other. The third unit will still be able to hear both of you but since he is not transmitting code 11, you still can't hear him.
If you are hearing some traffic, it is because they have their CTCSS set to the same code that you are set to. Look in you operators manual for CTCSS Privacy Codes. Set your radios accordingly and your problem is solved.
if you still insist on resetting your device,you can get e full description on how to do this in your users manual,if you don't have one you can get it for free at;www.manualsonline.com
Posted on Apr 25, 2010
BillB-SA
  • 2761 Answers
SOURCE: Manual
Channels 8 through 14 are low-power FRS license-free channels. Operation on any other channel requires a GMRS station license issued by the FCC. Unauthorized/unlicensed use of the GMRS frequencies can result in stiff fines and confiscation of radio equipment.
Bill B
WQJV930
Posted on Apr 27, 2010
pctech1
  • 1940 Answers
SOURCE: Have 9 COBRA microTalk 2-way
Just in case these radios have been modified, or have lost there settings, please perform the following:
All radios must be tuned to the same channel and privacy code to communicate. To successfully communicate using a privacy code, both the sending and receiving radios must be tuned to the same channel and to the same privacy code system (CTCSS or DCS) and privacy code number. Each channel will remember the last privacy code system and number you select.
The privacy code 00 is not a privacy code, but allows all signals to be heard on a channel that is set to 00 on both the CTCSS and DCS systems.
Channels 1 through 7 are shared with FRS/GMRS. Channels 8 through 14 are FRS only.
Channels 15 through 22 are GMRS only.
To select a CTCSS privacy code:
1. After selecting a channel, press the Mode/Power button until the CTCSS icon appears and the small numbers next to the channel number flash on the display. If DCS is turned on at the channel selected, the display will flash the CTCSS icon and "OFF." To switch from DCS to CTCSS, press the Channel Up or Channel Down button while the display is flashing "OFF." The display will then show the small numbers flashing and you will then be able to proceed to step 2.
2. Press using the Channel Up or Channel Down button to select a privacy code. You can hold the Up or Down button for fast advance.
3. When your desired CTCSS privacy code is displayed, choose one of the following:
a. Press the Mode/Power button to enter the new setting and proceed to other functions.
b. Press the Lock button to enter the new setting and return to Standby mode.
c. Do not press any buttons for 15 seconds to enter the new setting and return to Standby mode.
To select a DCS privacy code:
1. After selecting a channel, press the Mode/Power button until the DCS icon appears and the
small numbers flash on the display (01 through 83).
2. Press using the Channel Up or Channel Down button to select a DCS privacy code. You can hold the Up or Down button for fast advance.
3. When your desired DCS privacy code is displayed, choose one of the following:
For Cobra Customer Assistance:
9:00 a.m. to 5:00 p.m. Eastern Time, Monday to Friday
(except Holidays) - (514) 683-1771, ext. 2-264 (phone).
Posted on Jun 26, 2011
Does the motorola t4500 have an eliminator
Setting a Channel
Your radio has 22 channels. Channels 1-7 and 15-22 are 1 watt. Channels 8-14 are
0.5 watt. When the radio is on a 1 watt channel, displays. When the radio is on
a 0.5 watt channel, displays.
1. With the radio on, press . The current channel flashes.
2. Press or to set the channel.
3. Press to save the channel setting. You have a pretty straight forward Low wattage FM Walki/Talki
I would have them returned or replaced.
If you can not transmitt on one to the other
Channel
Channel
May 02, 2014 | Motorola Radio Communications
Crv radio hack
These are not ham radios, they are intended for use between two people, they are sometimes called family radios. If another radio is on the same channel you should be able to communicate with them however the range is limited to a few hundred feet depending on climate conditions.
You might consider either a CB or amature radio, you will have much better luck.
Apr 26, 2014 | Uniden Radio Communications
Would like codes for the area of 56573
If you need a S.A.M.E. code, NOAA does these by county.
The zip code of 56573 is part of the county of Otter Tail, Minnesota, assuming no typing errors are involved. Thus the S.A.M.E. code is 027111 . Several transmitters cover this region 162.400 (channel 1), 162.500 (channel 5), 162.550 (channel 7), and 162.525 (channel 6) . However, the best transmitter choice is probably Channel 5 (162.500 WNG680) from Fergus Falls. The second best choice for Perham, MN is Channel 1 (162.400 Detroit Lakes WXM64 but it is a low power transmitter). See the link to the coverage map below.
All S.A.M.E. codes are available here: http://www.weather.gov/nwr/indexnw.htm . Click on your State and then look for your county. The Minnesota S.A.M.E. codes are listed here: http://www.weather.gov/nwr/CntyCov/nwrMN.htm . To see the coverage zones for each of the transmitters, see http://www.weather.gov/nwr/Maps/PHP/minnesota.php (the link to the coverage map is also on the County S.A.M.E. code list page on the left hand side of the page.
Otter Tail is a large county and none of the transmitters seem to cover every inch. So you will need to try your weather radio and see which transmitter gives you the best reception of tests, watches and warnings.
I hope this helps.
(who has several weather radios in the house. They are in different areas and set to receive different transmitters. I live near a county line and the signal strength depends on where in the house you are. We tried using an external antenna. We received the signal from a transmitter from another state at the desired frequency and didn't receive the local warnings.)
Aug 08, 2011 | Midland WR-100 Weather/RDS Radio
Got a midland weather radio problem wr100 series. all county codes in and channel set. was working for awhile and now no alerts at all. keeps now saying check reception.
Turn your radio off and then on again. Then press the weather/snooze button. Do you hear the broadcast from your local transmitter? Check NOAA to make sure the station is broadcasting (not down for repairs). Try setting the radio to a different transmitter that covers your area.
You may need an external antenna for the radio (http://www.midlandradio.com/Weather-Radio-Accessories.BPE/18-259W ). Beware: when you use an external antenna, you may receive a broadcast from a different transmitter (farther away). In that case, the weather alerts for your county will likely not come in.
I hope this helps.
(we have two weather radios that are on full-time. The one set to a secondary transmitter does not receive the S.A.M.E. test signals or watches. (It can't be positioned to receive from the primary transmitter clearly.) It does receive warnings for the county correctly. The on/off routine has to be done every few weeks since it doesn't get the test signals. We tried an external antenna and kept getting transmitters from other states and missed tests, watches and warnings. Fortunately our main weather radio does get the primary transmitter and gets the tests, watches and warnings.)
Jun 27, 2011 | Midland WR-100 Weather/RDS Radio
Can the gmrsx1 talk to the hjc-frs
Yes, the Chatterbox is a GMRS / FRS Radio transmitter. If both radio transmitters are tuned to the same channel/subchannel, they should have no problems interacting.
Jan 31, 2011 | Chatterbox GMRS-X1 (15 Channels) 2-Way...
What channel should i set my motorolla walkie talkie to get the best distance? It seem not to wok beyond 1/4 mile on channel 3.
You didn't mention a model number, so I don't know if your radio is an FRS or FRS/GMRS model. GMRS channels have more power output than FRS does, but GMRS also requires a license for operation. Other than that, the frequencies are so close together that there is no distance advantage gained by changing channels. The manufacturer's distance claims on these radios are pure advertising gimmicks - the radios are line-of-sight only, so if there's anything between the transmitter and receiver, the signal will not get through.
Nov 10, 2010 | Motorola Walkie Talkie 2-Way Radio
Channel scanning fucntion won't work on my new Oregon Scientific TP329 Two Way Radio. Keeps scanning without finding a valid signal. The radio works when I set the channel randomly but so far I can't find...
Make sure there is a transmitter "on" somewhere along the way, otherwise it would not stop scanning. Try keeping the PTT pushed on the other set whilst you scan.
Jul 10, 2010 | Oregon Scientific TP329 Two Way Radio
Hello, I dusted off my old Cobra 2000 GTL and plugged it into the wall and it will not power on. The clock is on and adjustable. It was last working before I boxed it up a few years back. Is this a known...
Try this, plug it all up and turn it on, let it set over night, then try it, after a radio has been put away for a while, the capacitors lose charge...hope this was helpful....
May 09, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
On my scanneri have trunking what is that
trunking is a system where many radios use a few channels, the radios scan through the channels and find one that is not busy, then when you key up the transmitter it sends out a signal to the other radios in the group and switches them to the same frequency. There are at least 3 different trunkings systems that i know of, maybe more by now, but this is a basic explanation of how they work.
Dec 29, 2008 | Uniden BC60XLT Handheld Scanner
Delphi MyFi SA10113 XM Radio
try doing away with the external fm transmitter and use the one thats built in to the delphi you just go into settings and set it to a station that has no channels and tune it in
Jun 13, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Cobra Li 6000-2 WX VP GMRS/FRS Two-Way Radio Logo
43 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
