Question about Garden
Model LT2000 hydrostatic drive wont move in either direction drive belt started smoking than quit now tractor wont move in either direction
    President:
  • 3,074 Answers
If the main drive belt, from the engine to the rear end of the tractor broke, you won't move, nor will you hear a whining or grinding noise!
An easy check- inspect if each rear wheel has a key installed between it and the axle shaft. One pops out- it won't drive.The key is a square piece of hardened steel that is inserted into the axle, then the wheel hub is slipped over it and the axle, then the necessary fastener is installed to keep the wheel on. This could be either a bolt, or a spring clip. And, if the transmission has failed, you may or may not hear any whining or grinding noises!
My guess it the drive belt is toast as you said it was smoking, look at it and the order a new one. Here is a site you may be able to download a manual, Tim:
http://www.searspartsdirect.com
Posted on May 23, 2011
SimplictyYRZ01 hydrostats not engaging
The only thing the two hydrostatic drives have in common is a drive belt that ties them to the crankshaft. If both side quit at the same time that belt is most likely the problem.
Jul 09, 2016 | Garden
My hydrostatic pedal does not move the tractor in either direction
There is at least one belt that goes from the engine to the hydrostatic drive. It is highly likely that this belt has slipped off a pulley so the unit won't drive. It is also possible that this belt is broken there again causing the unit not to drive.
Apr 25, 2016 | Garden
MOWER WONT MOVE
Drive belt broken or slipped of pulleys, hydrostatic drive filter(s) plugged. Should be one or those, Roger. Follow the drivebelt with your hand (disconnect battery to be safe) and see if it hasn't slipped off the engine drive pulley, idler pulleys, or axle pulley. If you tractor is hydrostat, may be time to replace filter.
Aug 09, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My 4210 4x4 with hydrostatic drive quit driving runs well but will not travel forward or reverse
Hi, the engine will power the hydrostatic drive via a drive belt. See that this belt is in place or if it is worn out and loose. By replacing this belt you should get your machine running again. Hope this helps
Nov 17, 2010 | John Deere Seat 4210 4310 4410 4510 4610...
Tractor will not go into gear
is it hydrostatic or belt?probably belt broken.if its hydrostatic,check the release lever at back,that allows you to push it.wont drive if its released
Jul 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a cub cadet mower and it has the hydrostat trans drive and I hit a tree root in the yard and the tractor quit moving. The mower deck still runs so is there a belt broken or what could be wrong?
There are two belts - the main drive belt from the engine to the hydrostatic transmission, and the mower belt that runs from the engine to the mower deck. Sounds like the main drive belt broke or came off. It's not an easy job to replace because it's up against the chassis underneath, and you usually have to remove and replace some parts to get at it. Take a look under there, see if the belt's gone, and decide if you want to tackle it or have a shop do it.
Jun 12, 2010 | Cub Cadet Garden
Won't move
check drive belt and tension pulleys under machine if belt is stretched or damaged replace if popped off pulley check all to make sure one has not froze causing it to pop off also check rear pulley on axle sometimes pops off and just spins
May 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Oct 10, 2009 | Garden
Cratsman lt2000 lawn tractor will start but will not move forward or backward. I tried changing the drive belt, but that didn't work.
Is the transaxle pulley turning? If so have you removed the rear wheel recently and possibly lost the square key that fits on the axle?check those two items first.If ok it probably has a broken gear or shift key in transaxle.
Jul 14, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
331 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
