Processor fan is very noisy from start up to all the time I am on line.
    Novelist:
  • 123 Answers
Good day , you may need to power-off her PC, open it up, and give it a good cleaning with a vacuum cleaner. If possible, after you've got her PC open, and before you clean it, turn it back on so you can figure out which fan is causing the noise problem (many PCs have more than one fan). If it's the CPU fan, then you're going to want someone who is comfortable and experienced with removing it and replacing it with a new one, because it is EXTREMELY important to get 100% physical contact between the CPU chip itself and the cooling fan/housing that is attached to it, or the CPU is going to overheat and destroy itself within seconds of being turned back on. If the noise turns out to be from a normal case cooling fan (3-5 inches across), you can try cleaning it really well to remove any dust, and see if that fixes the problem. If not, you can buy a replacement fan of the appropriate size at pretty much any PC store for $5-$20. It takes 5-10 minutes to unscrew the old fan and install the new one, and just use the same electric wire from the old fan for the new fan.
If the noise turns out to be from the computer's power supply, you cannot repair it, so it needs to be replaced. I would recommend either replacing it yourself, or having someone who has done it before replace it for you. There's usually only 4 screws that hold the entire power supply box in the case, and then you also have to unplug the power cords that go from the power supply to the hard drives, floppy drive, CD drive, other internal peripherals, motherboard, and fans. Carefully remove the entire power supply box from the PC case, being careful to not scrape it or bang it against any of the memory cards or other internal components. Take the noisy power supply with you to a discount computer store and find a new power supply that's the same physical size and at least as many watts as the current one (usually 350-500 watts). If you go with a generic power supply, it will probably cost around $30. If you go with a name brand, high-wattage power supply, it can cost $100 or more. Hope this information help you in resolving your issue. Have a great day.
Posted on May 23, 2011
Cpu fan speed
1. Check if something like power supply wire have bangin in there.
2. Clean : Try to use lighter fluid to loosen and clean the dirt inside the processor fan but first disassemble the fan from the heat zinc of the processor. flip the fan and you will see the bearing and motor, drown it with fluid, and rotate the fan so the dirt will loose, after some spins, try to spill the fluid inside the fan. then assemble and test.
Dec 26, 2013 | ASUS P5P800-VM Motherboard
Fan is too loud
Every computer comes built with a processor cooling fan system.
The fan's main function is to keep the processor from overheating.
After long periods of use, processor fans can start to malfunction.
If your eMachines computer's fan is excessively noisy, it will need some maintenance.
If you don't deal with a noisy fan promptly, your computer's processor could overheat and cause significant damage to your motherboard as a result.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Power down the computer.
Disconnect all cables and peripheral devices from the computer's back panel.
Rotate the computer so the back panel is facing you. Lay the computer on its left side.
Remove the Phillips thumb screws that fasten the right side access panel to the computer's frame.
Remove the side access panel from the computer to reveal the motherboard and all internal components.
Locate the cooling fan assembly near the center of the motherboard.
Remove all Phillips screws fastening the fan to the motherboard.
Disconnect the fan's power cable from the motherboard.
Then lift the fan out of the computer.
This will reveal the processor chip.
Place the fan on a flat work surface with the label sticker facing upward.
Use a thin, flat-head screwdriver to peel away the label sticker from the fan.
This will reveal the access hole to the fan motor's bearings.
Apply one to two drops of lightweight mechanical oil into the fan motor's bearings.
Replace the fan's label sticker.
Use a can of compressed air to spray the dust and debris from inside the fan blades.
Place the fan back into the motherboard on top of the processor chip.
Replace the retention screws and reconnect the fan's power cable to the motherboard.
Replace the side access panel and its two retention thumb screws.
Place the computer tower vertically, and then reconnect all cables and devices to the computer.
Nov 18, 2013 | eMachines EL Computers & Internet
Fridge so noisy constant
one of the known proplems of noise in refrigration is the fan.try checking the fan and oil it. the compressor cannot be noisy.u can start by uncrewing the power line to the fan and see whether the noise is still there
njeru .embu -kenya
Oct 24, 2012 | Refrigerators
Noisy computer fan
If its a loud "whirring" noise almost grindy...you need to replace that fan...it's about to fail. if it's a vibration type of noise, you should try tightening the screws first...if it's coming from processor fan, replace it before you fry your processor...
Jul 03, 2012 | Computers & Internet
Why my motherboard did not start and have noisy sound coming from my processor what might be the problem?
If your processor fan is not functional at the correct RPM this could cause your system not to function.. The noise could be a cable rubbing against the fan...
Feb 11, 2011 | ASUS P4PE Motherboard
Today i started up my Asus N50V Laptop up and the fan is running continually now, I rebooted it and still no change. It never has done this before?
It is normal for the fan to kick in to cool the processor, but it sounds to me like the CPU fan and the air vents need a good cleaning.
Noisy fans and them running for a length of time means that its having to be on more to keep the processor cool.
Other causes of the fan being loud and on constantly is gaming and heavy programs. The more the processor has to work the hotter it will get, thus the fan being on all the time.
Have a look at your air vents and the CPU fan for dust. If you see any dust then you will need a can of compressed air to blast through the vents and CPU fan blades free of dust.
Removing the dust from the machine usually quietens them down.
Regards.
Nov 16, 2009 | ASUS N50Vn Notebook
Noisy fan - ~Dell Dimension 5150 (3 years old)
This issue is discussed here: Click Here
As for the fan check it inside the pc sounds like you may be missing a screw
Mar 07, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Noisy fan
the 100% noisiest fan is the hardware things and the svchost is the software problem...first thing you can check the svchost to remove the malwarebytes or trojan remover..second things you can fix the noisiest fan by cleaning the fan or replacing the fan.
My hp pavilion a6110n product nogg781aa .Has anoisy cooling fan .How do I chang it.
If it's the processor fan that's noisy you can purchase a replacement. The fan and heatsink are normally a complete assembly you can find from many vendors online. This computer has a type AM2 socket; you need to make sure to get a cooling fan for that type. Be sure the replacement will fit into the same space as the original.
If it's the power supply fan thats loud, there may be a couple of possible causes. It may just be a noisy fan, in which case you can replace the power supply. Make sure to get one that has at least the same power rating as the original. Or the fan may be running at its maximum speed. I don't know about this computer in particular, but many computers control the fan speed depending on how hot the processor is (determined by sensors built into the main board). If the fan is running at its top speed, it can be quite noisy. This might be due to a defective power supply or problems with the fan control on the system board
Nov 19, 2008 | Computers & Internet
COMPAQ Presario SR1220NX - Heat Sink/Fan
The processor fan should always be spinning; the variance is how fast it is spinning to dissipate the heat. The audible you would hear was most likely the fan spinning faster.
Take off the side of your case and turn on your PC. Is the processor fan spinning?
Also if it is a fan issue you will begin to experience heat issues on your processor that will start to force your PC to shut down in order to protect itself. I don't suggest you allow this to continue to happen as you will eventually fry the processor.
Jul 10, 2008 | HP Computers & Internet
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
