Question about Samsung DVD-V6700 DVD Player/VCR
Player NOT Outputing NTSC even though it says i have selected NTSC in the "DISPLAY MENU" NOTE: It was doing so, but seems to have Defaulted to "Pal60" and won't Switch back???? We are using a large number of These Combos at The University of Auckland. This seems to be a commond annoying problem with many of the models of Samsung Combo. V5500,V5600,V6700, V6800. I have a pile of them doingit.We use NTSC Output because it causes us less image problems with our Touch Screen Monitors. Would love to know if there is a hidden Menu that overides this setting. I notice that some of the Menu facilites in the Samsung Catalogues for these units looked up via Google are different from The actual the Player Menus?????
  • 2 more comments
  • r_sakey May 23, 2011
    Hi! Bob,
    Unfortunately Pressing The OK Button Twice just Switches the setting Back and Forth between Pal60 & NTSC. (Same as the Right Arrow does)
    I tried pressing it at lightning speed, but to no avail.
    Cheers!
    Ross
    Hi!
    Pressing << >> Simultaneously did nothing unfortunately.
    Does the Samsung Output NTSC 3.58 or NTSC 4.43?
    (1) Testing One of The Digitor G1923 DVD Players:
    When i set its Menu to "NTSC Output"
    It gives Colour when the NTSC 3.58 Button on my Test Monitor is pressed.
    But Black & White when the "PAL" "SECAM" or "NTSC 4.43" Buttons are pressed.
    (2) Testing the Samsung V6700 Combo:
    It gives Colour when the "PAL" Button or the "NTSC 4.43" Button is Pressed.
    But gives Black & White when the "SECAM" Button or the "NTSC 3.58" buttons are pressed.
    The strange thing is These Samsung players were Outputting NTSC Colour to our equipment just fine for a while.
    It would appear that something switches, Changes or fails in them after a while.
    Also When in the Display part of the Settings Menu, Pressing The "OK" Button On the Remote switches the Selection Between Pal And NTSC.
    This Means there is no way of Pressing the "OK" Button on the Remote Twice after using the the Arrow to Select "NTSC" or "Pal" as was earlier suggest by FixYa
    VERY ODD!!!!!!!!!!!!!!!!
    Could i perhaps be using the incorrect remote.
    I am using The Samsung 00052 Remote.
    Kind Regards,
    Ross Sakey
  • r_sakey May 25, 2011
    Hi!
    First of all, My Test monitor is a JVC MODEL No TM-90PSN CRT Monitor with 4 System Colour Switching.
    Each System can be indvidually selected via a 4 Push Button Switches on the top of the Unit.
    So testing is very precise.
    I now know that The Samsung Units Output NTSC 3.58 because I have just Tested a V6800 Model which does just that.
    With this Unit However!!!! I notice that when you go into
    (1) The "SETUP Menu" and, you get a 6 option choice.
    (2 Using the "DOWN ARROW" Button you select "DVD" and you get a 5 Option Sub Menu.
    (3) Using The "RIGHT ARROW" BUTTON abd THE "DOWN ARROW" BUTTON You Select "DISPLAY SETUP" and press OK, it leads you to a 4 option Sub Menu.
    (4) Using The "DOWN ARROW" BUTTON you then Select "TV SYSTEM".
    (Next to this it states whether Unit is currently set at NTSC or Pal output.)
    (5) You then press "OK" and this leads you to TWO TICK BOXES. One says NTSC, The other says PAL.
    (6) Using the Up & Down Arrows, you Select the one you require (NTSC or PAL60) and Press OK.
    (7) The Display the reverts to The "TV STSTEM" sub menu with your choice displayed beside it as i said before.
    AND IT WORKS OK Yay!!! YOU GET NTSC 3.58 being OUTPUT.
    BUT and its a BIG BUT: if you try to do the same on The Samsung V6700 or any of the other earlier Models i have tested, the result is as follows:
    (1) You Go into The "SETUP" This gives you a 6 option choice.
    (2) Using the "DOWN ARROW" Button you select "DVD" and you get a 5 Option Sub Menu.
    (3) Using the "ARROW BUTTONS or the "OK" Button you Select "DISPLAY SETUP"
    (4) Using the "ARROW BUTTONS or the "OK" Button"OK" Button, it leads you to a 3 option Sub Menu.
    (5) Using the "ARROW BUTTONS or the "OK" ButtonYou Select "NTSC DISC OUTPUT"
    (Next to this it states whether Unit is currently set at "NTSC" or "Pal60" Output.)
    NOW THIS IS WHERE THINGS CHANGE????????????????????????
    THERE ARE NO SELECTION TICK BOXES???????????????????????????
    Pressing either the RIGHT ARROW Button or THE OK Button selects "NTSC" or "PAL60"
    IF YOU SELECT "NTSC" the unit still puts out "PAL60" ????????????????????????????????
    This is Wierd, These reactions are the same with Both Samsung Units no matter what Remote i use.
    Also i am sure The V6700 and athoer earlier madels were workin fine and outputing NTSC OK. But have strangely reverted to this NON CHANGEABLE Condition.
    VERY ODD!!!!
    Cheers!
    Ross Sakey
  • r_sakey May 30, 2011
    Sounds good! "Salt"
    Only, Can't seem to find any sort of Coms Port???
    Unless it is sneekily hidden on the Underside of the Main Board or Under the VCR Mech etc.
    Had a quick look behind the Front Panel without taking it completely off, and also underneath the DVD Mech.
    Couldn't spot anything obvious.
    Also! Assuming i do find a port, is it a simple process?
    (Such as plugging in using a commonly used "P.C. to Equipment" type of Connector and then Loading the Firmware Update once the Laptop recognises The DVD/VCR Unit.)
    Cheers!
    Ross Sakey
  • 373 Answers
You have a firmware problem. Download at this link and install by using the device that will load it from your computer and hook it to your apporiate DVD player port:
http://www.samsung.com/us/support/downloads/DVD-V6700
Posted on May 25, 2011
  • TV Doctor
    TV Doctor May 29, 2011
    Please accept my solution.
    Top Expert:
  • Samsung Master
  • 74,106 Answers
Hello
Your institution is in New Zeland I recalls. As far as the DVD model you specified is concered, it can only output NTSC system video from it, as it is ment for NTSC only, and no PAL system circuit is inside it. To which purpose you use this DVD in your insistution, I don't know. The manual downloaded by Google and Samsung Website are the same I can see here. Just do one thing. Reset it to factory settings. Make a hard reset, so that all the passwords and other features now with it to get vanished. After reset, set a new password, refer to the manual, and try. To do a hard reset;
From a cold start with no disc in unit, press the Fast Forward and Fast Rewind [>> &
Posted on May 23, 2011
  • The Knight
    The Knight May 23, 2011
    From a cold start with no disc in unit, press the >> &<< button
    simultaneously on the front panel for 5 seconds. All settings
    including the password will revert to the factory settings.
  • The Knight
    The Knight May 24, 2011
    Answer for the first part of your comment related with g1923, the set is compactable for PAL/SECAM/NTSC4.43/NTSC3.58. It is a multisystem compactable one. But your monitor is set is set to receive NTSC4.43 signal only. For the second part I strongly belives that it is due to the use of worng remote control. Just use an orginal remote control and see the effect. V6700 combo manual; both downloaded by Google and Samsung web are the same and there is no differecne in between. There is no hidden menu at all. OK.
  • 635 Answers
After you select NTSC press the OK button ( enter ) twice. The menu image will flicker for a second ( indicating that it has changed from PAL to NTSC )and it might even ask you if you want to keep this setting.Press enter again. Turn off the power, wait for 10 seconds and on powering up see if your settings are locked in on NTSC.
Also make sure the video output is set to i-scan instead of p-scan. Some features won't work for p-scan. By the way it stands for interlaced scan and progressive scan.
I have a Philips DVP-3010 DVD player which I purchased in Europe and thus it was set to PAL video output mode. Connecting it to a US television (which understands only NTSC) and playing a DVD produces a...
Check that the TV doesn't have the option to display PAL transmissions. It might be able to do it via any of the connectors. Otherwise your best option is to find a TV that can indeed convert both signals, or get a converter box.
Apr 04, 2017 | Philips DVP3020 DVD Player
Hi I simply cannot get my DVD-5041 Curtis Home Theater system to play my DVD's, as it is always saying bad disk, and I have to put in a code for the Parental Guide...How do I get original settings?
urn power off on front panel (not remote)
Turn power on on from front of DVD player (not remote)
Immediately open tray
enter 9735 from remote control
(you may have to attempt this several times as timing seems to be important, but may not be necessary to power off and on again with each attempt)
If you can not enter in the hidden menu after 5 attempts repeat from first step again by powering off unit. If you till have no success please see comment at bottom
Hidden menu appears
on remote use arrow down to region
use arrow right to select region code on right side
use arrow up to go up to region 1 , then one more arrow up and no region will be highlighted. (line above region 1 MAY be highlighted
Hit enter on remote
Close door, hack is complete
Note: This player will play back PAL or NTSC DVDs and output automatically PAL or NTSC
or can be forced to PAL or NTSC. I will support DIVx up to 1024x576 with tested Bitrates up to 2200kbp via the USB port. player seems to skip on such videos paying from CR media.
Comment
This player comes in various flavors. If above code does not work after several tries, repeat procedure with codes below in the following order
5168
1111
Jul 30, 2009 | Curtis DVD5041 Theater System
My yamaha dv-s5650 is only playing in black & white!
That's a problem with the video IC it might shorted. You need to send your TV now to the nearest electronic repair center and have it fix there.
Jun 29, 2009 | Televison & Video
Convert ntsc to pal for sony bravia tv
While a modern PAL TV can display NTSC sources (namely DVD players and PAL VHS players that support pseudo-NTSC), an NTSC TV can not display a PAL source, unless it's an expensive multi-standard TV. Sorry pal, bad choice.
Mar 30, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
The display screen is rolling and is in black and white.
Hi
You switched to PAL mode from NTSC or vice versa. Most DVDs will only output PAL or NTSC, not both. So even if the disc is region ffree, the fact that it's encoded in PAL (50hz) makes it appear like you describe - no vertical hold / black and white.
Some set top players [Apex, Phillips] will convert PAL to NTSC on the fly or vice versa.
Remember, PAL/NTSC is not the same as Region.
Here's some detailed info:
http://www.michaeldvd.com.au/Articles/PALvsNTSC/PALvsNTSC.asp
http://www.sjbproductions.com/web_pages/tip_video/ntsc_pal.htm
http://www.dvdcity.com/codefree/codefree-ntsc-info.html
You can convert the DVD to NTSC, and strip the region code by following http://www.videohelp.com/guides/how-to-convert-interlaced-pal-dvd-to-ntsc-dvd-id1107#1107
-or-
http://forum.videohelp.com/topic221928.html
[This is very time consuming.]
You
What DVD
Most players are either NTSC or PAL, however increasingly DVD players from the Far East (Apex, Phillips etc)
, which is 50hz instead of 60hz, hence the lack of vertical hold
Mar 23, 2009 | Televison & Video
Oritron dvd 3119 player
You have to blindly instruct the NTSC/PAL menu item, which toggles between NTSC and PAL;
This is how it is done:
1) turn your dvd player off.
2) Turn it back on and make sure there is no DVD in the player tray.
This will ensure the menus are active
3) Using the remote, press the dowm menu selector key exactly three times
4) press the center menu select key once.
This will activate the display adjustement menu
5) press the down menu key exactly once.
This will activate the NTSC/PAL menu
6) press the center menu key
DONE.
The player should now have switched back to NTCS if it was in PAL.
IF it was in NTSC it should have switched back to PAL.
Note: If you still have the manual you can follow the menu tree blindly using the instructions in the manual. The above sequence is for activating the NTSC/PAL menu.
This player can also switch to progressive scan, which creates a similar problem. At least the progressive scan menu has enough warnings before it will actvate.
Jul 29, 2008 | Oritron NPD3117 DVD Player
How to switch back to NTSC from PAL without being able to see player menu
Solution to resetting TV type for RJ Tech
  1. hook up unit to computer monitor (not a TV)
  2. power up, remove any media from the tray
  3. select setup menue
  4. for TV type - select NTSC
  5. for TV output make sure CVBS S-Video is selected
  6. exit setup
Oct 28, 2007 | RJ Tech RJ-200S DVD Player
VCR not working for some cassettes
What do you mean by "not able to play my VCR with some cassettes. " Is it that some tapes do not display images? No Video? From your name it seems that you are from India, Assuming that to be so, I also presume that you must be possesing a Multi-System VCR, to play back PAL Tapes from India, and NTSC tapes from the US. And if that is the case, I guess it is a simple problem of resetting the System standards. Please go to the Main menu of your VCR using the Remote, and select AUTO in System (You will be given choices of AUTO, PAL, NTSC 3.58, NTSC 4.43 and NTSC PB PAL. Likewise, it is entirely possible that your Television SYSTEm Standard has been accidentally changed. If it is Multi System TV, Then, again, using the Remote of the TV, select Menu, and then select AUTO in System. In all likelihood your problem should get solved.
May 13, 2007 | RCA VR605HF VHS VCR
Black & White picture
There can one of two problems here. Either your DVD player's output is set to NTSC and you are attempting to play it through a PAL (European) TV, or you are perhaps using the SVHS output incorrectly. The solution is to access the player's setup menu and ensure the video output is set to your standard (PAL or NTSC). Hope this helps!
Feb 14, 2007 | Philips DVP642 DVD Player
Pal/Ntsc playing problem
is your tv is the same tv that u playing before? coz according to you if u play ntsc there is no problem. if ur tv is multisystem, u can change the tv system menu to auto, but if not u cannot watch coz ntsc tv only accepts ntsc signal.
Jan 08, 2007 | Pioneer DV-373 DVD Player
Samsung DVD-V6700 DVD Player/VCR Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
