Question about Hotpoint Washing Machines
My hotpoint wf340 washing machine starts up but the drum wont turn then the lights flash on rinse/hold and on/start at the same time. anyone know why. thanks. house dad of 3 chidren.
    Problem Solver:
  • 14 Answers
Try to change the 2 carbon brushes from motor.
Posted on May 23, 2011
Hotpoint fault codes
try a different store.
Oct 31, 2013 | Washing Machines
When i put it on a wash cycle it starts then all of a sudden the power light flashes rapidly and the rinse hold light flashes steady
Fault code F02 meaning Motor jammed / tacho detached: check motor
& module connections.. on the motor plug check that a wire hasn't become dislodged or broken...
Dec 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wd440. Flashing lights
press and hold on off button till the display panel lights up.Then press and hold the on/off button and the start /cancel button together.You will now reset the washing machine settings.And just pick your cycle again
Oct 04, 2009 | Hotpoint Aquarius WD63 Front Load...
I have a Hotpoint Aquarius WML540 washing machine and after the wash and the rinses, all the lights start flashing and the programme will not go any further. I would like to know what is causing this and...
I would like to know what is causing this and how to solve it.
Sep 22, 2009 | Washing Machines
WF340 hotpoint aquarius WASHINING MACHINE
Hi, Remove the drive belt from the drum & motor then turn the drum be hand, Is it noisy? if it is then the drum bearings need replacing i have used this website before and they are very good.
http://www.candmdomesticappliances.co.uk/section.php/88/1/hotpoint-washing-machine-spare-parts
Apr 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WF340 wont drain
I have the HOTPOINT WF540 with the same problem ....So remove the front panel at the front of the machine and you will see the filter plug unscrew anti clockwise, you may find it difficult to unscrew as the filter may be blocked solid with coins ans long objects but once you have started it off wiggle it back and forth with some force till the objects dislodge you may be scared of breacking it but the worst you can do is snap of the plunger which is attached to the filter plug, behind the filter plug its self which will do no real harm and you can put it back in unattached to the filter plug with no worries when your done
you can also drain of the water out of the drum drum from this point but you will need a very slim try to fit under the front of the washer below the filter plug DO NOT totaly remove the plug if the is washing machine is full of water, just release the plug till water slowly trickles out and drain it a bit at a time or you will flood your floor
Feb 12, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Wash enhance & on/off flashing
The only time the lights kept flashing on my Hotpoint machine was when the outflow pipe going into the ubend was blocked,
Check for blockages, but make sure that you have a bucket or pan ready to collect the water flow.
I hope this helps
Nov 24, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
348 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
