Question about Nokia 5530 XpressMusic Smartphone
I woke up to find my shortcut keys on the top of the screen. how can i bring it back down to the bottom? Pls help.
  • 133 Answers
You can change the Homescreen Theme of your Phone by Going to tools Folder and look for Profiles, inside that folder, look for HomeScreen and look for an item says homescreen theme. Using that, you can change the HomeScreen theme of your Handset.
Cheers!
Posted on May 23, 2011
How do i turn my screen back the right way
How to Rotate a Computer Screen 90 Degrees
Perhaps you built your own monitor, and the screen is displaying at the wrong angle now that it's all set up. Maybe you installed a new graphics card or driver, and it appears something has gone horribly wrong. It's possible you're just being creative, and think it would be cool to lay your monitor on its side and still be able to use the computer. Or, most likely, your cat or kids pressed some mysterious key combination which rotated your screen for you, and you can't get it back. Don't worry; getting your screen to rotate 90 degrees is easier than you think.
1 Identify in which direction your screen needs to be rotated. There are four shortcut key combinations, and each will rotate your screen so that the top of the screen is at the top, bottom, left or right side of your monitor; you need to know which combination to choose. Say you are you trying to correct a mistake, and put the top of your screen back where it belongs--at the top of the monitor. Or you are trying to rotate your screen because you are using your monitor differently than most people do, and want the top of the screen to be at the left or right side of the monitor, or even upside-down.
2 Hold down "Ctrl + Alt" and the "up" arrow key if you want to return the top of your screen to the top of the monitor. "Ctrl + Alt + Left Arrow" will rotate your screen so that the top of the display is on the left side of your monitor, and using the Right Arrow will put it at the right side. The Down Arrow will turn your screen upside down if your monitor is right side up. Make sure you hold all three keys down long enough; the screen may go back for a moment as the screen is rotated.
3 Open your "Control Panel" if nothing is happening, and see if there is an option to "Enable Screen Rotation" under your Display options. If not, you may not be able to rotate your screen. This is especially common with older computers, as they have older graphics cards or integrated video If you have a newer computer, you may need to have the graphics drivers updated in order for the shortcut to work.
Tips & Warnings
If pets or children accidentally rotated your screen, consider finding a way to better protect your keyboard not just from accidental keystrokes, but from pet hair and kids' spills. A keyboard cover might be in order.
Dec 02, 2011 | Toshiba Satellite C655-S5068 Notebook
Keyboard meaning
With the indulgence of the other posters.
The Acer Aspire AST180-UD400B or better known as Aspire T180 comes with a standard keyboard as shown below
Should this be what you have, the basic keys on the top left are:
Esc - Escape key. It is basically a shortcut to STOP or get out of a program sequence. Often this is as a shortcut key for the Stop button in many web browsers
F1 - usually launches a program's Help Guide
F2 - usually launches Rename command
F3 - usually launches Find or Search command
F4 - formerly a DOS for launching previous OS but currently used in conjunction with Alt that closes an active, open window and/or exits a program. With no active, open windows, it prompts you to exit.
If for some reason your keyboard is different, it is possible that the dealer could have bundled a different/after market keyboard such as those web or multimedia as shown below. The top left keys then would be either for web browser shortcut keys or multimedia shortcut keys or some other specialized functions.
Should this be the case, pls post back with the brand/model which may be determined by looking at the bottom or any of the markings at the top.
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Feb 11, 2008 | Computers & Internet
Tip
Nokia 5800 Tips
5800 Tips and Tricks
1. To bring out the Shortcuts on your Screen/Desktop-> Settings/Personal/Home Screen/Home Screen Theme and select Shortcut bar, you can then select which shortcut to display if goto "Shortcuts". This will also bring out the "Track" playing being displayed when you open the Music Player.
2. Tap the Clock to bring out the Clock menu and make your alarm, alarm repeat is now built-in.
3. Tap the "General" or Date (the set Profile besides the clock) and the Profile selection menu pops out, almost similar to pressing the "Power" button in all S60, but here the Remove memory is not shown, but "Calendar" shortcut is included and the other profiles as well.
4. If you are on the Numeric Keypad, pressing the [#] key alternately will toggle the General and Silent Profiles, same as before, which means long press on zero [0] will bring out bookmarks for the Web.
5. Tapping on the displayed To do or Calendar entry will bring you immediately to that particular item.
6. Tapping the Active Icon on the Top Left (near the battery indicator) will give you shortcuts for any of the active icons.
7. Long press on the Green Call Button will still activate the Voice Command Prompt
8. Long press on the center button is similar to the Long press on the "Menu" key (the yin-yang key on most S60) which will bring out the menu for all the active applications.
9. Go to Applications/File Manager and setup "Backup" for automated backup schedule of your phone data.
10. How to update your Nokia 5800 firmware using your phone.
Presss *#0000# to display phone factory information and firmware
Now press options and select check for updates
The newest update is sent to your phone from nokia
Download and install updates.
This is done using GPRS or WIFI Connectivity.
General Tips
1. Use Dialer and press # for about 2 seconds will switch the profile between Silent and General; press and hold 0 will open the web browser; press and hold 1 will open the voice mailbox
2. There is a shortcut key for Music, Gallery, Share, Video, Web shortcut at the top right corner just below the front camera
3. Press and hold the Green caller button when standby mode will activate the voice command. You could call the name from the contact or application name.
4. Organize your sms by grouping them like outlook by Messaging -> Option -> Setting -> Text message -> Other -> Show messages in groups -> Yes
5. Notification light will blink if there is unread sms/missed call. It could be turned off at Settings -> Notification light -> Off
6. If the touch input is not accurate, you could calibrate your screen at Touch Input-> Touch Screen Calibration -> ( Tap around the 4 dots at the corner)
7. Turning control functions:
a. Rotate your screen horizontal or vertical
b. Silence your phone for incoming call by rotate your phone with screen facing down.
c. Snooze the alarm by rotating phone screen facing down
8. Theme effect will give 3D and transition effect if on but will slow down your tube considerably. Settings -> Personal -> Themes -> General -> Themes effects -> On/Off
9. Shortcut to exit application : Press and hold the middle white button then press and hold the program that you wish to quit, an open/exit option will pop out (useful for those haven’t install handy taskman yet)
10. When using handwriting input, slide from left to right is Spacebar, right to left is Backspace
11. Organize your menu by Menu -> option -> organize. You could drag and drop the location of the application you wish to relocate.
on May 12, 2010 | Cell Phones
My screen is on sideways and i cant put it back the right way
Tips & Warnings
Dec 02, 2011 | Computers & Internet
I have a acer travel mate laptop , on the desk top the desk top bar which usually is on the bottom has now moved to the left side of the screen, how do i bring back to normal
click on start button in key board press alt space in displayed options select move press down arrow key to move your task bar to down
Sep 11, 2010 | Acer Computers & Internet
Certain keys just won't respond and one of the keys (the h key) brings up a drawing box. The "h" key is not programmed to do that. The computer brings up a screen message overnight relating to a keyboard...
Pressing the '?' Menu soft key displays the soft key section of the HP enhanced keyboard control panel on your screen. Click any of the keys on the screen to display the action assigned to an individual key or to change or assign an action to a key. Shortcut keys are provided specifically for user-defined actions. I hope this helps
Nov 03, 2009 | HP Keyboard & Mouse
Acer 1690 keyboard arrows problem
Sounds like your number lock maybe be on. It could also have a shortcut function option that is on. If not, have you spilled anything on it lately?
Mar 22, 2009 | Acer Aspire 1690 Notebook
Samsung Omnia - Main Menu Function key gives a shortcut error.
Assign the key to another function. And then reassign it back to the main menu short cut. It worked for me.
Dec 09, 2008 | Samsung SGH-i900 Omnia Unlocked Cellular...
Adding customised shortcuts to Sony Ericsson
Push on the shortcut key, scroll down to the end of the list and you'll find "New Shortcut" menu. Click "Add" and browse through your main menu to add shortcut.
PS: All the things you want may not be available for having a shortcut for.
Sep 12, 2008 | Cell Phones
Nokia 5530 XpressMusic Smartphone Logo
94 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
