Question about InFocus IN26 Multimedia Projector
Red wrench light is on and I have no picture, but the fan is still running
Hitachi model number 50V720 does not show picture or sound when turned on. The Temp light and the lamp light flash red on and off. What's the problem?
Check the tv fan it is running?No than the fan require replacing.Yes,than the tv projection lamp life are ending require replacing.
Apr 14, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
My 60" dlp mitsubishi tv
Sound /No picture- Have you replaced the Lamp?
If Not, First make sure fans are running when Tv is Turned on .Then if fans are OK ,Most common reason is the Lamp.
What is the Model # that is printed on back of TV?
Feb 20, 2011 | Mitsubishi Televison & Video
First the red bulb light was flashing and there was no picture. So i replaced the burnt bulb. Now when i go to turn the tv on were the red light means off and the green light mean on (that light blinks 3...
Check Lamp Fan if it stops running when Lamp trys to Light ,Then Lamp will not Power up,or Ballast Board itis what powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
Oct 06, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
I have a fan light on and the wrench light on and now I have an ! light flashin and I dont know what to do
YOU HAVE A COOLING FANS FAULT.CHECK COOLANT FANS FUSES AND RELAYS.IF ALL IS GOOD YOU COULD HAVE FAULTY COOLANT FAN MOTOR.HOTWIRE IT TO SEE IF IT RUNS.
Jul 06, 2010 | 1999 Mercury Cougar
Tv keeps turning itself off
The cooling system in the set maybe malfunctioning. this set run hot and they have built in fans. Have you tried cleaning the vents and or fans?
May 04, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
2001 Dodge Ram 1500 Water Pump?
can we have a picture of fan/pump assembly?
if not, just fit the correct size of wrench on the bolts.
if you have adjustable wrench that could reach those bolts.
use socket wrenches, or close type wrench.
email me the picture. jyzomnix2@yahoo.com
Nov 06, 2008 | 2001 Dodge Ram Maxi
No picture
When you turn it on if you haer a high chirp chip befor the light turns red
starter ok lamp has reach its life needs to be replcce
Mar 04, 2008 | Canon LV-7210 Multimedia Projector
Sony KF-42WE610
Sound but no picture, tv will not turn off. Light goes red but a dim overall blue screen remains and fan is still running.
Nov 15, 2007 | Sony XL-2100U Projector Lamp for...
InFocus IN26 Multimedia Projector Logo
222 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
