Question about Grundfos 599388 Timer for Series UP Circulator Pumps
How do I set the timer to turn off in early morning hours
You posted under grundfos recirculation pump.
Open following general guide for setting timer:
http://waterheatertimer.org/pdf/Guide-for-setting-recirculation-system-timer.pdf
Open following link for recirculation system information including illustrations and some manuals:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 23, 2011
How do you set a hager eh010 timer
switch the timer off or disconnect
turn the thermostat setting to low
that way it will not work when the solar section is producing enough hot water and when the temperature in the hot water system falls below the thermostat setting it will switch on the power
usable hot water temperature is around 60 degrees c and anything over that will scald the skin within minutes
low thermostat setting is 55 -65 degrees c
Aug 06, 2016 | Solar Hardware & Accessories
Brinks 42-1009 ez vacation timer instructions
The Brinks 42-1009 EZ Vacation Timer is preset with 7 full days. You cannot choose when it goes on and off.
To set, spin the dial (clockwise only) until the arrow in the upper right of the center face is near the current day and time. Plug everything in and switch the upper tab to the right. On certain days, it will turn on in the early morning as well as evening or late night.
You cannot choose when to turn the light off. However, if you are home, you can turn the light on by switching the upper tab to the left. Remember to switch it back to the right in order to activate the timed on/off periods.
Jun 10, 2012 | Hampton Technologies Brinks Timer
Can I set the time of the day that a Hoover "Frost
Yes you can. if you know where the defrost timer is and how to turn it all you have to do is get up in the middle of the night say 3 or 4 in the morning and set the defrost timer, it will defrost that time everyday. Hope this helps. Wally
Sep 17, 2011 | Hoover Refrigerators
The instructions are not very clear on my new UPM ET420C Electronic Outdoor Timer. What I want to do is have the time turn on power everyt morning at 3am, run for 2 hours, and stop at 5am. Could you tell...
Using the right & left arrows, go to CLOCK to set the current time & day.
Press SET
Using arrows, set the day, press SET.
Using arrows, select the hour, press SET.
Select the minute, press SET.
Select the second, press SET.
Using right arrow, press once for program 1.
Press SET.
Select day, press SET.
Select hour, press SET.
Minute, SET.
Repeat this for every day you want this program, five days or seven days,
Programs 1-5 or 1-7.
Gary, good luck, these instructions are difficult.
May 27, 2011 | UPM Programmable Outdoor Timer
I set my outdoor timer for 6 hours after dusk and the christmas lights go off after about hours. I have another set on the other side of the railing plugged into a seperate timer (same brand) on the other...
You see the idea that many folks miss >> that nearby lights cause outdoor timers to blink and not work.
Test if neighbor's lights are the problem or if timer is defective:
Put black tape over photo eye on timer.
I test timers.
About 5% of the timers I receive factory-fresh are defective out of the box, and a large number of good timers go bad within a year or less.
Most timers have no warranty or limited 1 year warranty.
Add a comment and let me know the outcome and what brand and model timer you have, for my notes.
Dec 14, 2010 | Hardware & Accessories
Gate stays open and does not close unless timer switch is turned off
I have a brand new Ramset 300 electric gate opener. My problem is in the early morning when the loop opens the gate it will not close unless deactivated manually. It does not happen later in the day with my GMC truck but happens early in the am with my husbands Toyota Prius. Please help. What can be the problem?
Jun 19, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
Alarm setting??
Try "playing" with the CountdownTimer feature: Setting the CountdownTimer 1. Press TIMER ON/OFF to enter timer setting mode. The red TIMER icon will flash on the display. 2. To select countdown time, use the TRK (SEARCH?TUNE) / buttons to select the correct time. Press and hold to fast forward or fast reverse countdown time. 3. Press TIMER ON/OFF again to activate the timer. The unit will beep twice to indicate countdown has started. The red TIMER icon will remain lit during countdown. 4. Press TIMER ON/OFF to turn timer off at any time or after it has sounded. good luck
Nov 05, 2005 | GE Slim Spacemaker 7-5295 CD Shelf System
Grundfos 599388  Timer for Series UP Circulator Pumps Logo
137 people viewed this question
Top Grundfos Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Grundfos Hardware and Accessory Expert? Answer questions, earn points and help others
