I have to download a program that I can put on a USB drive in different computers that I will be using. I bought a USB stick for this job but I have never used one. How do I download the program and how do I know if it is on the stick and how to use it? I am in the US and the program comes from Europe.
  • 4,737 Answers
Regarding your program and how it works, I need more details about the program you are going to download, otherwise it's not possible to tell you how it works. Would you be able to let me know the name or is it something confidential?
To transfer your program to your usb stick, follow the below steps:
1. Connect the usb stick to your computer's usb port.
2. An autoplay window should pop up on your desktop, if not, open "My Computer" and, locate "Removable Disk" or the name of the usb stick (this is different for different brands/models). Or in other words, you'll see a new Removable Disk icon (more or less similar to a hard disk partition icon, eg, C: icon).
3. Now, double click the icon to open it and see if it has something inside or not. Most usb stick nowadays have pre-installed application come with them, you don't need to delete them or there's neither problem deleting them. It's the software installed by the usb stick company.
4. Once it's confirmed that you can open it, go to the folder where you've saved your software (the software you like to transfer), right-click the software icon (or it could be a folder, depending on the software type), and then "copy".
5. Again go to the Usb stick folder, right-click anywhere in the folder (empty area) and select "paste" to paste the software in there. You may need to wait for few seconds or minutes depending on the size of the software/file.
6. Once it's done, close the usb stick folder.
7. Look at the taskbar notification area (the area on your desktop where the clock or other icons are shown), click the usb notification icon (it should be a dark-green icon, but I can't assure since I don't know your operating system) and select "Safely Remove Hardware" or "Eject" or "Remove the Hardware Safely" to safely remove it. While doing this, make sure no contents or programs saved on the usb stick is running or opened, otherwise, you'll be having problem removing it from your computer.
That's all, your software/file is saved on your usb stick..
For your reference, I have attached a link for you if in case you need more explanation. Click HERE to read more about transferring files from computer to usb stick/flash drive.
Let me know with more details if you need further help, so that I may help you better without assuming myself.
Good Luck.
Thanks for using FixYa.
Posted on May 23, 2011
IBM Travelstar usb 2.0 - when connected to pc get error msg - problem with drive need to scan - WILL scanning ERASE FILES THAT ARE STORED ON THE usb drive
the scan is just a program reading the files and folders either in the computer or storage device
normally it is done by the security program ( windows fire wall) or what ever program you have installed
it reports on any problems found and waits for your decision
if you run a system check, that is different as it will rectify any program faults as it goes not files or folders
it is always advisable to scan usb sticks when installing as that is a favourite way that hackers get into a computer
although the usb stick may be in your control all the time , downloads from your own computer can transfer a problem via usb stick
As for your concern---scanning will not change any files or folders but will report on any faults to you
Dec 31, 2016 | IBM Computers & Internet
Tip
Usb Boot stick!
Ok... i've been working on this for a while, Finally got it working! First download the program of your choice to put the image file on your flash drive (unetbootin, FlashBoot, Etc...) theres several out there.... Next download the iso of the OS that you want... You can get it from either a download site on the internet, or download a torrent from LimeWire, Use the program to Convert the ISO file to image format and put it on the flash drive, Next put the USB drive in the computer you want to run the OS on, On the Bios screen (boot up screen) press the corresponding button to change the system settings (usually F2) Choose to Boot from the USB drive, Follow the on screen settings and Your done!!!! Good luck and feel free to ask me any questions you have! I would love to Help! UPDATE: If your using a NetBook or other Computer with low memory, You may Have to download a Text Based Instillation Os, Most download sites offer alternative Downloads for these special computers.
on Mar 19, 2010 | Computers & Internet
Mi HP compaq laptop does not read the stik,any idea how to solve it?
Have you tried the stick in a different computer?
Where was the stick written to?
The first thing to do is see if you can read it elsewhere, copy the files off it if you can, format the drive using windows, check if you can read/write in your computer and copy the files back to it, leaving them as a backup on the other computer in case the stick is faulty
How to Format Flash Drive
OR
There are programs which can sometimes rescue usb stick data but your computer has to recognise that the stick is there. Look in disk management to see if it knows the stick is there. If it is you can use software such as
How to do data recovery from RAW usb drive may cost but is good
Data Recovery Software by ADRC is free
May 07, 2014 | HP Compaq DVD Drive
My del inspiron mini has no cd drive so how do i install new programs
Hi! Welcome to www.fixya.com.
You need to put your program on a flash drive or an external HDD and just plug in the to your usb port so you can install the programs yo like.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 19, 2011 | Dell Inspiron Mini 10 Notebook
I have just bought a Maxell USB Slim 4G to download files to, but I am not sure that I have bought the correct stick. Is it compatible with a normal USB port? Please advise, Many thanks Pam
Yes this product is compatible with a normal USB port. If your computer is not recognizing the drive when you plug it into your computer wait 1 minute for you computer to find it, if it still does not recognize it try using a different port and updating your USB drivers.
Mar 16, 2011 | Computers & Internet
I have an 8gb maxell usb memory stick which asks for passwords with ''Unlock an Enhanced memory stick''. I put in the password but nothing seems to unlock it. There is nothing on the disk as it is a few...
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
3.b) Format memory stick
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Feb 06, 2010 | Electronics - Others
The problem is with my 1GB memory stick. I don't
Check your computer
with antivirus and antispyware program and format 1GB memory stick.
1. Download this tool:
2. Format 1GB memory stick
Jan 21, 2010 | Electronics - Others
My usb 4gb flash don my computer only reads in a secure K with 1m
See http://www.maxell.eu/FAQ2/FAQ.html
Venture USB contain two partitions - one named 'Public' and the other 'Secure'. Unfortunately we have noticed a compatibility problem between these drives and some computers running Windows Vista. In these cases only one drive is showing in 'My Computer' - usually the 'Secure' drive. As a result you are unable to access the user manuals and software which are in the 'Public' drive and cannot alter the partition sizes to allow access to the entire capacity.
Please follow the below instructions to resolve the problem:
1. Connect the USB to the computer
2. Please unzip and run the attached program
3. After completion please unplug the USB
4. Re-insert the USB to the USB port
5. You should now be able to access both drives.
Please click here to download the program and instructions
Dec 28, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Putting on Computer what I have on Memory stick. I have saved songs from a Tyros 3 Keyboard and have difficulty putting it on Computer so that I can burn it on a CD...H E L P
Make sure you are in the song mode so you transfer just the song and not all the other stuff. Copy a song in the song mode to your USB stick, then read it on the PC. To burn it as DATA (MIDI data is data) you must use a burning program like Nero...
If you are trying to make an audio CD that is a different story as you need to convert the MIDI file to an audio format such as MP3 or WAV before burning and AUDIO CD.
Oct 19, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
Sony Memory Stick Duo Adapter
When you download to the computer, what program do you open with? Try not using the auto-open feature, and open direct from new device in "my computer".
Ed
Dec 11, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
