Question about Siemens WXLM112GB Front Load Washer
When i press start button machine takes in water,and drum turns.Status l.e.d.goes to active,Suddenly machine stops,and statusl.e.d.indicates on.what is the problem.
    Problem Solver:
  • 14 Answers
If it need moore than 8 min.to fill up with water,you must clean up that filter from inlet hose.
Posted on May 23, 2011
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
How can I replaced the PF KIT2 on my MFC9420CN?
2.3 Parts Life Reset Function
This function is provided for service personnel in order to reset the counter of each periodical replacement part and count the number of replacement times when replacing the periodical replacement parts.
(1) Press the 3 and 9 buttons at the same time in the ready
status. (sometimes can be 2 or 8 or 1 or 7)
(2) The "Reset Menu" will appear on the LCD. Select the
applicable periodical replacement part by pressing the up arrow or down arrow button and press the OK button.
- Drum - Belt Unit - PF KitMP - PF Kit1
- PF Kit2 - Fuser - Laser
(3) When the OK button is pressed the "1. Reset 2. Exit"
appears on the LCD. Press the 1 button if resetting the
counter. If not, press the 2 button.
(4) Pressing the 1 button accepts that the machine implements
the counter reset.
(5) If the 2 button is pressed the machine goes back to the
select part counter again. If you need to Exit press the
Stop/Exit button at any time.
(6) The machine returns to the ready status.
Note:
- All periodical replacement parts are always indicated on the LCD even though their lives do not reach 0 %.
- The PF kit2 is always indicated even though Tray 2 is not installed, or it is not supported for the model to be used.
- The machine returns to the ready state automatically if no panel operation is implemented for 60 seconds.
Apr 18, 2011 | Brother Office Equipment & Supplies
MFC9420CN brother printer says Check tray #1 Reinstall tray
I had this same problem. The solution was resetting it, and the instructions below worked for me:
status.
the counter reset.
Mar 03, 2011 | Brother MFC-9420CN All-In-One Laser...
Have replaced drums in printer and after turning the printer off and on several times, there is still a message saying "drums end soon"
1) Press the 1 and 7 buttons at the same time in the ready
status.
the counter reset.
Note:
Jan 17, 2011 | Brother MFC-9420CN All-In-One Laser...
F2 code
Hi, F2 code on the Kenmore indicates a problem with either of the control board and the user interface board. Run the console and indicators diagnostic test mode to find out.
Console and Indicators Diagnostic Test Mode Activation
  1. While in standby mode press the following button sequence within four seconds: SOIL LEVEL>WASH RINSE TEMP>SOIL LEVEL>WASH RINSE TEMP
  2. Press START within five seconds when "dt" shows on the display. All indicators in display are lit and "88" is displayed.
  3. Press START again. The two-digit display and the status indicators turn off while all other indicators remain lit.
  4. Press START again. The two-digit display and the status indicators turn on while all other indicators remain lit.
  5. Rotate the WASH CYCLE selector back and forth. The indicators will switch on an off.
  6. Press the buttons to check the functions. The indicators switch on and off and a beeping sound will be heard when a button is pressed.
  7. Press STOP or POWER button to exit diagnostic test mode.
  8. If no indicators light up or if no beeping sound is heard when a button is pressed or if some buttons do not light up indicators when pressed, check the control board, the user interface board, and the connection between them.
  • Unplug the machine.
  • Remove the three screws on the back of the console.
  • Lift the console off the cabinet.
  • The control board is located on the right side of the console viewed from the front of the machine. Disconnect the middle wiring harness connector on the right side of the control board near the pressure transducer hose.
  • Clean the connector and the terminals thoroughly with brush and alcohol.
  • Reconnect and disconnect the connector several times.
  • Reinstall the console and reconnect power.
  • If the problem is not resolved, replace the user interface board.
  • If the problem is still not resolved with the replacement of the user interface board, replace the control board. You may also replace both board at the same time and keep the old good board as a spare.
Take care
Jun 20, 2010 | Kenmore Oasis 27042 Top Load Washer
My oasis kenmore elite keeps flashing f 50
The machine control through the rotor position sensor (RPS) cannot detect the motor running. The rotor is stuck, the rotor position sensor is faulty, or the machine control is malfunctioning. Open the lid and turn the drum manually. If it turns freely, activate the Manual Diagnostic Mode Test to check the functionality of the rotor position sensor and the machine control. If it doesn't turn freely, let us know to guide you in troubleshooting and repairing it.
The machine should be in standby mode when activating diagnostic test mode. That is, the machine is plugged in will all indicators off, or with only the Clothes Clean indicator on.
Choose any single button except Start, Stop, and Power. Press and hold the chosen button for 3 seconds and release it for 3 seconds; press it again for another 3 seconds and release it for another 3 seconds; press the same button again for another 3 seconds and release it (press, release, press, release, press; 3 seconds each).
The indicators will all light up for 5 seconds with 88 displayed in the Estimated Time Remaining display if the test mode has been successfully entered.
Repeat the procedure if the test mode is not activated. You may choose another button. Let us know if it cannot be activated after multiple attempts failed.
Press the same button chosen above before the indicators turn off (5 seconds). A single beep sounds and the two-digit console ID number is displayed. After 3 seconds the display is cleared (00) and the Add a Garment indicator flashes.
Open the lid and rotate the basket manually. The Wash, Rinse, and Spin status indicators should toggle on and off according to the rotation of the basket.
Press and release the 2nd Rinse button to lock the lid and the lid lock indicator turns on. Press and release the Rinse Speed button. The basket should spin slowly; pressing it again will raise the spin speed. The motor turns off and the basket stops the fourth time the Rinse Speed button is pressed.
With the basket stopped, press the Soil Level button to activate the Gentle wash action. Press it again to activate the Normal wash action. Press it again to activate the Heavy wash action. Press it again to turn off the motor and stop the basket.
Let us know the result of the test for us to guide you in troubleshooting the problem and eventually repair it.
Feb 22, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Water is not pumped away, or stops in the middle of a cycle and displays one of a several error messages
Recall the error codes by activating the Automatic Diagnostic Test Mode to determine the cause of the problem. Select any one button, except Power, Start, and Stop, and follow this:
Press and hold the button for 3 seconds>Release the button for 3 seconds>Press and hold the button for 3 seconds>Release the button for 3 seconds>Press and hold the button for 3 seconds
All of the indicators on the console will light up for 5 seconds while 88 is displayed on the Estimated Time Remaining display. If not, repeat the step. Let us know if it cannot be activated.
The program then checks for any saved error codes after 5 seconds. List down the codes and post it back here. The console indicators will turn off then on with the 88 displayed if no error codes are recalled. After 5 seconds, the automatic test begins. The program performs a four-minute automatic test to check major washer functions. Press the same selected button in activating the automatic test above to advance through the automatic test steps.
  1. C0: The motor goes to a slow spin.
  2. C1: Warm water fills through the fresh dispenser and basket floats then disengage.
  3. C2: Cold water fills through the bleach valve for 10 seconds.
  4. C3: Hot water fills through the fabric softener valve for 10 seconds.
  5. C4: Warm water fills through the detergent valve for 10 seconds.
  6. C5: Agitates for 15 seconds.
  7. C6: Recirculates for 10 seconds.
  8. C7: Drains to engage basket and drain further for 10 seconds.
  9. C8: Drains and spins slowly.
  10. C9: Coasts to stop.
  11. Press the Stop or Power button to cancel/exit the test.
Inform us about the result of the test for the repair guide if necessary.
Feb 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does LF mean?
It is a long fill error. It flashes when the machine control board detected no change in the water level or the water level is not reached in a certain period of time during the fill cycle. Water is probably not entering the tub due to the water inlet valve not functioning or water enters the tub but not properly due to clogged fill hose screens.
Press the Pause/Cancel button to clear the error on the display. Remove the fill hoses from the water inlet valve assembly at the back of the machine and check the screens. Clean the screens and replace it if necessary. Make sure that the water supply valve is open and water is present.
Put the machine in standby mode (only the Clothes Clean indicator is on) and activate the Manual Diagnostic Test Mode to check the operation of the water inlet valve.
  1. Select any one button except Power, Stop, and Stop.
  2. Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds
  3. Press the same button when all indicators on the console are illuminated and "88" is displayed on the Estimated Time Remaining display. A single beep sounds and display shows the two digit console ID number for 3 seconds. The displayed ID number will change to "00" and the Add a Garment indicator will flash.
  4. Select Whitest Whites cycle.
  5. Press Start>Wash/Rinse Temp. The water inlet valve should turn on and fill the tub according to the Wash/Rinse Temp selection.
  6. Press Start to turn off the valve.
  7. Press Stop or Power button to exit diagnostic test mode.
Feb 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a kenmore Oasis that powers up but wont start
Activate the Console and Indicators Diagnostic Test Mode to check the functionality of the .
  1. While in standby mode, press the following button sequence within four seconds: SOIL LEVEL>WASH RINSE TEMP>SOIL LEVEL>WASH RINSE TEMP
  2. Press the START button within five seconds of "dt" showing on the display. All indicators should turn on and "88" is displayed.
  6. Press the buttons to check the function. The indicators will switch on or off and a beeping sound will be heard when a button is pressed.
  8. If no indicators light up or if no beeping sound is heard when a button is pressed or if some buttons do not light up indicators when pressed, check the user interface board and its connection to the main/control board.
  • Clean the connector thoroughly to ensure a good connection.
  • Run the diagnostic test once again.
  • Replace the user interface board if it fails the test once more.
Refer to the next post if no problem is found on the user interface.
Jan 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
How do you reset the fuser counter on the 9440CN from Brother
status.
(2) The “Reset Menu” will appear on the LCD. Select the
< Periodical replacement parts are indicated on the LCD >
(3) When the OK button is pressed the “1. Reset 2. Exit”
the counter reset.
Oct 30, 2009 | Brother MFC-9440CN Laser Printer
Siemens WXLM112GB Front Load Washer Logo
274 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
