Question about Mitsubishi WS-55859 55" Rear Projection Television
I have WS-73909 which uses same manual as WS-55869. The green light remains flashing even after I unplugged/replugged, or push "reset" couple times. . Thank you in advance for your help.
    President:
  • 1,654 Answers
The power supply is causing your issue and if your savy enough to do a little soldering and replaceing some bad capacitors this link to a PDF file explains the issue in depth. If you don't think you can handle the electrical work, then you will need a tech to take a look at the power supply for you. What is happening is the power supply is not getting up to power and therfore won't turn on or bring up any codes to follow.
www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
I hope this helps with the issue your having.
Posted on May 23, 2011
  • russ peeples Dec 01, 2011
    followed your instuctions for replacing caps on my 73909. great instructions, easy to follow and the pictures really helped alot. This was my first soldering fix. I was a little clumsy with the wicking but it seemed to work. Best $ 10.00 investment I have have made in a long time.
Ws 73909 has bad dm module. Where can I get it repaired or replaced?
If this is for the green blinking light issue, you can easily fix yourself if you have a soldering iron. It is just a few capacitors. But if you can't, then just about any mom n pop service compony will fix it for you, but will charge a lot of money to do it.
Mar 19, 2013 | Mitsubishi WS-73909 73" Rear Projection...
Tv problem
can you tell in what patter does the light blinks??
Mar 11, 2008 | Mitsubishi WS-55613 55" Rear Projection...
I have a Mitsubishi rear projection TV (WS-73909) that didn't turn on and had a green blinking light. I replaced the 7 DM capacitors and now it turns on. Both the remote and front control panel ca
Let me know as I can look for this---the set has a keyboard lockout that is cleared by holding the menu or another front button for more than 5-10 seconds with set on---I can find the service manual and check if needed.
Nov 04, 2012 | Mitsubishi WS-73909 73" Rear Projection...
Model WS-55909 Green light flashes won't go out. No TV
You need the WS55909 - WS73909 DM kit. You can get it at the following link which contains the capacitors and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Jul 18, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Misubishi WS-65613 Flashing green reset light
do you have the service manual? also have you checked the diodes or protection fuses for the volts out of the loptr ( low output trans) , also check the volts on the trans for no volts , low volts , or voltage drop
let me know what tests and results you have , and if you dont have a schematic yet , this one should be about the same as yours , this is part 1 with 7 zip files http://www.eserviceinfo.com/downloadsm/31768/Mitsubishi_WS-55859.html
this is part 2 with 2 zip files http://www.eserviceinfo.com/downloadsm/37351/Mitsubishi_WS-55859,%20WS-65869,%20WS-55909,%20WS-65909,%20WS-73909.html
electech
Nov 26, 2008 | Mitsubishi WS-65613 65" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
