Question about Garmin nuvi 255W GPS Receiver
Garmin says low battery and now will not work in the car. Does this Garmin have a battery inside the unit that I have to replace?
    President:
  • 1,514 Answers
There is a battery in the satnav but it's not user replaceable. It can only be replaced by returning it to Garmin. Before sending it away to replace the battery you could check the following;
  • Have you the satnav connected to the charger?
  • If it's connected to the charger is the cigarette lighter socket working. You can check by plugging in another device to see if it works
  • If the cigarette lighter socket is working and the battery of the satnav is not charging it's possible that the fuse in the plug, that goes into the cigarette lighter socket, is blown.
To change the fuse;
Unscrew the ring that's at the end of the plug and the plug comes apart. Be careful not to lose the silver coloured tip. When the plug comes apart you can take out the fuse and get a replacement at any car accessory shop or a shop that sells garmin satnavs.
If you have to return your satnav to garmin you can find their contact details at http://www.garmin.com/garmin/cms/home/support/supportcontact
Posted on May 23, 2011
Garmin nuvi says low battery and it is plugged into the car
The Garmin will tell you 'Low Battery' if its alternative power source is not available for some reason, so the battery is not being charged. Depending how the Garmin has been programmed, the display on some models will become slightly brighter when a power supply, other than its own batteries, is detected. Check for this.
It is likely that the lead you use to plug into the car is not supplying voltage to your Garmin set. If it plugs into a cigarette holder, check that the cigarette lighter works, or plug in another device to see if there is any electricity to the receptacle. Obviously ensure that the ignition switch is on. If the plug-in bit of the power cable has a light on it, check the light is illuminated. if you have a sensitive tongue, you should be able to put the end of the lead that plugs into the Garmin onto your tongue and you will feel a very slight tingle on your tongue if power is getting to the end of the lead. If not, then there is probably a break in the lead inside the plastic insulation or a problem with the supply plug.
If the plug in lead proves serviceable then you should change the batteries in Garmin as one or more may have failed and will not charge. Check for this by leaving the unit on after unplugging the external supply lead. Depending on the Garmin you have, the unit should remain functioning for at least 30 minutes. The internal batteries will degrade rapidly if the unit has not been use for some time and the batteries were not fully charged before you put it to bed.
Mar 10, 2014 | Garmin Nuvi 2460 2495 2555 2595 3790 Lm W...
The unit won't charge...it says "low battery". i
Sandra,
I don't know where you live - so I don't know who nearby can work on it. Regardless, my suggestion is to return it to Garmin and let them handle it. Since your nuvi 760 is out of warranty, Garmin will charge $99 to "factory overhaul" it. What this means really is, you will get a factory rebuilt nuvi 760. Garmin will not fix yours and return it to you - but rather they will send one that that belonged to someone else that they refurbished. This means really fast "turn around" instead of waiting for yours to be fixed. In short, you will not get the same one you sent in. The refurbished unit will come with the latest up - to - date maps and have a 90 day factory warranty.
Check out Garmin's page to learn more about this overhaul service and to take advantage of it. If you do send it in - your data will be lost. Garmin will erase all your personal data, photos, etc. from the nuvi (and they won't put it on the replacement) - so if there's anything on it that you want - be sure to copy it before sending in.
I hope this helps & good luck! Please rate my reply - thank you.
Feb 18, 2011 | Garmin Nuvi 760 Handheld GPS Receiver
Battery power was low on my nuvi 255.plugged into the garmin wall charger.now nothing works.wont power up at all.plugged into the car charger and still nothing..whats happened ?
The 2xx series had a batch with bad batteries and they are replacing them even out of warranty , try your serial number on https://my.garmin.com/rma/recallLanding.faces. See if it is eligible for repair, if not the unit is probably pooched.
Hope this helps!
Dec 09, 2010 | Garmin Nuvi 255 GPS Receiver
Display reads sonar timed out
check the battery voltage as low voltage can cause the unit to display errors and prevent the sonar from starting up. This unit is more sensitive to low voltage than many other electronics. If charging the battery or replacing it with a known good battery doesn't work then contact garmin for a replacement of your fishfinder.
Nov 18, 2010 | Garmin Fishfinder 400c With Dual Beam...
Can you replace the batteries in the unit? It only works with the power adapter now.
The battery CAN be replaced, but it is not designed so that the user can replace it. Either contact Garmin or your local GPS retailer to see where you can get the battery replaced. If you open the cover to try to replace the battery, you will void the warranty and chance damaging the electronics inside the unit.
Sep 20, 2010 | Garmin StreetPilot C330 GPS Receiver
My Garmin c530 GPS will not turn on
Pull the face off it, press the reset button, this may work,
If it will not reset, or work in the house or the car, the battery will need replacing,
http://www8.garmin.com/support/outofwarranty.html
Around $100 for new battery
Regards.
Jun 21, 2009 | Garmin StreetPilot c340 GPS Receiver
Low battery, won't charge
connect the garmin to your computer using the usb port. It will start charging then. For some reason when the battery goes dead in this unit the only way to charge it is with computer. the car adaptor will not work once the battery gets real low.
Apr 16, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin 48 memory loss
I have fixed several Memory battery low for the Garmin 48 .
May 30, 2007 | Garmin GPS 48 GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
542 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
