While using my HP Presario Compaq notebook, The battery life completely drained down to zero while being on. I then plugged in the power cord after the computer power went out. After plugging in the power cord the computer would never come back on.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
You need to replace the battery and check out the contacts of the cord .if the outlet is broken you will need a new outlet for the cord.
Posted on May 23, 2011
HP Compaq Presario R4000 (PN495AV) PC Notebook How
Yes, go to Start>Control panel>Power Options. There also should be a screen brightness key on your key board, that looks like a sun shining, with arrows pointing up & down. To use that key, hit the FN key, right next to the Ctrl key. Push & hold the FN key, while pushing the up arrow. That should increase the brightness of your display. Good luck.
Jul 06, 2011 | HP Compaq Presario R4000 Notebook
Compaq Presario V2000 will not boot.
Remove the battery and just leave it off the computer, then plug in the power cord and try it. If it works with no battery...the battery is completely dead and you need to replace.
Mar 08, 2010 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V6101US Notebook PC' push the
There are several reasons why this could be happening. Below are a few diagnostic steps we can start off with to eliminate some possibilities. If there is anything you are not comfortable with doing yourself please consult a local repair technician.
  • Remove the battery from the system and try booting up the computer with only the power cord. The "1" in the diagram below is the battery, "2" is the battery release latch.
  • Try removing one of the memory modules (if there is more than one) from the system by following the below steps.
1. Flip the computer upside down. Remove power cord and battery and ensure the system is completely off.
2.Unscrew the compartment labeled "4" in the diagram below. This is where the battery is held, as well as the WiFi card and motherboard battery. DO NOT do anything to these other components as they are quite fragile.
3. If there is more than one memory module you should remove one. Replace the compartment cover and attempt to boot up with battery and power cord reattached. If nothing has changed try swapping out the memory with the one you just removed.
If still nothing happens, this is not the issue. Comment back and we will move further with your case.
Good Luck,
NOLA Tech
Jan 28, 2010 | Microsoft HP Compaq Presario V6101US...
My Compaq Presario V3000 laptop will not power up.
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Dec 04, 2009 | HP Compaq Presario V3000T Notebook
Laptop not powering
try a simple power cycle. Take out the battery, leave power adapter plugged in. Hold down the power button for about one minute. Then hit the power button normally this should correct the problem
Jan 23, 2009 | HP Compaq Presario 2200 Notebook
HP Compaq plugged in & blue light on but icon says NOT plugged in
Check power out put of the adapter is it giving you the correct readings
Try to remove the battery and run it from adapter itself check to see if its working
Reset the battery ..by removing it from the system
Nov 10, 2008 | Compaq Presario Notebook
Compaq Presario needed a new battery was installed labtop will not charge up!
When you install a new battery and remove a battery always make sure the laptop is completely shut off and have the power cord removed so that you avoid any possible power surge.
Batteries generally don't last much longer than a year and I have found removing the power cord or battery when it is off to be a good practice.
Before you charge a battery make sure it is run most all the way down. Recharging a battery when it is not run down can give it a memory and you may only be able to charge it up to the point you started charging it.
Anyway, if the computer won't charge a new battery then you could have a bad motherboard. To be sure try another battery.
Sep 09, 2008 | Compaq Presario Notebook
Wont turn on
At this situation we can try power drain.
Try doing power drain by taking out the battery & keep holding down the power button for complete one minute to drain out the power from the computer components. Restart the computer after putting the battery in.
Try restarting the computer only with the AC power, without the battery & vice-versa.
That should resolve the issue. If the issue persists, then the only option is service center.
Jun 08, 2008 | HP Compaq Presario C500t Notebook
Compaq F700 Battery live very less
Giri,
Its normal, generally it comes with 80-90 min. You can use HP Power management to optimize the use of battery. Making screen less bright will increase the power backup.
Thanks
Iqbal
Apr 28, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
