Question about Refrigerators
I have double door frig., the cooling side is warmer then it should be. I've had the computer board changed,which was quite expensive and the thermostat. When I called my serviceman back a second time thats when he put in the board. But it still did the same thing(warmer on the cooling side). Called him bac, he has to unthaw something. It has worked now for 4 wks. And her the same problem again.
  • 4,059 Answers
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on May 23, 2011
I saw your response to another Kenmore frig and I have a similar problem I want to ask you about. I have a Side-by-side Kenmore frig(model 106.9555722) that we've had for 16 years!! Other than r
I have seen this one other time in all my years of appliance repair and changing out the "water inlet valve" corrected the problem. I don't have an answer to why it did, but it did. Here is the valve for your unit.
After you change the valve be sure to purge the water line for a good 5 - 10 mins to get all the nasty water out. Keep me posted!
Nov 24, 2012 | Kenmore Side by Side Refrigerator
Changed door switch and still its like the dryer has no electricty
The nicest problem would be that one side of the 220VAC power line is dead, possibly due to a bad circuit breaker. The drum light runs off one side of the line only, but everything else requires 240VAC (i.e., both legs of the line.) So, if you're really lucky, you could turn off the circuit breaker, turn it back on, and everything will work. If you've got a voltmeter handy you could also verify 120 VAC between each leg and neutral, and 240VAC between the two legs.
If your incoming power os OK, it's an electronic control (aka main circuit board, computer board) problem. The solution could be as simple (and cheap) as just reseating the connectors going to that board, or as simple (but expensive) as replacing the board.
Sep 14, 2012 | Kenmore Elite HE4 Electric Dryer
Refrigerator starts cooling mainly when I open the door
Put a thermometer in both the freezer and the fridge. Fridge should be around 40F if not a little lower, but should stay above 30F.
Freezer should be just below 30.
Feb 09, 2012 | Refrigerators
I have a GE Gss22iFRE CC side by side. The strip between the 2 doors is very warm to the touch. I have vacuumed the rear panel and removed the rear panel and vacuumed. The fan blade will move freely by...
most likely you have a bad computer board,if the condenser fan runs slowly or not at all i've been changing the computer board and it runs fine.everything on this machine runs through the board,unplug it,remove the cover to the computer board on the back of the machine and look at the board,if you look at it you'll see black relays,if your board doesn't have all 7 relays on it you don't have the newest board in your fridge and this is your problem,part number WR55X10942 and it's around 150 dollars.look at j1 pin 2,if there's a yellow or white wire in pin 2 cut it,you'll see this on the instructions,get any kind of a fan and blow it onto the back of the machine to keep the compressor cool and change out the computer board as soon as possible or you'll cook the compressor,i've had costumers run a fan in the back until i could get to them till the next day and it works great but change out the coil tomorrow,you can check the condenser fan motor with a meter but most likely it's gonna be the computer board.hope this helps you out,salde
Sep 16, 2011 | GE Refrigerators
Not cooling,lower part of the frig and freezer gets cold
You may need to set the Fridge side thermostat cooler or there may be a slide switch that allows ou to set the "bias" more toward the fridge side.
Jun 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore frig/freezer, light/power on, no cooling in frezer.
looks like you have a leak in the cooling system, call sears out right away to save yourself from an even more expensive repair.
Jun 15, 2009 | Freezers
Freezer stays warmer than frig
Jim, chk for air diverter in wrong position
the fridge cools from freezer air flow direction control. Like a door. The more/less controls may be messed up.
May 14, 2009 | Home
Divider strip between fridge and freezer is hot
First take the grill off at the bottom under the doors look at the grate under the frig That is your condenser it will probably be covered in dust clean it off the see if you can fill air blowing under the frig there is a fan under there that keeps that coil cool and it runs around the door to keep condensation from build around the doors if no air is blowing take the back panel behind the Frig and there should be a fan running if the compressor is running this will also cause the compressor to over heat and will not cool as well but it might just need to be cleaned Good luck
Apr 03, 2009 | KitchenAid KSRG22FK Side by Side...
Kenmore refrigerator 5260 not cold
  • the defrost timer on your machine is actually integrated within a control board/air diffuser. hopefully that is not the problem (expensive).
  • i would start by testing the heater and bimetal thermostat in the freezer. (note: the bimetal thermostat will only have continuity when below 40 degrees.)
  • the heat you feel between the doors is normal (if it is not too hot).
  • some of the heat that is released by the machine is intentionally released between the doors to prevent condensation.
  •  if it seems warmer than usual then you might need to clean the coils under the machine and make sure the airflow under the machine is not obstructed at all.
  • if the coils are dirty then they will not be able to release the heat properly and the heat will be released in other areas like between the doors.
Jul 18, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Freezer works like frig-freezer lite only one working
ch the fan in the frige feel it if is blowing air .or is slow. you need to replace the fan moter.
Feb 06, 2008 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
