Question about Dryers
When I push the start button it makes a clicking sound and won't start
  • Dryers Master
  • 7,482 Answers
Hi momofjmb
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please take time to rate me
Posted on May 24, 2011
1986 yamaha xj700 won't start just makes click
sounds like a bad earth if you have jump leads go direct of earth to engine to see if this cures it if so you no where problem is clean replace earth
Jul 12, 2013 | Motorcycles
2003 Goldwing won't start...just one click when start button pushed
you may have blown the starter solenoid or even worst the starter motor
i cannot diagnose without seeing the bike properly
i strongly suggest you put in a workshop and get it diagnosed properly
Apr 12, 2013 | 2003 Honda GL 1800 Gold Wing
My 2005 honda vt750 shadow won't start just makes a cocking sound
Sounds like your starter is froze up. Try tapping on the starter.
Apr 04, 2013 | Honda VT 750 CD Shadow A.C.E. Deluxe...
Won't start makes clicking sound,plenty of juice in battery
A battery can show 12 volts yet still be dead (not pushing any amps). Many battery places or auto parts store will do a free test.
Aug 26, 2012 | 2006 Chrysler PT Cruiser
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
Why does the 30 amp circuit breaker behind the battery box on my 1990 fatboy click once when i push the ignition button? The bike won't start.
Try to reset the circuit breaker. also check for an earth fault on the starter motor .If this is not a circuit breaker and is a relay, you should make sure everything is ready for a start, (ie : in neutral, sidestand up and clutch in and that the battery is charged.) the neutral light being "on" doesn't mean it is in neutral. I hope this helps.
Mar 08, 2012 | Motorcycles
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
Kenmore 80 series electric dryer Model - 110-60882990 The dryer won't turn on. Once the start button is pushed it makes a single clicking noise. If I open/shut the door and push the start button...
check the actual door switch,, you can jumper it to see if this is the problem, Just connect the 2 wires together , if this cures the problem replace the switch
May 25, 2011 | Dryers
Dryers Logo
57 people viewed this question
Top Dryers Experts
