Question about Sony STR-DB840 Receiver
I have a SOny STR DB 840 receiver. When I turn the volume up to 3 it will shut off and go into "protector" mode. Would say the shortage is in the speaker wires or the unit itself?
    Brigadier General:
  • 8,546 Answers
That's for you to determine.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 23, 2011
How do i get my sony DA30ES am -fm reciever out of protector mode
Here is a guide for you: STR DA30ES Protect
let us know how , if you need further assistance.
Jun 09, 2012 | Sony STR-DA30ES Receiver
When I am using the Video 2 mode and the show on the TV is put on hold, we can hear an AM radio station. What is going on and how could I fix it.
my str-DB 840 is the same and pretty sure most budget amps do it i figure the tuner has a strong presence within the amp and seems to push through when silence is desired i asked my local shop when i has some service done to it and he figured it would also be a good possibility aswell and ive also had a cheaper jvc do it but my harmon k didnt do it so i quess its hit and miss whether an amp will or wont have this issue :) good luck
Jan 23, 2011 | Sony STR-DE598 Receiver
Sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Mar 15, 2009 | Sony STR-DE935
My reciever turns itself off
You most likey have a wire short on your center or rear surround speakers. The wire short will be between the + and - points of the speaker wire.
To find the problem speaker, disconnect one of the 3 speakers at a time from the back of the sony and see if the problem goes away. Once you identified the offending speaker, check both the sony side and speaker side for the short. The small wire strands are hard to see and it only takes one to trip the protection mode, so look carefully.
Mar 07, 2009 | Sony STR-DE845 Receiver
Receiver goes into protector mode
Nope, power supply it would not even power up.  The capacitors are fried
Jan 04, 2009 | Sony STR-DE635 Receiver
My sony str-d1o15 says protector
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
  1. Check the speaker wires and speakers for proper connections.
  2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
  3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
  4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
  6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Dec 20, 2008 | Sony STR-D1015
Sony STR-DE525 Protector mode
Download service manual of STR-DE525 here and fix your receiver.
Must download all 4 files at web site.
Need further help, let me know.
Sep 24, 2008 | Sony STR-DE525
Help
check/replace your speaker wires. If a wire came loose, it will go into "protect" mode and shut down, to protect from a short circuit.
Jun 16, 2008 | Sony STR-DE525
Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
Mar 07, 2008 | Sony STR-DB930 Receiver
Sony STR-DB840 Receiver Logo
184 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
