Question about Brother Office Equipment & Supplies
My Brother printer will not print from my Mac computer screen. It copies from pages I place on the copy machine.
  • 1 more comment
  • sbellbaby Aug 15, 2008
    Thank you. However I cannot seem to find a site to download a driver for a Mac machine.
    To: CMV9
    I need to download a driver for my Mac computer. The model # of my Brother printer is MFC-5440CN.  Your assistance would be appreciated.
  • sbellbaby Aug 17, 2008
    Thank you for trying to help. I went to the site you suggested and I could not find a download for my computer. there are mostly windows programs. My computer is
    Mac OS X version 10.5.4
    Master:
  • 521 Answers
It sound like communication problem
Posted on Aug 15, 2008
  • tech expert12 Aug 15, 2008
    also try out downloading drivers that supports mac.
    also try reset by unplugging the machine n then plugging it on after 5 mins.
  • 594 Answers
Have you downloaded the drivers for your printer for MAC users?
6ya staff
SOURCE:
MFC_5840CN Will not print, not showing
Typically, a Brother machine stops printing, because the connection between the computer and the Brother machine is lost. There are multiple reasons for a lost connection.
  1. The Brother print driver is Offline.
  2. The Brother printer driver is not set as the default printer driver.
  3. The computer, not the monitor, connected to the Brother machine is set to go into sleep or standby mode. When the computer goes into sleep or standby mode, the connection between the computer and the Brother machine is lost and needs to be re-established.
Follow the steps below in order to re-establish the connection between the Brother machine and the computer:
  1. Verify that the Brother machine is connected with a USB cable and is not on a network.
  2. Verify the power cord and USB cable are securely connected. If the USB cable is loose on either end, disconnect and reconnect the cable securely. Test the machine by trying to print. If the machine does not print, go to STEP3.
  3. Cycle the power of the Brother machine by unplugging the power cord from power outlet, wait approximately one minute and plug back in. Once the Brother machine displays the date and time after plugging it back in, test the machine by trying to print. If the machine does not print, to Step 4.
  4. Reboot the computer connect to the Brother machine and then try to print again.
Apr 01, 2008 | Office Equipment & Supplies
MFC-L27OODW Monoblack. How do I print double sided page from passport?
Scan the document to the computer then piece the two pages together on a page using whatever editing software you use. then print it again. I don't think there is any way to duplex copy something like a passport since it requires it being placed on the scanner and scanned in two copies.
Dec 29, 2015 | Brother MFC Office Equipment & Supplies
Won't print. Red light blinking
Reboot your computer and power down your printer. Leave them off for about 30 minutes or even overnight. (In other words, leave the computer and printer off more than a few minutes--some of the printers take more than 5 minutes before they'll clear their memories--a quick reboot won't do it.)
When deleting print copies it is safer to use the delete button on the printer than to delete from your computer, as then the copies don't get hung up in spooling.
I've had to do this a few times with Vista and printers, as things get held up in spooling on a regular basis.
Jan 05, 2009 | Brother HL 1440 Laser Printer
Brother MFC-8440 will not print or copy
YOU HAVE TO RESET.
TURN OFF THEN PRESS THE STOP /CLEAR BUTTOM THEN TURN ON KEEP PRESS ABOUT 10 SECOND THEN IT WORK .
Oct 15, 2008 | Brother MFC-8440 All-In-One Laser Printer
Double sided printing Pixma MP520
here's how:
print double sided pages
1. Set your computer software for double sided printing if you have a printer that is compatible. Double sided printers are generally professional style machines, and most offices, schools and libraries will have them. On a PC, go to the drop down "File" menu and select "Double Sided Printing" under the "Preferences" or "Properties" window and print. If you have a MAC, click "Copies and Pages" under the "File" menu, select "Layout" and then click on "Long-Edged Binding" and print.
2.Print double sided with your standard home printer, again, by setting your PC writing software. When you are ready to print, click on the drop down "File" menu and select "Print." From the "Print" window select "odd pages only," or "even pages only."
3.Set your odd and even pages a bit differently if you are working with MAC writing software. Select "Print" from the drop down "File" menu and click on the arrow to drop the "Copies & Pages" menu. Under the "Copies & Pages" menu, select "Paper Handling" and then click on "Odd Numbered Pages" or "Even Numbered Pages."
4.Select "Odd Pages Only" or "Odd Numbered Pages" and then print as usual. It is a good idea to mark the top of your first page with a pencil so that you know the direction and side of the page your printer prints. Use the mark to determine how to turn your pages and place them back in the printer. Select "Even Pages Only" or "Even Numbered Pages" and print again. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
Sep 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Open Questions:
James Cagle
James Cagle
Jim Keysor
ctnozil
