Question about HP PSC 1610v All-in-One Printer
It doesn't scan.The message is No Scan options. You need to install or run device software for feature.
    Guru:
  • 731 Answers
Please click the below link which shows step by step on resolving this error. HP guides are always recommended to start troubleshooting
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02450835&cc=us&lc=en&dlc=en&product=390328&tmp_track_link=ot_search#N1481
Regards
Riztech
Posted on May 23, 2011
I have hp officejet j4660. when I try to scan, the message appear: no scan options, refer to device documentation to troubleshoot
no scan option means scan setting are not set on the printer. Before you can scan directly from the printer control panel, you must have the printer's Full Feature software package installed on your computer .If you ran the installer and installed everything,then scanner software should be installed on the pc.there must be solution center icon on the computer,as well.Below are the troubleshooting steps for no scan options issue. STEP 1:Download the Scan Diagnostic Utility (click on the link below) http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?cc=us&lc=en&lang=en&softwareitem=oj-90927-2 download and run the tool.select the product and click on diagnose.if the printer is not in the box.skip this step. STEP 2: Set up the scan destination list
  • click on the solution center icon on the computer
  • click on settings on the bottom,click on scan settings,click on either scan..to setup or button settings
  • click on scan to setup (front panel list)
  • if this is what you have,then you should transfer all items on the left- hand side to the right-side by clicking on one item and clicking on add until everything is transferred.click on update device.
  • it should look like this.
  • try scanning to pc again
  • you can also try to scan from the pc using the solution center software
  • if the steps above fails,you may need to uninstall and reinstall the software or check this link out for no scan options
  • http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02450835&cc=us&lc=en&dlc=en&product=3692891&tmp_track_link=ot_search#N74
Jun 07, 2011 | Office Equipment & Supplies
How do I use the scan feature on my HP Officejet J3680 All in One. I pressed the "scan" button and received message "No scan option, refer to device documentation to troubleshoot". I do not have "device...
The HP Digital Imaging Monitor (DIM) software must be running in order to scan from the printer.
  1. Click Start , and then click Run .
  2. In the Open text box, type msconfig , and then click OK .
  3. In the System Configuration Utility window, click the Startup tab.
  4. Search the list for HP Digital Imaging Monitor .If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. You need to reinstall the software.
  5. Select the HP Digital Imaging Monitor check box.
  6. Click Apply , and then click Close .
  7. Click Restart to restart the computer.
  8. Try scanning again
Regards,
Riztech
Jun 16, 2010 | HP J3680 Officejet All In One Printer
Hi, I have had my hp 6210 for several years and just re-installed it. When I try to scan, I get the message: "No Scan Options. You need to run or install software for feature" Thanks, Johnny
Visit the below web link and select your operating sytem, download full feature drivers.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=421991&lc=en&cc=us&dlc=en&lang=en&cc=us
1. If the issue still persists, After installing the printer software
2. Open HP Solution Center
3. Go to Settings-> Scan Settings->Scan to setup
4. select all available scan shortcuts one by one and click on add
5.Click on update the device
6. Verify the results.
Aug 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Will not let me scan documents
install the software first and then you will be able to scan its just that the scan options are not getting detected from the software on the computer that assigns the scanning options.
IF the software is installed then open hp solution centre and point to settings.Then point to scan settings and click on scan to setup and move all the items on the left to the right by selecting each one and pressing the right arrow button and click on ok and now check you will be able to scan
Jun 15, 2009 | HP Officejet 7210 All-In-One InkJet...
Scanner
When in doubt, pull out the instruction sheet. Solved it by some preliminary steps I didn't know were necessary.
Jul 20, 2008 | HP Officejet 4215v All-in-One Printer
No Scan Options Error Message
Vista?
Pressing of scan button feature is no longer supported by hp drivers, if installed correctly one scans using scanners and fax
When the scan button is pressed on the printer, nothing happens. The scan button does not work correctly. Solution Scan documents using Windows Fax and Scanning or Paint. Scanning with Windows Fax and Scanning
  1. Click the Start (c00845897.gif ) icon.
  2. Click All Programs .
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File and then click Scan .
Scanning with Paint
  1. Click Windows .
  3. Click Accessories .
  4. Click Paint .
  5. Click File and then click From Scanner or Camera .
  6. Click Scan .
Cause The drivers in the Windows Vista operating system do not support button press functionality on the printer. link to above info from HP
Dec 11, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Cardridge problem for my 5610v
try with another cartridge, maybe you have a faulty one.
try cleaning the connectors on both printer and ink cartridge.
Nov 21, 2007 | HP Officejet 5610 All-In-One InkJet...
HP OFFICEJET 7410 "NO SCAN OPTION"
1.open the HP Director/Solution Center 2.click on scan menu and go to destination list tab 3. on the left side u will find a list of available destinations , move them all to the right side (front panel destination list) and save and then try to scan again , IT MAY WORK
Jan 01, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP PSC 1610v All-in-One Printer Logo
110 people viewed this question
Seeker5211
Seeker5211
