Window time diplay indicates cl when selecter switch is on number one that is the cold water wash,machine will not wash,model is wkf 2401
  • 8 more comments
  • plumfield Aug 16, 2008
    no luck with posted soloution,machine still in the same mode.
    have tried several times to resetthis machine with no luck, window time display still shows code--CL--WHEN SELECTER IS ON NUMB--1---HELP,
    THIS MACHINE IS ABOSCH WFK2401 THANKS
  • plumfield Aug 23, 2008
    bosch washer still in the cl mode when no1 which is cold water wash cycle is selected,machine will operae on all other selections???????????
  • plumfield Aug 27, 2008
    have followed all soloutions, to the letter,the last test came up with the code oo, which indicates no fault condition,however,the times showiing for temp and different wash cycles is all over the place,and most times its back to CL on numb1,have checked voltages at both ends-ok.
    have already aproached the hose problem in the early stages off this problem,thanks all the same,beginig to suspect a control moudle malfunction,please check all my postings to see if i have missed anything---thanks
  • plumfield Aug 29, 2008
    my machine indicates cl when you select no1 or no4---the rest off the cycle times are all over the place,I have run every test suggested, beging to suspect a control moudle failure????
    this machine is 5years old,made in usa,I recently removed main drive motor to replace the brushes--------------is it possible that I did not reconnect the harness wiring from motor to the main harness the right way????
    meant to get back to my last expert,semm ot have lost him ,machine displays cl on no1 and no4 the rest off the time cycles are all over the place,machine is from usa and is 6years old
  • plumfield Aug 30, 2008
    thanks to every one for their efforts,though it would be good to know why cl appears on noi and no4 instead of the selected time cycle--------comment please, thanks again.
  • Washing Mach... Master
  • 19,396 Answers
Follow techexperts12 indications, he is the head expert on Fixya, Vote his solution Fixya, so that he can earn his well deserved money.
Thanks for using Fixya.
Posted on Aug 29, 2008
  • 1,879 Answers
Worked before ? (washed in cold water selection)
reset didn't helped.
what are the conditions required in order for that machine to wash in cold water ?
Posted on Aug 27, 2008
  • monk3ybidzness
    monk3ybidzness Aug 27, 2008
    sounds logical that the control may be malfunctioning. check again your user guide about required conditions for the cold water wash cycle to start.
  • 813 Answers
U have to go with a professionl repairer
    Genius:
  • 1,056 Answers
How old is this washer?
And is it a US machine or a European machine? These 2 are almost completely different machines.
Since they are so different, the cures can also be different.
Bosch comes with a 2 year exchange or refund guarantee on their machines. So if you are withing the 2 year time period, I would contact the local Bosch service center with your problem.
Also, has the machine had any other repairs done to it recently? Has it displayed any behavior that doesn't seem "right" Reason I ask can have a lot to do with what might be causing the problem. This is sounding like a controller card fault.
Or it could be that the display is showing an incorrect error code.
Lets cover the above questions, and go from there.
Posted on Aug 23, 2008
    Master:
  • 623 Answers
Dowloadable manual here
http://laundry.manualsonline.com/manuals/mfg/bosch/bosch_wfk_2401_tumble_action_clothes_washer.html
  • 876 Answers
Check your cold water hose and make sure that the little screen is clean. On the back of the washer you will find two hoses. One will feel warm and the other cold. Turn off the washer and unplug it. Have a bucket and some towels nearby. unscrew the hoses and clean the little filters at the ends carefully. sometimes sand can get in there and completely stop water from entering. While you're there make sure your cold water valve is turned all the way on and that they hose is not twisted or flattened in any way.
I hope this works for you. Thank You for using Fix Ya!
    Genius:
  • 1,011 Answers
Dear sir/madam,
Enter the test program by:
1. Set the cycle knob to any "X" (reset) position
2. Press and hold the Pre-wash and the Start buttons at the same time. While still holding these buttons, turn the unit on by pressing the On/Off button
3. Keep holding the Pre-wash and the Start buttons until the digital display comes on (about 5 seconds)
The digital display will show 00 for no faults or will show a fault code.
To end the test program turn the washer off at any time.
thanks
good luck
Posted on Aug 16, 2008
  • 1,800 Answers
Its bosh
and follow me
Initially check the filter on your washing machine and clean if necessary, your manual should detail this procedure. If your machine will not start or complete the programme, check:
  • The plug, the socket and the switch, if necessary, with another appliance.
  • The fuse in the plug.
  • That the door is closed.
  • That a programme is accurately selected.
  • 594 Answers
What is the make of the washer? ge,kenmore,sharp.ect....
Posted on Aug 15, 2008
  • Cameron Viseth
    Cameron Viseth Aug 15, 2008
    are you sure it is WKF and not WFK
    Master:
  • 521 Answers
Try reset.unplug the machine n replug in n switch on after 5 mins.
  • tech expert12 Aug 29, 2008
    it is quite possible that u did not reconnect the harness wiring from motor to the main harness the right way.recheck it.hope it helps.
    pls do rate the solution
    thanks.
    regards.
    fixya expert team
My Bosch WFK2401 washer has stopped filling. The cycle will count down and the pump will run to drain (but nothing to drain!). I have checked the supply lines, there is water and the filter screens are...
I suspect the solenoid on the water input connection has failed, this is the unit that allows water into the machine , if you know a bit open the lid and you should see this just inside behind the cold water connection.
Oct 20, 2013 | Bosch WFK 2401
The washer work but stop along the way,ie unable to complete the circle
see this steps and fix it. God bless you
Lid Switch Assembly
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Enter your model number to see parts for your washing machine.
Help me find my model number
Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 13, 2013 | Washing Machines
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
Washer heavy duty cycle issue
Lid Switch Assembly
Water Inlet Valve
Main Control Board
Timer
God bless youcb4af627-0171-42f5-ad0a-5f8e85e72ae0.gif6634bf88-8eca-4d0f-b59c-0e8829e5d59d.gif419f93c3-fea0-4d93-af85-2e59d98d88e0.gif
May 23, 2013 | Whirlpool AWG320 Front Load Washer / Dryer
On my Maytag Washing Machine...Sometimes my water selector works... sometimes it doesnt. Sometime hot will come out when set on cold and sometimes cold will come out when set on hot.. Sometimes it works...
Hi and welcome to FixYa, I am Kelly. Just reading this it sounds like the water temp selector switch is acting up. You did not provide a model number so this is just an outright guess to help you. Try this if you have the button type start mashing the buttons several times between temps. Do it with conviction. Your cycling the switch to unstick or clean off the contacts in the switch. If the cycle temp switch fails while doing this; changing the switch was the next recomendation to correct the temp problem. You should cycle the switch at least 30 times methodically. Press, change temp, press repeatedly. Then check your cycle water temps for hot and cold as selected. Depending upon model you could have a problem with the water inlet valve. I will wait for a response before commenting on that.
If you need specific model information I need your Model number.
Thanks for choosing FixYa,
Kelly
Nov 14, 2010 | Washing Machines
Our Bosch WFK 2401 keeps filling with hot water - even when a cold cycle is selected.
The problem is the water inlet valve has failed. Although it is only the cold water the whole valve needs to be replaced. There are 2 solenoids on the valve 1 for cold 1 for hot the cold water solenoid has failed. The reason it works in the softner is it uses a separate solenoid to let water in there.
Check the below link , it might be useful;
http://appliancehelponline.com/washerwaterinlet.html
Jul 21, 2010 | Bosch WFK 2401
My bosch wfk 2401 when i start the wash everything is fine then after a couple of minutes it starts beeping the error code 01. i have checked to make sure the filters are cleaned out and that the water...
Hello and welcome to fixya.
I'll start by saying you're right the "01" error code is indicating a fill problem has been detected by the control.
Have you tried just a "cold" water wash ? If not try selecting "quick wash" and on the dial turn it to #1 "cold" in the cotton setting see what happens. Do the same and select #3 "hot". If the error occurs in one and not the other, observe and either focus on the hot water valve or the cold main wash valve ( I don't think it is the cold prewash valve or the error would occur immediately ).
In fact I suspect it is the main wash cold valve ( dual valve ) since you haven't indicated the error occurs during prewash and the hot water valve is energized in prewash by design to help rinse out the detergent no matter what cycle or temp. you selected.
Having said all that, here's what you're dealing with. Even though you appear to have sufficient water flow as you stated you checked for, the electronic control doesn't think it is correct.
There are several factor's which could possibly be causing this error, a couple you've mentioned.
They are...
 Water supply turned off. ( obviously not in this case )
 Water inlet hose filters (strainers/screens) blocked. ( you've said you cleaned them out )
 Water pressure too low. ( must be no lower than 14.5psi and a max. of 145psi )
 Water inlet valve(s) has failed. ( this doesn't appear likely...at least at first, not completely failed based on your description...but the control may think it has. If you have an ohm meter you can check it. the coils should have a value of between 2.7 and 3.3k ohms. That means 2700ohms and 3300ohms. If not within those values the control will detect the value being incorrect , hence displaying the "01" error. Change the valve, Bosch part # 265772, or repairclinic.com # 467537.
The Hot water valve if need be is Bosch part # 171295 or repairclinic.com # 423900 )
 Control module has failed. ( Not very likely either...but possible...if not the valves. )
Let me know what you find as I will watch for your reply here. Thanks for visiting "fixya". Please take a moment and rate the info provided for you here today.
Let me know if you require further assistance.
Thanks and good luck.
macmarkus :)
Jun 12, 2010 | Bosch WFK 2401
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
Bosch wash front loader
code 00 means machine did not spin
check load for out of balance
redistribute load and restart
good luck
Aug 27, 2008 | Washing Machines
CL on display panel - washing machine will not respond
CL stands for child lock to take it off press and hold TEMP and TIME DELAY at the same time and this should remove it
Dec 11, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
