Question about Craftsman Garden
Craftsman DGS6500 with 54" precision
  • kevin_c_leon May 23, 2011
    Manual says front should be lower than back when mower is in highest position? I'll check if clean underneath.
  • kevin_c_leon May 26, 2011
    yes
  • 318 Answers
The only thing that makes sence is that some how te blades are the wrong ones they are not long enough . raise the tractor up set the blades so they are in line with each other they should not have more then a 1/4 inch gap if it's more you have the wrong blades.
Posted on May 23, 2011
  • 4,070 Answers
When the mower deck leaves a strip, the most common problem is in the set up of the deck. The instructions for installing and leveling the mower deck are in the owners manual.
The major reasons for leaving strips of grass are not having the front of the deck 1/8-1/4 inch higher than the rear and mowing at a speed that is too fast.
Make sure the new blades are the correct size. The ends should be about 1/4 inch apart when they meet.
Spinning to slow [bad belt, motor turning slow, belt out of adjustment]
Is the inside of the deck clean?
My 72 in deck looks like the blades are not long enough leaves a line between blades
If there is a line of uncut grass,, when you cut in a straight line, then at least ONE of your blades is too short.
Sep 20, 2017 | Garden
I have a Craftsman SL3500 42" riding lwan mower. the two blads make uneven paths ans the left blade makes a cut about 1/4" lower than the right blade. What do I do?
You should be using a up lift blade it will help by sucking up the grass to be cut. You should have an adjust on both sides of the blade deck . As for the strip check to see if you have a wheel behind the mower deck. If you do it might be the cause for mower leaving a strip uncut . Sears has been noted for putting wheels in the path of the blade area and smashing the grass down . That is also why I suggest to use an up draft blade it should **** the grass back up again so you can cut it.
Oct 07, 2013 | Craftsman Garden
Uncut grass in center & higher grass cut on right.
Hi, this may sound obvious but make sure the new blade is the same type as the old one and make sure it is not fitted upside down. Spin the blades and make sure the tips are level with each other, this will tell you if the deck is straight where the blade spindles mount. Regards Phil.
Jun 24, 2012 | John Deere Garden
I have 11 years old Murray (42 inch deck). After deck adjustment still leaves uncut portion of the grass between blades. Should I exchange the blades (I have not done it for many years, but I sharpened...
On a two blade deck, such as yours, there is generally an overlap between the cutting coverage of the blades so that you do not leave a mohawk. This does not work well on turns however, and the sharper the turn, the more grass is left. Overcoming that issue brings you up to a 3 blade deck. If your mower is leaving a strip of uncut grass while cutting in a straight line, somehow you are running blades for a smaller deck, thus there is no overlap. The mandrels are offset, one slightly in front of the other so that the blades do not hit each other. I would measure under the deck and see how long a blade could be and still fit within the deck and not strike the other blade, then ask a parts store to sell you something longer than what you have now.
Oct 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
It leaves the center uncut
i think i would raise the whole thing up on jack stands and take a look at the bottom of the deck. do not start it of course, but the problem should be evident. 42 inch generally means only 2 blades which are cutting on the outside leaving you a mohawk. so something is blocking the grass from being cut in the center. if it is by chance a 3 blade deck , then something is wrong with the center blade, if it is there i would guess a broken key.
Aug 23, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
Why does a craftsman 42in lawn tractor leave a uncut streak in middle
Is the uncut portion roughly 10-12" wide? Burning rubber smell? Screaching?
Chances are the middle blade isn't spinning.
Shut everything down. Key out.
Check for obstructions. Above and below. Blade and pulley.
If none, you're going to need to break it free. A piece of large bore PVC can be fit over the blade for leverage and safety.
Clear and grass or debris from the pulley shaft. You know, all the normal stuff.
Then try it again
Best regards
Aug 14, 2010 | Craftsman Garden
I have a Craftsman Lawn tractor. Blade leaves grass uncut.
Hi Tom,
Check your spindle shafts for loose play. If your bearings are worn out and sloppy, the belts pull the spindle to one side and an angle cut results... close cut grass at outer edge and high in center will leave this grass trail you are describing. I'd replace the bearings next year for sure.
I hope this helps... Good luck!
Oct 04, 2009 | Garden
I have a 19hp craftsman 42 deck. It has two blades. It does not cut the grass in the center. It leaves a strip uncut. What adjustment should I do
You may be running too fast on ground speed for the mower deck to cut completely. It may be time for some new blades. The blades may be worn down to where they are shorter than when they were first put on.
Sep 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
42 inch craftsman. Replaced bades and now have a row of uncut grass in the center of cut.
OOPS! I hate to tell you but you most likely put new blades on that were too short. Check your manual and get the proper length blades. If you still have the old ones, check them against the new ones and you will see that they are shorter resulting in the uncut grass in the center.
Jun 23, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
A row of uncut grass left between blaces when mowing
THE answer that FINALLY worked for me. Torque the bolt that holds on the blade to the recommended torque specified in your owners manual (for my Exmark this torque is 120 ft-lbs). When I first used the torque wrench, i was quite surprised by the amount of addional force I needed to apply to reach 120 ft-lbs Exmark blades have a round blade hole with a washer and therefore, relies only on friction provided by torquing bolt to the proper torque to prevent slippage so that the blade rotates at the same speed as the spindle. When slippage between the blade and spindle occurs, blade tip speed slows leaving uncut grass.
Note: this solution will NOT work for mowers with a blade and spindle design which uses a positive means (e.g., a star shaped hole on the blade) that assures the blade rotates at the same speed as the spindle with no slippage.
Jun 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
243 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
